  3. Alternative to ArduinoIDE
29 Posts 13 Posters 10.8k Views 10 Watching
    I'm still using arduino ide, or sublimetext on my side too...it's a long time i would like to try visualmicro so i could use VS but never find the time to try.
    problem is sometimes when you change your chain, things can goes well or you need to dig in. so i was lazy. But i agree, arduino ide is ...too simple :) something with brackets (I don't know if there is a plugin like this btw) or sublimetext, is simple but a lot better!
    And more sense to use a nice ide, if you want to use other mcu with mysensors..on my side I prefer local solution, not a big fan of cloud dev..
    @ericvdb do you use VisualMicro ? does it work well, not so much things to change to make libs working, mysensors for instance? it's very tempting..
    tekkaT 1 Reply Last reply
    • scalzS scalz
      tekkaT
      tekkaT
      tekka
      @scalz @Daniel-Oliveira I'm using VS with VisualMicro - works smoothly with lots of nice features...
        @tekka rooooooh, that's not fair :) thx for info :thumbsup: so now I have no excuse to not try. great
        • Daniel OliveiraD
          Daniel OliveiraD
          Daniel Oliveira
          Thanks to all of you for your feedback,
          I'll give it a try to Visual Micro, I?m also curious about PlatformIO with eclipse as editor.
          I'll keep ou posted on the results for future reference.
          Regards
          MySensors rules my home :)
          • D
            drock1985
            This is a good thread; been recently contemplating changing IDE's myself.
            Visual Studio seems to be the most complete - I think I will give this one a try. Anyone have any tips for how to use this coming from the Arduino IDE (with no previous programming experience?)
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            Daniel OliveiraD 1 Reply Last reply
            • D drock1985
              Daniel OliveiraD
              Daniel OliveiraD
              Daniel Oliveira
              Being using it from some hours and indeed it seems to be a great alternative, it even has a dark skin :D
              You can use it to program in a more pure C++ way (my goal here), but it also support projects with .ino files so you can use your existing ArduinoIDE projects.
              To get used to Visual Studio/Micro I'm following their User guide, you can find it HERE
              Feel free to continue sharing your experiences
              S 1 Reply Last reply
              • Daniel OliveiraD Daniel Oliveira
                stedew
                @Daniel-Oliveira
                Hello Daniel for what it's worth: Jantje posted a Fix in Github:
                the selection of subfolders included to the path is not consistent with the Arduino IDE
                Just have to test it further
                Regards,
                Stefan
                • tbowmoT
                  tbowmoT
                  tbowmo
                  I have plans for trying to get platform.io up and running, specially because I use ATOM editor for most file editing (even in mysensors core).
                  I have some shell scripts that enables me to build sketches etc. from cli, all are based on arduino in cli mode though, but makes it easy for me to verify errors / warnings in a sketch when I hack on core files (which you can't edit through arduino anyways)
                    Stuart Middleton
                    As a professional developer who lives in Visual Studio and XCode, I prefer the VS plugin. I'm not saying it's any good, and in fact it crashes now and then, but you get all of the power of VS behind you.
                    dpressleD 1 Reply Last reply
                    • S Stuart Middleton
                      dpressleD
                      dpressleD
                      dpressle
                      @Stuart-Middleton +1
                      Are you using vs2015? with the arduino IDE extension?
                        Stuart Middleton
                        Yes. However I've found it more unstable than the previous version. Maybe that's just my setup.
                          dpressleD
                          dpressleD
                          dpressle
                          @Stuart-Middleton I am getting so many errors on a simple sketch:
                          Severity Code Description Project File Line Suppression State
                          Error (active) expected a '{' c:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h 154
                          What am i missing here?
                          • dpressleD
                            dpressleD
                            dpressle
                            Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MyTransport.cpp 507
                            Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MySensorsCore.cpp 262
                            i get this on all of the debug function calls in these files.
                              Stuart Middleton
                              I don't know. I would suspect that certain defines are not set up correctly or you are building for an unsupported CPU or a CPU you don't have installed?
                                Hi everyone!
                                I would like o know if any of you use an IDE to develop MySensors projects and libraries, I find ArduinoIDE atrocious.
                                Actually I think that it does not even deserve the name of IDE because does not even highlight all occurrences of a selected work.
                                I've tried sloeber: http://eclipse.baeyens.it/index.shtml but I'm not able to make it to compile the MySensors library 2.0.0 due to the extensive use of #defines and #ifndef, etc.
                                Does anybody use anything else that can recommend?
                                Thank you all in advance,
                                Daniel
                                andrewA
                                andrewA
                                andrew
                                wrote on last edited by andrew
                                #22
                                Hi Everyone, Hello @Daniel-Oliveira
                                I also played with Eclipse and the Sloeber plugin (now v3.1 is out).
                                Eclipse is a very powerful IDE and Sloeber is a pretty good plugin for enhancing the IDE's feature and make the Arduino development possible in Eclipse.
                                There are some issues with the INO file support and limitations, but if you use cpp files instead of ino then some problem automatically disappear.
                                The plugin installation to the IDE is pretty easy, its library manager is also good and you can easily add your own library paths as well to the whole IDE or to the project.
                                When I tried to compile basic or example sketch codes it worked like a charm, but when I tried to include and use the MySensors library then it caused tons of errors caused by unresolved defines and it also started to compile every file which were in the included library path, even if those were not included in the code.
                                The solution is quite trivial, although I spent some days to investigate the issue... the root cause of this problem is that included libraries will be part of the build paths, so the build process will try to compile the whole library code base without proper define inits etc.
                                So, what you have to do is just remove the added library from the build.
                                This can be done multiple ways, e.g. by right clicking on the added library in the project explorer, then select resource configurations / exclude from build...
                                In the appearing dialog select the proper option (by default the "Release") and press ok.
                                After this trick there is no more problem with the MySensors library and the code compiles without any problem.
                                Furthermore, if you use cpp files instead of ino, then you don't have to worry about the define sections and you don't have to declare the defines in command line options.
                                Hope this helps for those whom try to use a normal IDE for development.
                                Cheers,
                                Andrew
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  The development branch has been updated with a SublimeText 3 project. Enjoy! The project file contains instructions for installing the plugins necessary.
                                  andrewA 1 Reply Last reply
                                  • AnticimexA Anticimex
                                    andrewA
                                    andrewA
                                    andrew
                                    Ok, but as far as I know subimetext is just a pretty good text editor which is enhanced with fancy features, so it is good for auto completion, code highlight etc, but does it provide features like a real IDE does? For example highlight warnings and errors during the code writing - e.g. typos, undeclared/unreferenced stuff, unused code segments, type or casting problems etc. - and not just output the compile time error log?
                                    AnticimexA 1 Reply Last reply
                                    • andrewA andrew
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @andrew yes
                                        @andrew yes
                                        andrewA
                                        andrewA
                                        andrew
                                        @Anticimex hm... ok, I'll try to use both of them for a while then make the conclusion...
                                        • andrewA andrew
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @andrew just make sure to install the plugins, or it will just remain a simple editor
