  3. Alternative to ArduinoIDE
29 Posts 13 Posters 10.8k Views 10 Watching
    Stuart Middleton
    As a professional developer who lives in Visual Studio and XCode, I prefer the VS plugin. I'm not saying it's any good, and in fact it crashes now and then, but you get all of the power of VS behind you.
    dpressleD 1 Reply Last reply
    • S Stuart Middleton
      dpressleD
      dpressleD
      dpressle
      @Stuart-Middleton +1
      Are you using vs2015? with the arduino IDE extension?
        Stuart Middleton
        Yes. However I've found it more unstable than the previous version. Maybe that's just my setup.
          dpressleD
          dpressleD
          dpressle
          @Stuart-Middleton I am getting so many errors on a simple sketch:
          Severity Code Description Project File Line Suppression State
          Error (active) expected a '{' c:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h 154
          What am i missing here?
          • dpressleD
            dpressleD
            dpressle
            Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MyTransport.cpp 507
            Error (active) missing closing quote c:\Users\dpressle\Documents\Arduino\libraries\MySensors-2.0.0\core\MySensorsCore.cpp 262
            i get this on all of the debug function calls in these files.
              Stuart Middleton
              I don't know. I would suspect that certain defines are not set up correctly or you are building for an unsupported CPU or a CPU you don't have installed?
              • Daniel OliveiraD Daniel Oliveira
                Hi everyone!
                I would like o know if any of you use an IDE to develop MySensors projects and libraries, I find ArduinoIDE atrocious.
                Actually I think that it does not even deserve the name of IDE because does not even highlight all occurrences of a selected work.
                I've tried sloeber: http://eclipse.baeyens.it/index.shtml but I'm not able to make it to compile the MySensors library 2.0.0 due to the extensive use of #defines and #ifndef, etc.
                Does anybody use anything else that can recommend?
                Thank you all in advance,
                Daniel
                andrewA
                andrewA
                andrew
                wrote on last edited by andrew
                #22
                Hi Everyone, Hello @Daniel-Oliveira
                I also played with Eclipse and the Sloeber plugin (now v3.1 is out).
                Eclipse is a very powerful IDE and Sloeber is a pretty good plugin for enhancing the IDE's feature and make the Arduino development possible in Eclipse.
                There are some issues with the INO file support and limitations, but if you use cpp files instead of ino then some problem automatically disappear.
                The plugin installation to the IDE is pretty easy, its library manager is also good and you can easily add your own library paths as well to the whole IDE or to the project.
                When I tried to compile basic or example sketch codes it worked like a charm, but when I tried to include and use the MySensors library then it caused tons of errors caused by unresolved defines and it also started to compile every file which were in the included library path, even if those were not included in the code.
                The solution is quite trivial, although I spent some days to investigate the issue... the root cause of this problem is that included libraries will be part of the build paths, so the build process will try to compile the whole library code base without proper define inits etc.
                So, what you have to do is just remove the added library from the build.
                This can be done multiple ways, e.g. by right clicking on the added library in the project explorer, then select resource configurations / exclude from build...
                In the appearing dialog select the proper option (by default the "Release") and press ok.
                After this trick there is no more problem with the MySensors library and the code compiles without any problem.
                Furthermore, if you use cpp files instead of ino, then you don't have to worry about the define sections and you don't have to declare the defines in command line options.
                Hope this helps for those whom try to use a normal IDE for development.
                Cheers,
                Andrew
                S 1 Reply Last reply
                • AnticimexA
                  AnticimexA
                  Anticimex
                  The development branch has been updated with a SublimeText 3 project. Enjoy! The project file contains instructions for installing the plugins necessary.
                  andrewA 1 Reply Last reply
                  • AnticimexA Anticimex
                    andrewA
                    andrewA
                    andrew
                    Ok, but as far as I know subimetext is just a pretty good text editor which is enhanced with fancy features, so it is good for auto completion, code highlight etc, but does it provide features like a real IDE does? For example highlight warnings and errors during the code writing - e.g. typos, undeclared/unreferenced stuff, unused code segments, type or casting problems etc. - and not just output the compile time error log?
                    AnticimexA 1 Reply Last reply
                    • andrewA andrew
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @andrew yes
                        @andrew yes
                        andrewA
                        andrewA
                        andrew
                        @Anticimex hm... ok, I'll try to use both of them for a while then make the conclusion...
                        • andrewA andrew
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @andrew just make sure to install the plugins, or it will just remain a simple editor
                            andrewA
                            andrewA
                            andrew
                            @Anticimex of course :)
                            • andrewA andrew
                              Cheers,
                              Andrew
                              stedew
                              @andrew
                              Hello Andrew, as Anticimex already answered also other IDE's are possible (Atmel Studio with a arduino plugin seems to work) Atom, and others I use the Eclipse + plugin solution and are happy with it. It is really a powerfull solution with many configuration options. I had a few discussions with the maintainer of sloeber (Jantje) and in general i made a few observations that summerize yours: lsee discussions on github
                              The problem for cpp is that you have to declare the prototypes because you lose the confort from the ino suffix.
                              Regards ,
                              Stefan
