  3. [SOLVED] Timers and Interrupts not being triggered
19 Posts 4 Posters 7.3k Views 4 Watching
    Mike Cayouette
    @Yveaux Sorry for the confusion. In my testing I did in fact change the original sketch to use interrupt 1 as I have in my modified sketch and it worked. I did this knowing the radio was going to be connected to 0. I understand your comment about hard coding the interrupt and agree it is not best practice, however, that does not take away from the fact that the sketch did not work when I added the mysensors library in my changes. I believe, even with it hard coded, it should have worked or am I missing something?
    Thank you,
    Mike
      Mike Cayouette
      wrote on last edited by Mike Cayouette
      Just to be clear, below is the exact sketch that I used, i added the digitalPinToInterrupt() to the sketch.
      /*AC Light Control
       Updated by Robert Twomey
       Changed zero-crossing detection to look for RISING edge rather
       than falling.  (originally it was only chopping the negative half
       of the AC wave form).
       Also changed the dim_check() to turn on the Triac, leaving it on
       until the zero_cross_detect() turn's it off.
       Adapted from sketch by Ryan McLaughlin
       http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230333861/30
      #include  <TimerOne.h>          // Avaiable from http://www.arduino.cc/playground/Code/Timer1
      volatile int i=0;               // Variable to use as a counter volatile as it is in an interrupt
      volatile boolean zero_cross=0;  // Boolean to store a "switch" to tell us if we have crossed zero
      int AC_pin = 4;                // Output to Opto Triac
      int interruptPin = 3;
      int dim = 0;                    // Dimming level (0-128)  0 = on, 128 = 0ff
      int inc=1;                      // counting up or down, 1=up, -1=down
      int freqStep = 65;    // This is the delay-per-brightness step in microseconds.
                            // For 60 Hz it should be 65
      // It is calculated based on the frequency of your voltage supply (50Hz or 60Hz)
      // and the number of brightness steps you want.
      // Realize that there are 2 zerocrossing per cycle. This means
      // zero crossing happens at 120Hz for a 60Hz supply or 100Hz for a 50Hz supply.
      // To calculate freqStep divide the length of one full half-wave of the power
      // cycle (in microseconds) by the number of brightness steps.
      // (120 Hz=8333uS) / 128 brightness steps = 65 uS / brightness step
      // (100Hz=10000uS) / 128 steps = 75uS/step
      void setup() {                                      // Begin setup
        pinMode(AC_pin, OUTPUT);                          // Set the Triac pin as output
        attachInterrupt(digitalPinToInterrupt(interruptPin), zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
        Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
        Timer1.attachInterrupt(dim_check, freqStep);
        // Use the TimerOne Library to attach an interrupt
        // to the function we use to check to see if it is
        // the right time to fire the triac.  This function
        // will now run every freqStep in microseconds.
      void zero_cross_detect() {
        zero_cross = true;               // set the boolean to true to tell our dimming function that a zero cross has occured
        i=0;
        digitalWrite(AC_pin, LOW);       // turn off TRIAC (and AC)
      // Turn on the TRIAC at the appropriate time
      void dim_check() {
        if(zero_cross == true) {
          if(i>=dim) {
            digitalWrite(AC_pin, HIGH); // turn on light
            i=0;  // reset time step counter
            zero_cross = false; //reset zero cross detection
          else {
            i++; // increment time step counter
        dim+=inc;
        if((dim>=128) || (dim<=0))
          inc*=-1;
        delay(18);
      The above sketch works as intended. When I add the mysensors library to the sketch, as I did below, the triac never gets triggered.
      /*AC Light Control
      #define MY_NODE_ID 300
      #define SN "ACDimmer"
      #define SV "1.0"
      #define AC1_ID 1
      MyMessage dimmerMsg(AC1_ID, V_DIMMER);
        // Register the LED Dimmable Light with the gateway
        present( AC1_ID, S_DIMMER );
        sendSketchInfo(SN, SV);
        i=0;
      void dim_check() {
          if(i>=dim) {
          else {
        dim+=inc;
          inc*=-1;
        delay(18);
      What would be preventing the interrupt from triggering?
      Thank you,
      Mike
      • M Mike Cayouette
        /*AC Light Control
          i=0;
        void dim_check() {
            if(i>=dim) {
            else {
          dim+=inc;
            inc*=-1;
          delay(18);
        /*AC Light Control
        #define SV "1.0"
        #define AC1_ID 1
          i=0;
        void dim_check() {
            if(i>=dim) {
            else {
          dim+=inc;
            inc*=-1;
          delay(18);
        Thank you,
        Mike
        @Mike-Cayouette then I guess dim_check never gets called. Can you check if the timer works as expected?
          Mike Cayouette
          @Yveaux How can I get Serial.println to work? I'm using the new 2.0 library and I have a few Serail.println() command in various places, including in void setup(), but I am not getting any output on the serial monitor except for all the debug data.
          Sketch with serial output:
          /*AC Light Control
          #define SV "1.0"
          #define AC1_ID 1
            Serial.println("Dim Sketch started");
            Serial.println("Zero Cross");
            i=0;
          void dim_check() {
            Serial.println("Dim Check");
              if(i>=dim) {
              else {
            Serial.print("Dim value: ");
            Serial.println(String(dim));
            dim+=inc;
              inc*=-1;
            delay(18);
          • M Mike Cayouette
            /*AC Light Control
            #define SV "1.0"
            #define AC1_ID 1
              i=0;
            void dim_check() {
                if(i>=dim) {
                else {
              dim+=inc;
                inc*=-1;
              delay(18);
            @Mike-Cayouette if you don't have MY_DEBUG defined you should call Serial.begin() with the Baudelaire yourself.
              Mike Cayouette
              @Yveaux There is something wrong with the Serial print command. I have the most basic of sketches below but I see none on the Serial.println() output, but I get all the debug output.
              #define SV "1.0"
              int AC1_ID = 1;
                Serial.println("Loop");
              what am I doing wrong?
              Mike
              TheoLT 1 Reply Last reply
              • M Mike Cayouette
                #define SV "1.0"
                int AC1_ID = 1;
                Mike
                TheoLT
                TheoLT
                TheoL
                @Mike-Cayouette Maybe this helps
                  Serial.begin( 115200 );
                • TheoLT TheoL
                  Mike Cayouette
                  @TheoL I tried that also but I thought that was not needed if MY_DEBUG was defined. In any case, event with Serial.begin( 115200 ) it still does not work.
                  I did notice the following 2 errors in the debug output, one after the other.
                  TSP:CHKUPL:FAIL (hops=255)
                  !TSM:UPL:FAIL
                  but I see my sensor registered on my MQTT server.
                  Thank you,
                  Mike
                  TheoLT YveauxY 2 Replies Last reply
                  • M Mike Cayouette
                    !TSM:UPL:FAIL
                    Thank you,
                    Mike
                    TheoLT
                    TheoLT
                    TheoL
                    @Mike-Cayouette I think you won't be getting any serial output from the println's because the node cannot get a handshake with the gateway. But I'm still not familiar with the new debug output.
                    • M Mike Cayouette
                      !TSM:UPL:FAIL
                      Thank you,
                      Mike
                      @Mike-Cayouette try putting the code suggested by @theol in the before() method instead of in setup()
                      • YveauxY Yveaux
                        Mike Cayouette
                        @Yveaux There is still something odd happening. This is now my basic sketch
                        //#define MY_NODE_ID 300
                        #define SV "1.0"
                        unsigned long previousMillis = 0;
                        unsigned long currentMillis = 0;
                        int AC1_ID = 1;
                        int SET_DELAY = 300;
                        void before() {
                         if (currentMillis - previousMillis > SET_DELAY) {
                            send( dimmerMsg.set("Message From Dimmer") );
                            previousMillis = millis();
                            currentMillis = millis();
                        I get the output that is in the before() method, but what I have in the loop is not output at all. Its as if loop is not running at all.
                        Mike
                        • M Mike Cayouette
                          #define SV "1.0"
                          int AC1_ID = 1;
                          void before() {
                          Mike
                          @Mike-Cayouette that's because the mysensors stack doesn't start (e.g radio fails to initialize, or parent can not be found)
                          That is probably also causing setup() not to be called and your timer not being registered!
                          • YveauxY Yveaux
                            Mike Cayouette
                            @Yveaux I find it hard to believe that the radio is not initialized. My MQTT server receives the following when I have the node running:
                            mymqtt-out/44/255/3/0/24
                            I modified the sketch and add the following receive method
                              Serial.print("Message: ");
                              Serial.println(message.type);
                              Serial.print("Message Data: ");
                              Serial.println(message.data);
                            when I send a payload of 50 to mymqtt-in/44/1/1/0/3, the serial output shows the following:
                            Dim Sketch started
                            Message: 3
                            Message Data: 50
                            I would think if the radio is not initialized this would not be possible.
                            My debug output is below:
                            Dim Sketch started
                            TSM:INIT
                            TSM:RADIO:OK
                            TSP:ASSIGNID:OK (ID=44)
                            TSM:FPAR
                            TSP:MSG:SEND 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                            TSP:MSG:READ 0-0-44 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            TSP:MSG:PAR OK (ID=0, dist=1)
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=44)
                            TSM:UPL
                            TSP:PING:SEND (dest=0)
                            TSP:MSG:SEND 44-44-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            I remember in the past when the radio would not initialize it said radio init failed or something like that.
                            Thank you,
                            Mike
                              Mike Cayouette
                              @Yveaux I solved the problem.
                              The issue was not my sketch, but rather my ESP8266 MQTT Gateway. I was using an older development version. After upgrading to version 2.0 everything started working. Thankfully my older nodes, using the older development version, are still working, I will upgrade them over time.
                              This is my final sketch:
                              #define SV "1.0"
                              #define AC1_ID 1
                              #define FADE_DELAY 18      // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                              int intPin = 3;
                              unsigned long previousMillis = 0;        // will store last time LED was updated
                              int currentLevel =  0;
                              int requestedLevel = 0;
                              void before() {
                                #ifdef MY_DEBUG
                                Serial.println("Dimmer Node Starting");
                                attachInterrupt(digitalPinToInterrupt(intPin), zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
                                i=0;
                              void dim_check() {
                                  if(i>=currentLevel) {
                                  else {
                                #ifdef MY_DEBUG
                                if (message.type == 3) {
                                  int requestedLevel = map(atoi( message.data ), 0, 100, 128, 0); //128 = off | 0 = ON
                                  while (currentLevel != requestedLevel) {
                                    if(currentLevel<=requestedLevel) inc=1;
                                    if(currentLevel>=requestedLevel) inc=-1;
                                    currentLevel+=inc;
                                    #ifdef MY_DEBUG
                                    Serial.print("Current Level:");
                                    Serial.println(String(currentLevel));
                                    //delay
                                    currentMillis = previousMillis = millis();
                                    while (currentMillis - previousMillis < FADE_DELAY) {
                              There is still one error though. When I try to set my own node id using #define MY_NODE_ID 300, I get the following error:
                              In file included from /home/sketchbook/libraries/MySensors/MySensors.h:253:0,
                                               from /home/sketchbook/ACDimmer_Test/ACDimmer_Test.ino:11:
                              /home/sketchbook/libraries/MySensors/core/MyTransport.cpp: In function 'void stInitTransition()':
                              /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:74:16: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                                   _nc.nodeId = MY_NODE_ID;
                              In file included from /home/sketchbook/libraries/MySensors/core/MyHwATMega328.cpp:22:0,
                                               from /home/sketchbook/libraries/MySensors/MySensors.h:69,
                              /home/sketchbook/libraries/MySensors/core/MyHwATMega328.h:69:88: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                                #define hwWriteConfig(__pos, __value) (eeprom_update_byte((uint8_t*)(__pos), (__value)))
                              /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:76:5: note: in expansion of macro 'hwWriteConfig'
                                   hwWriteConfig(EEPROM_NODE_ID_ADDRESS, MY_NODE_ID);
                              I was able to set my own node id's in the older development version but it does not seem to work now.
                              Thank you for all your help.
                              Mike
                              • M Mike Cayouette
                                #define SV "1.0"
                                #define AC1_ID 1
                                int intPin = 3;
                                void before() {
                                  #ifdef MY_DEBUG
                                  i=0;
                                void dim_check() {
                                    else {
                                  #ifdef MY_DEBUG
                                      currentLevel+=inc;
                                      #ifdef MY_DEBUG
                                      //delay
                                Mike
                                @Mike-Cayouette node id needs to be in the range of 1..254.
                                • M Mike Cayouette
                                  Dim Sketch started
                                  Message: 3
                                  Message Data: 50
                                  Dim Sketch started
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:UPL
                                  !TSM:UPL:FAIL
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  Thank you,
                                  Mike
                                  @Mike-Cayouette well, suggesting the radio fails was just one of the many possible failures as I indicated.
                                  Great to hear you finally nailed it!
                                    Mike Cayouette
                                    @mfalkvidd Node id's work now.
                                    Thank you everyone for your help.
                                    Mike
