  3. [SOLVED] Timers and Interrupts not being triggered
19 Posts 4 Posters 7.3k Views 4 Watching
    Mike Cayouette
    wrote on last edited by Mike Cayouette
    @Yveaux There is something wrong with the Serial print command. I have the most basic of sketches below but I see none on the Serial.println() output, but I get all the debug output.
    #define SN "ACDimmer"
    #define SV "1.0"
    int AC1_ID = 1;
    MyMessage dimmerMsg(AC1_ID, V_DIMMER);
    void setup() {                                        // Begin setup
      Serial.println("Dim Sketch started");
      // Register the LED Dimmable Light with the gateway
      present( AC1_ID, S_DIMMER );
      sendSketchInfo(SN, SV);
      Serial.println("Loop");
    what am I doing wrong?
    Mike
    TheoLT 1 Reply Last reply
    • M Mike Cayouette
      #define SV "1.0"
      int AC1_ID = 1;
      Mike
      TheoLT
      TheoLT
      TheoL
      @Mike-Cayouette Maybe this helps
        Serial.begin( 115200 );
      • TheoLT TheoL
        Mike Cayouette
        @TheoL I tried that also but I thought that was not needed if MY_DEBUG was defined. In any case, event with Serial.begin( 115200 ) it still does not work.
        I did notice the following 2 errors in the debug output, one after the other.
        TSP:CHKUPL:FAIL (hops=255)
        !TSM:UPL:FAIL
        but I see my sensor registered on my MQTT server.
        Thank you,
        Mike
        TheoLT YveauxY 2 Replies Last reply
        • M Mike Cayouette
          !TSM:UPL:FAIL
          Thank you,
          Mike
          TheoLT
          TheoLT
          TheoL
          @Mike-Cayouette I think you won't be getting any serial output from the println's because the node cannot get a handshake with the gateway. But I'm still not familiar with the new debug output.
          • M Mike Cayouette
            !TSM:UPL:FAIL
            Thank you,
            Mike
            @Mike-Cayouette try putting the code suggested by @theol in the before() method instead of in setup()
            • YveauxY Yveaux
              Mike Cayouette
              @Yveaux There is still something odd happening. This is now my basic sketch
              //#define MY_NODE_ID 300
              #define SV "1.0"
              unsigned long previousMillis = 0;
              unsigned long currentMillis = 0;
              int AC1_ID = 1;
              int SET_DELAY = 300;
              void before() {
               if (currentMillis - previousMillis > SET_DELAY) {
                  send( dimmerMsg.set("Message From Dimmer") );
                  previousMillis = millis();
                  currentMillis = millis();
              I get the output that is in the before() method, but what I have in the loop is not output at all. Its as if loop is not running at all.
              Mike
              • M Mike Cayouette
                #define SV "1.0"
                int AC1_ID = 1;
                void before() {
                Mike
                @Mike-Cayouette that's because the mysensors stack doesn't start (e.g radio fails to initialize, or parent can not be found)
                That is probably also causing setup() not to be called and your timer not being registered!
                • YveauxY Yveaux
                  Mike Cayouette
                  @Yveaux I find it hard to believe that the radio is not initialized. My MQTT server receives the following when I have the node running:
                  mymqtt-out/44/255/3/0/24
                  I modified the sketch and add the following receive method
                    Serial.print("Message: ");
                    Serial.println(message.type);
                    Serial.print("Message Data: ");
                    Serial.println(message.data);
                  when I send a payload of 50 to mymqtt-in/44/1/1/0/3, the serial output shows the following:
                  Dim Sketch started
                  Message: 3
                  Message Data: 50
                  I would think if the radio is not initialized this would not be possible.
                  My debug output is below:
                  Dim Sketch started
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=44)
                  TSM:FPAR
                  TSP:MSG:SEND 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSP:MSG:READ 0-0-44 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=44)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 44-44-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  !TSM:UPL:FAIL
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  I remember in the past when the radio would not initialize it said radio init failed or something like that.
                  Thank you,
                  Mike
                    Mike Cayouette
                    @Yveaux I solved the problem.
                    The issue was not my sketch, but rather my ESP8266 MQTT Gateway. I was using an older development version. After upgrading to version 2.0 everything started working. Thankfully my older nodes, using the older development version, are still working, I will upgrade them over time.
                    This is my final sketch:
                    #define SV "1.0"
                    #define AC1_ID 1
                    #define FADE_DELAY 18      // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                    #include <TimerOne.h>
                    volatile int i=0;               // Variable to use as a counter volatile as it is in an interrupt
                    volatile boolean zero_cross=0;  // Boolean to store a "switch" to tell us if we have crossed zero
                    int AC_pin = 4;                // Output to Opto Triac
                    int intPin = 3;
                    int dim = 0;                    // Dimming level (0-128)  0 = on, 128 = 0ff
                    int inc=1;                      // counting up or down, 1=up, -1=down
                    int freqStep = 65;    // This is the delay-per-brightness step in microseconds.
                    unsigned long previousMillis = 0;        // will store last time LED was updated
                    int currentLevel =  0;
                    int requestedLevel = 0;
                    void before() {
                      #ifdef MY_DEBUG
                      Serial.println("Dimmer Node Starting");
                      pinMode(AC_pin, OUTPUT);                          // Set the Triac pin as output
                      attachInterrupt(digitalPinToInterrupt(intPin), zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
                      Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
                      Timer1.attachInterrupt(dim_check, freqStep);
                    void zero_cross_detect() {
                      zero_cross = true;               // set the boolean to true to tell our dimming function that a zero cross has occured
                      i=0;
                      digitalWrite(AC_pin, LOW);       // turn off TRIAC (and AC)
                    // Turn on the TRIAC at the appropriate time
                    void dim_check() {
                      if(zero_cross == true) {
                        if(i>=currentLevel) {
                          digitalWrite(AC_pin, HIGH); // turn on light
                          i=0;  // reset time step counter
                          zero_cross = false; //reset zero cross detection
                        else {
                          i++; // increment time step counter
                      #ifdef MY_DEBUG
                      if (message.type == 3) {
                        int requestedLevel = map(atoi( message.data ), 0, 100, 128, 0); //128 = off | 0 = ON
                        while (currentLevel != requestedLevel) {
                          if(currentLevel<=requestedLevel) inc=1;
                          if(currentLevel>=requestedLevel) inc=-1;
                          currentLevel+=inc;
                          #ifdef MY_DEBUG
                          Serial.print("Current Level:");
                          Serial.println(String(currentLevel));
                          //delay
                          currentMillis = previousMillis = millis();
                          while (currentMillis - previousMillis < FADE_DELAY) {
                    There is still one error though. When I try to set my own node id using #define MY_NODE_ID 300, I get the following error:
                    In file included from /home/sketchbook/libraries/MySensors/MySensors.h:253:0,
                                     from /home/sketchbook/ACDimmer_Test/ACDimmer_Test.ino:11:
                    /home/sketchbook/libraries/MySensors/core/MyTransport.cpp: In function 'void stInitTransition()':
                    /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:74:16: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                         _nc.nodeId = MY_NODE_ID;
                    In file included from /home/sketchbook/libraries/MySensors/core/MyHwATMega328.cpp:22:0,
                                     from /home/sketchbook/libraries/MySensors/MySensors.h:69,
                    /home/sketchbook/libraries/MySensors/core/MyHwATMega328.h:69:88: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                      #define hwWriteConfig(__pos, __value) (eeprom_update_byte((uint8_t*)(__pos), (__value)))
                    /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:76:5: note: in expansion of macro 'hwWriteConfig'
                         hwWriteConfig(EEPROM_NODE_ID_ADDRESS, MY_NODE_ID);
                    I was able to set my own node id's in the older development version but it does not seem to work now.
                    Thank you for all your help.
                    Mike
                    • M Mike Cayouette
                      #define SV "1.0"
                      #define AC1_ID 1
                      int intPin = 3;
                      void before() {
                        #ifdef MY_DEBUG
                        i=0;
                      void dim_check() {
                          else {
                        #ifdef MY_DEBUG
                            currentLevel+=inc;
                            #ifdef MY_DEBUG
                            //delay
                      Mike
                      @Mike-Cayouette node id needs to be in the range of 1..254.
                      • M Mike Cayouette
                        Dim Sketch started
                        Message: 3
                        Message Data: 50
                        Dim Sketch started
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:UPL
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        Thank you,
                        Mike
                        @Mike-Cayouette well, suggesting the radio fails was just one of the many possible failures as I indicated.
                        Great to hear you finally nailed it!
                          Mike Cayouette
                          @mfalkvidd Node id's work now.
                          Thank you everyone for your help.
                          Mike
