  3. New scketch for water level + control valves
9 Posts 3 Posters 3.3k Views 2 Watching
  • NaitsirhcN Offline
    NaitsirhcN Offline
    Naitsirhc
    wrote on last edited by TheoL
    As the title already mentioned, I would like to build a sensor which will measure the waterlevel and send it to my gateway. If the waterlevel is sufficient, my gateway has to send the signal to open the valve and start the pump.
    I would like to use a combination of 2 scripts (Relay and distance sensor)
    I have tested the sketch, but it only returns a distance when I press a button in Domoticz.
    The sketch I've used:
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #include <NewPing.h>
    #define CHILD_ID 1
    #define TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 radio;
    // Message signing driver (none default)
    //MySigningNone signer;
    // Select AtMega328 hardware profile
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        gw.present(CHILD_ID, S_DISTANCE);
        boolean metric = gw.getConfig().isMetric;
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          gw.send(msg.set(dist));
          lastDist = dist;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
      gw.sleep(SLEEP_TIME);
    Please could you help me, to combine the sketches and help me with my learnig curve ;-)
    T S 2 Replies Last reply
    • NaitsirhcN Naitsirhc
      #define CHILD_ID 1
      MyHwATMega328 hw;
      int lastDist;
            lastDist = dist;
      T Offline
      T Offline
      TheoL
      Hello @Naitsirhc,
      I've put the correct tags around your sketch. I'm currently @work so I'm not able to have a in depth look at your sketch.
        #define CHILD_ID 1
        MyHwATMega328 hw;
        int lastDist;
              lastDist = dist;
        @Naitsirhc Hi!
        Have a look at https://forum.mysensors.org/topic/4651/my-basement-flooding-alarm/. This is exactly what @GertSanders posted some days ago. There is a .ino file with code attached at the bottom of the post.
        The problem with your code might be that you only send values when it has changed. So if the value is the same all the time (no flood) it will not send any new value.
        Also check serial log to see that its not 0 or any other error value all the time coming from distance sensor.
        Another tip might be adding a wait(50); after or before reading the distance and see if that makes any difference.
          NaitsirhcN Offline
          Naitsirhc
          Thank You all,
          I will try the sketch (and try to understand it....LOL)
          I need only need to measure the water level once or twice a day. So I will figure it out how it has to be done.
          Thanks again
            NaitsirhcN Offline
            Naitsirhc
            Hi back again,
            Tried to upload the sketch. unfortunatly the copiler returns an error:
            'sendSketchInfo' was not declared in this scope
            Googled for an answer. And found an solution, for installing a new library.
            I installed:
            MySensors 2.0.0
            Mysensors_development
            But it doesn't work.
            Can you help me please
              NaitsirhcN Offline
              Naitsirhc
              Did a check with my other sketches a adapted the basement fooding alarm sketch:
                Ultrasonic Sensor - based on a MySensors example (actuator)
                modified 30 august 2016
                version 1.2
                by Gert Sanders
                Uses 2.0.0-dev version of the library
              //#define MY_DEBUG_VERBOSE
              //#define MY_NODE_ID 123
              #define MY_NODE_ID 32
              // possible values: RF24_PA_LOW (is default on gateway), RF24_PA_MED, RF24_PA_HIGH, RF24_PA_MAX (is default on nodes)
              #define MY_RF24_CHANNEL     80  // just my choice
              #define MY_RF24_DATARATE      RF24_250KBPS
              // defines for sensors
              #define PUMP          1
              #define WATERLEVEL    2
              //#define MY_REPEATER_FEATURE
              // All includes
              // Pin definitions and other defines
              #define TRIGGER_PIN  5  // Arduino pin tied to trigger pin on the ultrasonic sensor.
              #define ECHO_PIN     6  // Arduino pin tied to echo pin on the ultrasonic sensor.
              #define RELAYPIN     7
              //#define LEDPIN       8
              #define PumpOFFLimit    2
              #define PumpONLimit     12
              #define MAX_DISTANCE 255 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
              #define NUMBEROFSAMPLES 100
              // constants
              // variables
              boolean  PumpStatus = false;
              boolean  oldPumpStatus = false;
              unsigned int uS = 0;
              byte Distance = 0;
              byte LastMeasuredDistance = 0;
              byte MaxMeasuredDistance = 0;
              // Instantiate objects
              NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
              MyMessage PumpMsg(PUMP, V_LIGHT);
              MyMessage DistanceMsg(WATERLEVEL, V_DISTANCE);
                 gw.begin();
                gw.sendSketchInfo("BasementAlarmUltrasonic", "1.1");
                gw.wait(500); // delay needed by Raspi/domotics
                gw.present(PUMP, S_LIGHT);
                gw.present(WATERLEVEL, S_DISTANCE);
              // supporting functions.
              //void blipled()
              //  digitalWrite(LEDPIN, !PumpStatus);   // turn the LED on (HIGH is the voltage level)
              //  wait(50);              // wait for a bit
              //  digitalWrite(LEDPIN, PumpStatus);    // turn the LED off by making the voltage HIGH
              //  wait(150);              // wait for a bit
              void receive(const MyMessage & message)
              #ifdef MY_DEBUG
                Serial.print(F("Incoming change for sensor:"));
                if (message.type == V_LIGHT)
                  oldPumpStatus = PumpStatus;
                  PumpStatus = message.getBool();
                  digitalWrite(RELAYPIN, PumpStatus ? HIGH : LOW);
                  saveState(PUMP, PumpStatus);
              #ifdef MY_DEBUG
                  Serial.print(F("Changing PUMP status to : "));
                  Serial.println(PumpStatus);
              // the setup function runs once when you press reset or power the board
                PumpStatus = false;
                // initialize digital LEDpin as an output.
              //  pinMode(LEDPIN, OUTPUT);
                //digitalWrite(LEDPIN, HIGH);    // turn the LED on by making the voltage HIGH
                // initialize digital Pumppin as an output.
                pinMode(RELAYPIN, OUTPUT);
                digitalWrite(RELAYPIN, LOW);    // turn the LED off by making the voltage LOW
                PumpStatus = loadState(PUMP);
                digitalWrite(RELAYPIN, PumpStatus);
                send(PumpMsg.set(PumpStatus == true ? 1 : 0));
                wait(500);
                MaxMeasuredDistance = loadState(WATERLEVEL);
              //  digitalWrite(LEDPIN, LOW);                   // turn the LED off by making the voltage LOW
              // the loop function runs over and over again forever
                blipled();
                uS = sonar.ping_median(NUMBEROFSAMPLES); // Send ping, get ping time in microseconds (uS).
                Distance = uS / US_ROUNDTRIP_CM;
                if (Distance >= MaxMeasuredDistance)
                  MaxMeasuredDistance = Distance;
                  if (Distance >= loadState(WATERLEVEL))
                    saveState(WATERLEVEL, Distance);
                if (Distance != LastMeasuredDistance)
                  if (send(DistanceMsg.set((MaxMeasuredDistance - Distance), 0)))
                    LastMeasuredDistance = Distance;
                    wait(500);
              #ifdef MY_DEBUG
                Serial.print(Distance); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                Serial.print("cm");
                Serial.print("    Max: ");
                Serial.print(MaxMeasuredDistance); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                Serial.println("cm");
                if ((MaxMeasuredDistance - Distance) >= PumpONLimit)
                  SetPumpOn();
                if ((MaxMeasuredDistance - Distance) <= PumpOFFLimit)
                  SetPumpOff();
                if (oldPumpStatus != PumpStatus)
                  if (send(PumpMsg.set(PumpStatus == true ? 1 : 0)))
              void SetPumpOn()
                digitalWrite(RELAYPIN, HIGH);
                PumpStatus = true;
              void SetPumpOff()
                PumpStatus = false;
              I turned of the LED pin (I don't need it)
              The compiler does his job till the last line:
              which returns:
              exit status 1
              'saveState' was not declared in this scope
              What can I do to make this error disappear
              Thanks in advance
                  version 1.2
                  by Gert Sanders
                #define PUMP          1
                // All includes
                #define RELAYPIN     7
                //#define LEDPIN       8
                // constants
                // variables
                byte Distance = 0;
                   gw.begin();
                //void blipled()
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                  PumpStatus = false;
                  wait(500);
                  blipled();
                      wait(500);
                #ifdef MY_DEBUG
                  Serial.print("cm");
                    SetPumpOn();
                    SetPumpOff();
                void SetPumpOn()
                  PumpStatus = true;
                void SetPumpOff()
                  PumpStatus = false;
                which returns:
                exit status 1
                Thanks in advance
                T Offline
                T Offline
                TheoL
                @Naitsirhc Your running MySensors 1.5 ??? try:
                  gw.saveState(WATERLEVEL, Distance);
                  NaitsirhcN Offline
                  Naitsirhc
                  wrote on last edited by Naitsirhc
                  Hi
                  First of all, thanks for all the answers.
                  Started from skratch again. Downloaded the new arduino IDE.Some Libraries (NewPing and Mysensors) and finaly the sketch compiled :-D
                  I uploaded it to the Nano and then expected to see something on the serial monitor....
                  Too bad...Oh right. removed slashes for MyDebug and MyDebug_Verbose...
                  Presto.
                  Unfortunatly I see in serial monitor:
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=32)
                  TSM:FPAR
                  TSP:MSG:SEND 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  Too bad. What have I done wrong? Is it possible to see the distance in serial monitor and to see if a relay turned on or off?
                  EDIT:
                  Upgraded my Gateway also to 2.0
                  Stil no succes :-(
                  Output from Gateway:
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  0;255;0;0;18;2.0.0
                  0;255;3;0;11;GateWay
                  0;255;3;0;12;1.0
                  0;255;3;0;9;TSP:SANCHK:OK
                    NaitsirhcN Offline
                    Naitsirhc
                    update:
                    Adapted the old distance sensor sketch to the 2.0 library and upladed it and connected to my PC. Also connected the gateway 2.0 to raspberry (Domoticz).....
                    Allright it works....I do get distance in my serial monitor and in domoticz.
                    Now try to upload the basement alarm sketch...See what happens...
