  3. How To - Doorbell Automation Hack
106 Posts 29 Posters 128.8k Views 26 Watching
  • rnollenR rnollen
    I have installed the doorbell sketch on my testboard. This just to see how it should be working. First sensor with a relay for me basically :)
    But I have a question. I have use the sketch, I have two devices coming up in Domiticz, a security sensor and a light switch. But basically I don't get the function of these buttons?
    I think the security sensor responds on the doorbell press?
    Also I think the other button is to activate the physical doorbell which could switch the relay? But I would expect that the security switch button in Domoticz could also activate the relay remotely, but this is not the case? Because, I don't see an option to switch the relay remotely in Domoticz?
    So it is working; but any help is appreciated if somebody could explain the functionallity for me and if this is the expected behavior :)
    drock1985
    wrote on last edited by drock1985
    #77
    @rnollen
    I know when I was playing with Domoticz the Doorbell sketch would show up as a security light and a light for me. The security light I changed to a motion sensor in Domoticz (click edit on your dashboard/switches tab). After that when I pressed the doorbell button, the motion sensor would switch on to show the button was pressed, then immediately back off. Although for it to turn off automatically, I may have had to tell domoticz to do that after xx seconds, can't remember for sure now.
    And yes you are correct, the second switch is a 'mute' for the doorbell. If off, the doorbell won't sound (switch the relay).
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • pjblinkP
      pjblinkP
      pjblink
      Hi guys,
      I'm nearly there, but need a little help if anyone can!
      For my setup I've got a diode bridge followed immediately by a buck converter, so the doorbell's 18v AC comes down to 8v DC. My plan was to run the doorbell AND the arduino off this same supply, but I'm guessing now that it may not be possible. The reason for this was down to there only being 2 wires to the doorbell. The doorbell works fine off 8v DC and so does the arduino. The issue however is when i both power the arduino and the doorbell at the same time of the same supply. The relay opens and then the arduino resets. No chime.
      What should I do? Wiring layout is exactly the same as above but the 8v DC loops through the relay to the doorbell as well as going to VIN/GND on the Arduino Nano.
      I can't have the arduino at the power supply end as I need the doorbell button connections, so I'm hoping someone might have some ideas around splitting out the power supplies at the doorbell end? Or smoothing it or something like that.
      Power is red/yellow from the wall. Doorbell button is yellow/yellow from the wall. brown/brown is soldered/heat shrunk to red/red within the housing. NRF is on headers, so it's lifted out in this photo.
      Patrick
      crodgersC 1 Reply Last reply
      • pjblinkP
        pjblinkP
        pjblink
        Or can i just get away with a better power supply for the both? Essentially I've got a pulse-detecting mysensors node, a doorbell node and a doorbell itself running off a cheap-ass ebay chinese full-bridge rectifier and step-down converter (120v AC > 8v DC). The doorbell takes 8v DC so I'm using that as the common voltage.
        • pjblinkP pjblink
          Hi guys,
          Patrick
          crodgersC
          crodgersC
          crodgers
          @pjblink - what are the components you have built in there? I see the Arduino Nano and a relay - are they all attached to a board? Is there a radio in there, too? I clicked on the (old) link above for Mini RBoard, but I get a gateway error when going to the page to purchase...
          • pjblinkP
            pjblinkP
            pjblink
            Hi crodgers,
            So yeh, there's a nano on headers, relay, nrf on headers and 3 wire terminals - 1 for the doorbell button, 1 for the bell itself and another for the DC IN. Everything is soldered to a prototyping board which has now been trimmed down to fit in the doorbell housing.
            Patrick
            • pjblinkP
              pjblinkP
              pjblink
              wrote on last edited by pjblink
              #82
              Working without the doorbell load attached:
              mysensors enabled doorbell working without load
              Failing when I attach the load:
              mysensors enabled doorbell failing with load
              • pjblinkP
                pjblinkP
                pjblink
                I've just tried it with both 1000uF and then a 4700uF cap across VIN/GND on the arduino with only slightly better results. It'll ring, but the relay stays open most of the time and the arduino needs resetting to release it :(
                • pjblinkP pjblink
                  sundberg84S
                  sundberg84S
                  @pjblink - late into the discussion, but have you tried changing to another power supply or another regulator? It might that its to unstable for your node... atleast temporary to rule things out.
                  pjblinkP 1 Reply Last reply
                  • sundberg84S sundberg84
                    pjblinkP
                    pjblinkP
                    pjblink
                    @sundberg84 That was definitely on the cards...but it looks like I might have got it working. I did 4 things in one go, which is unlike me, so now I have to break things down to see which one helped (if it wasn't all)...1st thing was a 4700uF cap over the arduino VIN/GND, 2nd was a 1000uF cap over the relay +- 5v,… 3rd was to reflow a few of the GND solders and finally I dropped the voltage regulator from 8v to just under 7v...and hey presto...
                    https://youtu.be/jj8wo7NME6U
                    • pjblinkP pjblink
                      sundberg84S
                      sundberg84S
                      @pjblink - a bad ground connection has been a pain for me alot of times... good you got it working.
                      • pjblinkP
                        pjblinkP
                        pjblink
                        So it kept failing after 2 or 3 rings...frustrating! I enabled all the debug and noticed it kept failing just before sending out the "off" message. It didn't reset, just stalled. This was the case even when powered by USB. And then I remembered how sensitive the NRFs are to fluctuations in power and I hadn't got round to putting a cap on there yet!!! I put a spare 1000uF (47uF are on order) and so far it hasnt caused me any further issues! So now I've got 3 huge capacitors on there, and it looks ok...touch wood.
                        • pjblinkP
                          pjblinkP
                          pjblink
                          It still looks to be having issues :( looks like the arduino will hang just before sending the command to untrip.
                            A Former User
                            Great how-to for a beginner. But now I'm stuck because of my lack of knowledge to rebuild the sketch for MySensors 2.0. Does anyone already rebuild it and willing to share?
                            • dbemowskD
                              dbemowskD
                              #90
                              How are you powering the relay? Are you trying to run it directly from an arduino data line? If so, that could be your problem. I am currently working on a motion sensor light with a PIR, LDR, and a relay. Now the relay I am using is a 12 volt relay, but the concept would be the same for a 5 volt relay. The idea is to use a transistor to trigger the relay from a separate power source. I used an 2N3904 NPN transistor to switch the the negative side of the power to the relay. You simply connect the emitter to your ground, the collector to the negative side of your relay and the base goes to your arduino data pin. You may need to add a pull-down resistor on the transistor base to ground depending on your situation. In my case it worked fine without it. Also, you should still of course put your flyback diode across your relay coil to prevent voltage spikes.
                              The above assumes that you are using a relay on it's own and not a relay module like the ones you find on ebay. The relay modules already have the transistor and diode already built in, and some even use an optocoupler for added isolation.
                                A Former User
                                My test situation is Nano+Radio with double relay module and push button for the bell. Relay is powered by the 5V by Arduino, and i have tested this with the example sketch (+modification for double relay) and everything was working fine. The issue i am having is the original sketch (1 bell + 1 relay) is made for mysensors 1.x, and i am running 2.x and have no idea how te rewrite this.
                                mrwombleM 1 Reply Last reply
                                • ? A Former User
                                  mrwombleM
                                  mrwombleM
                                  mrwomble
                                  @Samster here's the link to converting code to 2.0:
                                  https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                                  I followed this recently (different sketch) and it works just fine as long as you take your time and make sure you do each step properly. Post back on how you get on, if you're still stuck I might be able to give a hand next week but I'm pretty new at this myself.
                                  ? 1 Reply Last reply
                                  • mrwombleM mrwomble
                                    A Former User
                                    wrote on last edited by [[global:former-user]]
                                    #93
                                    @mrwomble Thank you, that's very helpfull, i will start puzzling around and share the result.
                                    • T
                                      timropp
                                      Ok, finally worked this again today. Here's the status. I modified the sketch to update it to 2.0, giving me this:
                                       * Version 1.0 - PeteWill
                                       * Version 2.0 - timropp, updating for MySensors 2.0
                                       * This sketch is used to control a doorbell ring with a relay as well as send an
                                       * alert when the buttons is pressed.  Connect the button to ground and digital
                                       * pin 3.  The relay controlling the doorbell is conntected to pin 4.
                                       * Watch the How To video here: https://youtu.be/nMIcalwpstc
                                      #define MY_REPEATER_FEATURE
                                      #define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
                                      #define DOORBELL_PIN A0      // Arduino Digital I/O pin number for the doorbell button
                                      #define RELAY_PIN  4         // Arduino Digital I/O pin number for the relay
                                      #define DOORBELL_CHILD_ID 0  //ID of the doorbell
                                      #define SWITCH_CHILD_ID 1    // Id of the switch that will control doorbell sound
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      Bounce debouncer = Bounce();
                                      MyMessage switchMsg(SWITCH_CHILD_ID, V_LIGHT);
                                      MyMessage doorbellMsg(DOORBELL_CHILD_ID, V_TRIPPED);
                                      unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
                                      unsigned int ringTime = 400; //How long the doorbell relay is on (in milliseconds)
                                      unsigned long doorbellMillis;  //Used to keep track of the last doorbell button press
                                      unsigned long doorbellTimer;  //Used to keep track of doorbell ring time
                                      byte doorbellPreviousVal;  //Used to keep track of doorbell button pressed state
                                      boolean ringDoorbell;  //Used to initiate the ring doorbell if statement
                                      boolean doorbellSound; //Used to keep track if the doorbell should sound or be silent.  Value recieved from doorbell on/off switch
                                      boolean doorbellOff = true;  //Used to keep track of doorbell ring state
                                        // Setup the button and activate internal pull-up
                                        pinMode(DOORBELL_PIN, INPUT_PULLUP);
                                        debouncer.attach(DOORBELL_PIN);
                                        debouncer.interval(5);
                                        pinMode(RELAY_PIN, OUTPUT);
                                        // Set doorbellSound to last known state (using eeprom storage)
                                        doorbellSound = loadState(SWITCH_CHILD_ID);
                                        //Check to see if doorbell button was pushed.
                                        if (currentMillis - doorbellMillis > doorbellDelay) //used to stop doorbell from being pressed too frequently
                                          debouncer.update();
                                          // Read doorbell button value
                                          byte doorbellDetect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
                                          if (doorbellDetect != doorbellPreviousVal)
                                            //Serial.print("doorbellDetect Value: ");
                                            //Serial.println(doorbellDetect);
                                            send(doorbellMsg.set(doorbellDetect));
                                            if (doorbellDetect == 1)
                                              ringDoorbell = true;
                                              doorbellTimer = currentMillis;
                                            doorbellMillis = currentMillis;
                                            doorbellPreviousVal = doorbellDetect;
                                        if (ringDoorbell)
                                          if (doorbellSound)
                                            if (doorbellOff)
                                              digitalWrite(RELAY_PIN, RELAY_ON);
                                              //Serial.println("Doorbell sounded.");
                                              doorbellOff = false;
                                              if (currentMillis - doorbellTimer > ringTime)
                                                ringDoorbell = false;
                                                //Serial.println("Doorbell off.");
                                                doorbellOff = true;
                                          if (message.isAck()) {
                                            // Change relay state
                                            doorbellSound = message.getBool();
                                            // Store state in eeprom
                                            saveState(SWITCH_CHILD_ID, doorbellSound);
                                        sendSketchInfo("Doorbell Monitor", "1.0");
                                        present(SWITCH_CHILD_ID, S_LIGHT);
                                        present(DOORBELL_CHILD_ID, S_MOTION);
                                      Sitting on my desk, it works fine. It appears in Home Assistant, clicks the relay when A0 is shorted to ground, and that appears in HASS as a motion event. Seems good, so I installed it in the doorbell. Doesn't work there. I get one ring when I hook up power, and then nothing. I checked again the leads from the physical doorbell button with a multimeter - I get a good continuity buzz when I press the button and silence when not pressed. Then I discovered something - if I physically unhook the wire going to A0 and reconnect it, the doorbell rings and I get that notification in Hass. If I unhook and reconnect the wire again, same thing. So that makes it appear that the A0 is being constantly grounded - is that possible? It acts like my physical doorbell button is stuck in the pressed position, but the multimeter indicates it's fine.
                                      Further testing - If I connect the board to the doorbell system but leave the physical doorbell button disconnected, then attach a spare piece of wire to A0 and ground it, the system works perfectly. So it's definitely something related to the physical button.
                                      On thing I've realized - I THINK the outdoor button is an illuminated one, which isn't illuminated with this system. Could that light be the cause? If so, why doesn't the continuity test show it as continuous? I think I'll go buy a basic non-illuminated button and install it and see if that works. Or just pull the button out of the wall, disconnect the wires, and then short them together. Duh, that'd be easier and cheaper. I'll try that this afternoon - have a wedding to get to first.
                                      VeraEdge UI7 with Mysensors ethernet gateway
                                      dbemowskD 1 Reply Last reply
                                      • T timropp
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                            debouncer.update();
                                          if (ringDoorbell)
                                            if (doorbellSound)
                                              if (doorbellOff)
                                                  doorbellOff = true;
                                        dbemowskD
                                        dbemowskD
                                        #95
                                        The button is probably illuminated with LEDs and a resistor (depending how old it is). This could complete the circuit to the digital input on the arduino making it look like the button is pressed. It is probably not seen on a continuity test when the button is not pressed because the resistance is enough where you don't have full continuity. See if reversing the wires into the arduino A0 and ground gets it working. If the doorbell is illuminated with an LED and a resistor that should reverse the current flow of the LED/resistor into A0 on the arduino in effect preventing that problem.
                                        • T
                                          timropp
                                          wrote on last edited by timropp
                                          #96
                                          It's definitely the illuminated button. I pulled it out and connecting the wires rings the bell correctly. I hadn't thought about swapping the wires... It is pretty new but I wasn't considering the possibility of it being led. I'll give that a try. Worst case, replace it with a non lit button. Just glad to have finally figured it out!
                                          edit: actually, I'm betting it's not a LED. These buttons are typically on a 16VAC system, so a LED wouldn't work without more components. Whereas a simple incandescent bulb works fine on AC. So I think I probably just need a new button.
