  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 139.1k Views 27 Watching
  • M Mariusz
    I am new in mysensors and arduino however I already use domoticz with mysensors and rflink.
    Everything is working fine however now I plan to renovate my house and I would like to put wire connection using max485 and arduino. Problem is that it is now working :( I have tried 1.5.4 version and also development branch. It seems that signal is not getting to gateway. I nothing see on arduino gateway except of initalization gateway. I have started to use two nano but I also tried combination nano and mega without success. I would be very appreciate if someone who done it could more describe how to make that it works.
    I tried https://arduino-info.wikispaces.com/SoftwareSerialRS485Example and it works fine.
    I use for nano combination pins 2 (de/re), 8 (ro),9(di)
    radekzmR
    radekzmR
    radekzm
    @Mariusz jak jesteś Polakiem ? Jeżeli tak to mogę Ci pomóc po polsku będzie łatwiej :)
    m26872M 1 Reply Last reply
    • radekzmR radekzm
      m26872M
      m26872M
      m26872
      @radekzm Please use private chat/PM if you don't intend everyone to read it.
      • radekzmR
        radekzmR
        radekzm
        wrote on last edited by radekzm
        #90
        @m26872
        I'm sorry and promises to improve :)
        @Mariusz
        In my case the solution was in MyConfig.h file (in my case C:\Program Files (x86)\Arduino\libraries\MySensors):
        1. Disable function MY_DISABLED_SERIAL
          commenting lines 49
          // #define MY_DISABLED_SERIAL
        2. Disable function MY_DEBUG
          commenting lines 36
        3. Correct connection is on my pictures enclosed in the above comment
        Board | Transmit | Receive | PWM Unusable
        Arduino Uno | 9 | 8 | 10 <----- Form https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html .... (& other ATMEGA328)
        Arduino Leonardo | 5 | 13 | (none)
        Arduino Mega | 46 | 48 | 44, 45
        DE and RE -> Pin 2
        RO -> Pin 8
        DI -> Pin 9
        1. To check the hardware and connections run the "Example Program" from https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
        2. Use development branch
        • L LeoDesigner
          Hi everyone !
          I needed a wired solution for my several nodes.
          Here is the serial rs485/rs232 wired network transport for mysensors.
          https://github.com/leodesigner/mysensors-serial-transport
          It is based on the Majenko ICSC serial library.
          Can you please test it? It is a beta version - but it is working for me.
          (However, I am still waiting for my rs485 boards to arrive)
          You can find more technical information at
          http://sourceforge.net/p/arduino-icsc/wiki/RS-485/
          To use it, you have to:
          1. Put SerialTransport.cpp and SerialTransport.h to folder/directory/path SerialTransport in your library.
          2. Add #include <SerialTransport.h> to your .ino sketch
          3. Replace transport class with:
            MyTransportSerial transport(Serial,0,-1); // serial port, node, dePin (-1 disabled)
          Please let me know about bugs and how it is working for you.
          skatunS
          skatunS
          skatun
          @LeoDesigner
          Hi, I am trying to do almost the same, but I would like to use softwareSerial instead of altsoft. The reason why I would do this is that i can barely fit the arduino nano inside my case, and an additional rs485 module would not fit and that I have 8 nodes connected on the softwareserial . I have tested software serial on arduino and it seems to work fine up to 15meters, I also adjusted the baudrate to 9600 since my node does not send out/receive large amount of data. I read that you did some work on software serial and were wondering if you could take a look at this thread.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            Is there any how-to's on this transport class as far as the hardware goes? How does it work with multiple nodes? Is it like a ring pattern? or do all the nodes have to have a dedicated connection to the gateway.
            Home Automation Tinkerer
            www.CrankyCoder.net
            Gateway: MQTTClientGateway
            MySensors: 2.3
            • tbowmoT
              tbowmoT
              tbowmo
              Depends on your physical transport layer. I would say a multidrop link where everything is in parallel..
              • H
                H
                hausinger
                Is it possible, to built a esp8266 wifi gateway and communicate GW to node with rs485?
                In altsoft esp8266 is not decleared, so i can't use it out of the box.
                Btw: I tested my_rs485 with nano as GW and Pro Mini as node, and it worked great. Thank you :)
                  @hausinger I don't think so. I haven't heard of anyone trying. I guess you'd have to replace alt-soft-serial with something else.
                    #96
                    @hausinger if you know about coding..
                    • plain C lib for esp8266, it can be adapted to work with Arduino Esp: https://github.com/plieningerweb/esp8266-software-uart
                    • or use stock arduino esp8266 software serial lib (https://github.com/plerup/espsoftwareserial), and inspire yourself from lib above, and code your CE pin management..
                    • BartB
                      BartB
                      Bart
                      Any reason why this lib is not using Serial1 or Serial2 on Arduino Mega 2560 instead of AltSoftSerial?
                        @Bartek-Celary
                        No, not really. Just that not many that uses 2560.
                        • BartB
                          BartB
                          Bart
                          wrote on last edited by Bart
                          #99
                          How about adding the following define to use the Serial1/2 on Mega. I have not tested yet but assuming the AltSoftSerial lib has the same interface/functionality it should work.
                          #define MY_RS485_SERIAL Serial1
                          diff --git a/core/MyTransportRS485.cpp b/core/MyTransportRS485.cpp
                          index 814f721..ea35c9e 100644
                          --- a/core/MyTransportRS485.cpp
                          +++ b/core/MyTransportRS485.cpp
                          @@ -92,7 +92,11 @@ unsigned char _recSender;
                           unsigned char _recCS;
                           unsigned char _recCalcCS;
                          +#if defined(MY_RS485_SERIAL)
                          +HardwareSerial& _dev = MY_RS485_SERIAL;
                          +#else
                           AltSoftSerial _dev;
                          +#endif
                           unsigned char _nodeId;
                            Looks like a neat solution. If it verifies ok, please create a pull request agains the development branch.
                            • lanL
                              lanL
                              lan
                              I understand that the RS485 is a separate gateway to communicate. Is it also possible to have the wireless gateway and RS485 gateway combined?
                                Currently, no..
                                lanL 1 Reply Last reply
                                  Currently, no..
                                  lanL
                                  lanL
                                  lan
                                  @hek Thanks for the quick response. I'm looking for some direction (this might not be the right forum).
                                  I want to create a node to control my Itho Ecofan ventilation box. I now have a working program (thanks to the help of Rogier Reedijk The nodo now uses a CC1101 transceiver to control the box and thus uses the SPI bus. I'm looking for some direction to use this transmitter as part of my sensor network so I can control it from my Domoticz. Hope you can give me some directions how to proceed.
                                    Why do you need to hook it up to RS485 wired network? Can't you just forwards commands to the CC11001 from any radio node or the gateway?
                                    • lanL
                                      lanL
                                      lan
                                      Is it then possible to use the two radio's on one node and share the SPI bus?
                                        Yes, if the CC11001 behaves correctly.
                                        • lanL
                                          lanL
                                          lan
                                          Thanks, will try that
