  2. Feature Requests
  3. New internal message types
Scheduled Pinned Locked Moved Feature Requests
5 Posts 4 Posters 3.1k Views 4 Watching
  • chrilleC Offline
    chrilleC Offline
    chrille
    Since it's now possible to have sensors on the gateway and there seems to be a slight shift towards using more advanced hardware (Raspberry Pi, ESP8266, ARM based) I think it would be great to have some additional internal message types to report various internal data from both gateway and sensor nodes. So far I considered the following types
    I_WIFI_RSSI - signal strenght from wifi network (dBm)
    I_RADIO_RSSI - signal strengh from radio (dBm)
    I_MEMORY - free memory (bytes)
    I_UPTIME - uptime (seconds)
    I_CPULOAD - CPU load (%)
    I_VCC - supply voltage (volt)
    • Jan
    • H Offline
      H Offline
      Maybe you can add this to a new issue on github, things tends to be lost when posted on the forum.
      chrilleC 1 Reply Last reply
      • H hek
        chrilleC Offline
        chrilleC Offline
        chrille
        @hek Issue #581 created
        • cimba007C Offline
          cimba007C Offline
          cimba007
          Just for the sake of linking the issue:
          https://github.com/mysensors/MySensors/issues/581
          • C Offline
            C Offline
            chaeron
            Adding I_BATTERY_VOLTAGE to complement the existing I_BATTERY_LEVEL, along with a convenience function to send the voltage would be a real nice to have!
            12.2k
