  2. Announcements
    wrote on last edited by hek
    This thread contains comments for the article "Building a Raspberry Pi Gateway" posted on MySensors.org.
      shabba
      Does this page imply that RFM69 and Rasp Pi as a gateway/controller is possible?! :-)
        @marceloaqno has been working on a PR for RPI/Linux.
        https://github.com/mysensors/MySensors/pull/537
        It hasn't been merged into development yet.
        • Jean-Chris Ô-ôJ
          Jean-Chris Ô-ôJ
          Jean-Chris Ô-ô
          Or NRF24L01+ and Rasp PI also as gateway/controller possible ???
            Yes, NRF24L01+ will also be supported.
            • Patrik SöderströmP
              Patrik SöderströmP
              Patrik Söderström
              When do you think the install and build instructions will come up? :) Will this work with a B-model? (bought 2013)
                I'm not sure, @marceloaqno will finish the page when he feels the configuration options is stable enough.
                • breimannB
                  breimannB
                  breimann
                  Yes, can I use my Rasp Pi as a GW/Controller all in one? I have setup Domoticz on my Rasp Pi so could i do this and add an NRF??
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    RFM69 will work on RPi.
                    @marceloaqno PR works fine more me on my RPi3 so it will work on RPi2 or below, but this is still beta and has not been merged into development branch yet.
                    yes, it is possible to have 3-in-1 (nrf24l01+ RPi and Domoticz or any other combination).
                    • frenchoF
                      frenchoF
                      frencho
                      I just saw that the PR537 was merged
                      @marceloaqno great job, do you now plan to write some build instructions ? I've had a look at the file, but I don't want to mess it all up
                      Your second life begins when you understand you only have one !
                      • frenchoF frencho
                        marceloaqno
                        Code Contributor
                        @frencho I hope to write something this weekend, at least a draft.
                        GertSandersG frenchoF 2 Replies Last reply
                        • M marceloaqno
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @marceloaqno
                          looking forward to upgrading my gateway to v2 :-)
                          • M marceloaqno
                            frenchoF
                            frenchoF
                            frencho
                            @marceloaqno just wondering because I could figure it out looking at your code : does it work with nrf24 And rfm69 or just nrf24?!
                            Regardless of your answer you did a great job, that awesome thanks
                            • frenchoF frencho
                              marceloaqno
                              Code Contributor
                              wrote on last edited by marceloaqno
                              @frencho thanks. Sorry no support for rfm69 yet. I order some rfm69 modules from ebay to play with but they haven't arrived. So I'm waiting to finish some tests.
                              H 1 Reply Last reply
                              • M marceloaqno
                                H
                                H
                                hawk_2050
                                @marceloaqno I second @frencho's comment, excellent job on getting mainline support for the Raspberry Pi into the MySensors codebase. Thank you for your efforts.
                                • jerseyguy1996J
                                  jerseyguy1996J
                                  jerseyguy1996
                                  Hello, I just installed @marceloaqno wonderful port of the mySensors 2.0 to the raspberry pi MyGatewaySerial. Thank you very much for that! I'm very glad to be using my boards that connect my radio directly to my Raspi! The installation went very smoothly.
                                  I am having an issue with a few of my messages from my sensor node. My sensor node sends 6 messages. 3 are V-STATUS, 1 is V-TEMP, 1 is V-VAR1, and one is the battery voltage level. The V-TEMP and the 3 V-STATUS messages go through perfectly but the V-VAR1 and the Battery voltage are not reaching the Raspi. This is the output of the node:
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSP:ASSIGNID:OK (ID=3)
                                  TSM:FPAR
                                  TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                  TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  TSP:MSG:PAR OK (ID=0, dist=1)
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:CHKID:OK (ID=3)
                                  TSM:UPL
                                  TSP:PING:SEND (dest=0)
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                  TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  TSP:MSG:PONG RECV (hops=1)
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                  TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=ok:Sensor Node
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                  TSP:MSG:SEND 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                  TSP:MSG:SEND 3-3-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                  TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                  TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                  TSP:MSG:SEND 3-3-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                  Request registration...
                                  TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                  TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  Node registration=1
                                  Init complete, id=3, parent=0, distance=1, registration=1
                                    Data = 0 0 0 0 0 0 0 0 0 0  CRC=0
                                    Temperature = 0.00 Celsius, 32.00 Fahrenheit
                                  TSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:32.00
                                  !TSP:MSG:SEND 3-3-0-0 s=2,c=1,t=24,pt=3,l=2,sg=0,ft=0,st=fail:0
                                  TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,ft=1,st=ok:1
                                  TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
                                  TSP:MSG:SEND 3-3-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=ok:1
                                  !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=fail:44
                                  No SensorTSP:MSG:SEND 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:0.00
                                  !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=fail:60
                                  Notice the failed messages on the "s=2" and "s=255" lines.
                                  This is what the Raspi receives:
                                  mysGateway: TSF:MSG:BC
                                  mysGateway: TSF:MSG:FPAR REQ,ID=3
                                  mysGateway: TSF:PNG:SEND,TO=0
                                  mysGateway: TSF:CKU:OK
                                  mysGateway: TSF:MSG:GWL OK
                                  mysGateway: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  mysGateway: TSF:MSG:PINGED,ID=3,HP=1
                                  mysGateway: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  mysGateway: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=11,pt=0,l=11,sg=0:Sensor Node
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                  mysGateway: TSF:MSG:READ,3-3-0,s=1,c=0,t=6,pt=0,l=0,sg=0:
                                  mysGateway: TSF:MSG:READ,3-3-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
                                  mysGateway: TSF:MSG:READ,3-3-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                                  mysGateway: TSF:MSG:READ,3-3-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
                                  mysGateway: TSF:MSG:READ,3-3-0,s=5,c=0,t=3,pt=0,l=0,sg=0:
                                  mysGateway: TSF:MSG:READ,3-3-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                  mysGateway: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  mysGateway: TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:32.00
                                  mysGateway: TSF:MSG:READ,3-3-0,s=3,c=1,t=2,pt=1,l=1,sg=0:1
                                  mysGateway: TSF:MSG:READ,3-3-0,s=4,c=1,t=2,pt=1,l=1,sg=0:1
                                  mysGateway: TSF:MSG:READ,3-3-0,s=5,c=1,t=2,pt=1,l=1,sg=0:1
                                  mysGateway: TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:0.00
                                  This is the code running on the sensor node:
                                  #define MY_NODE_ID 3
                                  #define MY_RF24_CE_PIN 9
                                  #include <prescaler.h>
                                  #include <OneWire.h>
                                  #define SKETCH_NAME "Sensor Node"
                                  #define SKETCH_MAJOR_VER "1"
                                  #define SKETCH_MINOR_VER "0"
                                  #define TEMPERATURE_SENSOR 1
                                  #define STATUS 2
                                  #define HIGH_SWITCH 3
                                  #define FILL_SWITCH 4
                                  #define LOW_SWITCH 5
                                  const byte EN = 17; //turns on the boost converter to get 3.3v
                                  const byte PER = 14; //peripherals (DS18B20, nRF24L01)
                                  const byte High_sw = 5;
                                  const byte Fill_sw = 6;
                                  const byte Low_sw = 7;
                                  const byte Wake_pin = 2;  //wake from sleep mode powerdown
                                  OneWire  ds(9);  // on pin 10 (a 4.7K resistor is necessary)
                                  unsigned int node_status = 0;
                                  MyMessage msg(TEMPERATURE_SENSOR, V_TEMP);
                                  MyMessage msg2(STATUS, V_VAR1);
                                  MyMessage msg3(HIGH_SWITCH, V_STATUS);
                                  MyMessage msg4(FILL_SWITCH, V_STATUS);
                                  MyMessage msg5(LOW_SWITCH, V_STATUS);
                                  void before(){
                                    pinMode(EN,OUTPUT);
                                    digitalWrite(EN,LOW);  //give us 3.3v
                                    pinMode(PER, OUTPUT);   //for turning on peripherals
                                    digitalWrite(PER,LOW);  //peripherals on - P Chan FET
                                    digitalWrite (Wake_pin, HIGH);  //will wake with falling edge
                                    present(TEMPERATURE_SENSOR, S_TEMP);
                                    present(STATUS, S_TEMP);
                                    present(HIGH_SWITCH, S_BINARY);
                                    present(FILL_SWITCH, S_BINARY);
                                    present(LOW_SWITCH, S_BINARY);
                                        send(msg.set(get_temperature(),2));
                                        send(msg2.set(node_status));
                                        send(msg3.set(switch_status(High_sw)));
                                        send(msg4.set(switch_status(Fill_sw)));
                                        send(msg5.set(switch_status(Low_sw)));
                                        sendBatteryLevel(get_battery());
                                        //this worked when I was using the SerialGateway on the Raspi but
                                        //isn't working using the MySerialGateway (mysgateway)
                                        if(isTransportOK()){
                                          sleep(30000);  // transport is OK, node can sleep
                                        else {
                                          Serial.println("Fixing Transport Layer");
                                          node_status+=1;
                                          wait(5000); // transport is not operational, allow the transport layer to fix this
                                        //sleep(60000);  //interrupt on pin 2
                                  bool switch_status(int digitalPin){
                                    bool stat = 1;
                                    pinMode(digitalPin,INPUT);
                                    digitalWrite(digitalPin,HIGH);  //enable pullup
                                    sleep(5); //not sure if we need to wait for the line to settle
                                    stat = digitalRead(digitalPin);
                                    digitalWrite(digitalPin,LOW);  //save power when off
                                    return stat;
                                  float get_temperature(){
                                    byte i;
                                    byte ds_present = 0;
                                    byte type_s = 0;
                                    byte data[12];
                                    byte addr[8];
                                    float celsius, fahrenheit;
                                    if (!ds.reset())
                                      Serial.print("No Sensor");
                                      return (0);
                                    ds.skip();
                                    ds.write(0x44, 1);        // start conversion, with parasite power on at the end
                                    sleep(1000);     // maybe 750ms is enough, maybe not
                                    // we might do a ds.depower() here, but the reset will take care of it.
                                    ds_present = ds.reset();
                                    ds.skip();
                                    ds.write(0xBE);         // Read Scratchpad
                                    Serial.print("  Data = ");
                                    Serial.print(ds_present, HEX);
                                    Serial.print(" ");
                                    for ( i = 0; i < 9; i++) {           // we need 9 bytes
                                      data[i] = ds.read();
                                      Serial.print(data[i], HEX);
                                      Serial.print(" ");
                                    Serial.print(" CRC=");
                                    Serial.print(OneWire::crc8(data, 8), HEX);
                                    Serial.println();
                                    // Convert the data to actual temperature
                                    // because the result is a 16 bit signed integer, it should
                                    // be stored to an "int16_t" type, which is always 16 bits
                                    // even when compiled on a 32 bit processor.
                                    int16_t raw = (data[1] << 8) | data[0];
                                    if (type_s) {
                                      raw = raw << 3; // 9 bit resolution default
                                      if (data[7] == 0x10) {
                                        // "count remain" gives full 12 bit resolution
                                        raw = (raw & 0xFFF0) + 12 - data[6];
                                      byte cfg = (data[4] & 0x60);
                                      // at lower res, the low bits are undefined, so let's zero them
                                      if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
                                      else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
                                      else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
                                      //// default is 12 bit resolution, 750 ms conversion time
                                    celsius = (float)raw / 16.0;
                                    fahrenheit = celsius * 1.8 + 32.0;
                                    Serial.print("  Temperature = ");
                                    Serial.print(celsius);
                                    Serial.print(" Celsius, ");
                                    Serial.print(fahrenheit);
                                    Serial.println(" Fahrenheit");
                                    return(fahrenheit);
                                  //battery empty at .8v so 1.5 - .8 = .7
                                  //(465-battery)/248
                                  //.0032226562
                                  float get_battery(){
                                    unsigned int battery = analogRead(A1);
                                    //float volts = 3.3/1024.0*(float)battery;
                                    float percent = (217.0-(465.0-(float)battery))/217.0;
                                    return(max(0,min(100,(percent * 100))));
                                  Can you see anything that may be causing my issue?
                                  • A
                                    annegerben
                                    I've connected the radio using gpio pinnumbers to my rpi using this schema:
                                    but when I run it gives the following errors:
                                    what did I do wrong?
                                    mysGateway: Starting gateway...
                                    mysGateway: Protocol version - 2.0.1-beta
                                    mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                                    mysGateway: TSF:LRT:OK
                                    mysGateway: TSM:INIT
                                    mysGateway: !TSM:INIT:TSP FAIL
                                    mysGateway: TSM:FAIL:CNT=1
                                    mysGateway: TSM:FAIL:PDT
                                    mysGateway: TSM:FAIL:RE-INIT
                                    mysGateway: TSM:FAIL:CNT=2
                                    mysGateway: TSM:FAIL:CNT=3
                                    mysGateway: TSM:FAIL:CNT=4
                                    mysGateway: TSM:FAIL:CNT=5
                                    mysGateway: TSM:FAIL:CNT=6
                                    mysGateway: TSM:FAIL:CNT=7
                                    make output:
                                    pi@raspberrypi:~/MySensors$ make
                                    Makefile:12: Makefile.inc: Bestand of map bestaat niet
                                    [Running configure]
                                    [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=0010.
                                    [OK] init system detected: systemd
                                    [OK] Finished.
                                    cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                                    cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/piHiPri.o drivers/RPi/piHiPri.c
                                    cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/bcm2835.o drivers/RPi/bcm2835.c
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/rpi_util.o drivers/RPi/rpi_util.cpp
                                    g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -D__RPI_BPLUS -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/SPI.o drivers/RPi/SPI.cpp
                                    g++ -pthread  -o examples_linux/mysGateway drivers/Linux/log.o drivers/Linux/noniso.o drivers/Linux/EthernetClient.o drivers/Linux/SerialPort.o drivers/Linux/Stream.o drivers/Linux/Print.o drivers/Linux/IPAddress.o drivers/Linux/compatibility.o drivers/Linux/EthernetServer.o examples_linux/mysGateway.o drivers/RPi/piHiPri.o drivers/RPi/bcm2835.o drivers/RPi/rpi_util.o drivers/RPi/SPI.o
                                      marceloaqno
                                      Code Contributor
                                      @hawk_2050 same for you guys who helped, thank you for all the feedback.
                                      @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
                                      @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
                                      A M 2 Replies Last reply
                                      • M marceloaqno
                                        annegerben
                                        @marceloaqno thanks for the updated in the guide, I've now successfully connected the radio to the RPI.
                                        • E
                                          E
                                          ericvdb
                                          Would it be possible to connect a I2C display to display some information, and drive that display from within mysGatway.cpp ?
