  3. [SOLVED] ESP8266 MQTT with RM69HW
20 Posts 5 Posters 6.3k Views 3 Watching
  • YveauxY Yveaux
    @Meshx86 said:
    still the RADIO shows OK even if it is unplugged, is verifying RFM69 running functions working ok ?
    No, it's not implemented: https://github.com/mysensors/MySensors/blob/development/core/MyTransportRFM69.cpp#L60
    Also, you're referring to the nRF24 wiring instructions, which say to leave the IRQ unconnected, but apparently you figured that out yourself.
    Meshx86M
    Meshx86M
    Meshx86
    @Yveaux i referred to nRF24 wiring since there isn't any reference wiring for ESP8266<->RFM69
    • Meshx86M Meshx86
      @mfalkvidd am talking about this:
      bool transportInit() {
      	// Start up the radio library (_address will be set later by the MySensors library)
      	if (_radio.initialize(MY_RFM69_FREQUENCY, _address, MY_RFM69_NETWORKID)) {
      i believe the _address will be equal to the node ID (which either statically defined or obtained from controller),i am wondering with GW address is always 0 how the Radio will operate since valid "RFM69 Addresses" range is 1-254
      @Meshx86 I see. Good question. I didn't know that the rfm69 protocol doesn't support address 0.
        rfm and nrf works the same in Mysensors if i remember.
        But let's go back to your problem :)
        So you don't have communication between GW and a node with Mysensors?
        I think your node or GW does not receive ACK. It can be power issue (but you're saying it's ok), or it could be bad defines for CS or especially IRQ pin as RFM69 rely on this pin.
        I have a working nodemcu with rfm69hw, mqtt too ;) maybe not exactly same pin mapping with wemos.
        I hope this helps.
        • mfalkviddM
          If nrf and rfm work the same, then id 0 is possible. My nrf gateway has id 0 and it works fine.
          Meshx86M 1 Reply Last reply
            Meshx86M
            Meshx86M
            Meshx86
            yea my bad, i just tried ID 0 in the RFM69 library Gateway-Node example and it worked, still can't understand the logic behind it since i know logical AND is done on the addresses but nvm..
            I am trying to get the Gateway Example of Original RFM69 (by Felix) to run on Wemos D1 Mini but i gets WDT reset, am trying to build up the gateway step by step to narrow down the problem.
            any idea if any modifications were done to the original RFM69 library to run on ESP8266 chips ?
            • korttomaK
              korttomaK
              korttoma
              I tested a ESP8266 GW with an RFM69 radio today an I finally managed to get it to work when I reasigned the radio IRQ pin to GPIO4 on the ESP.
              • Tomas
              • korttomaK korttoma
                Meshx86M
                Meshx86M
                Meshx86
                @korttoma isn't GPIO4 = D2 ?
                • Meshx86M Meshx86
                  Meshx86M
                  Meshx86M
                  Meshx86
                  @Meshx86 damn, i just connected it to D3 on Wemos D1 mini and it started working ..
                  • korttomaK
                    korttomaK
                    korttoma
                    I am using an ESP-07 so your device is probably different, nice that you got it working.
                    • Tomas
                    • Meshx86M
                      Meshx86M
                      Meshx86
                      cheers, The D1 mini is a mini wifi board based on ESP-8266EX according to their website.
                      still the whole thing is flakey, sometimes it got stuck and won't reset (even from onboard reset button) until i disconnect all the wires, are i only connect the RFM69 pins specified in here should other on used pins be grounded ?
                      • korttomaK
                        korttomaK
                        korttoma
                        Hi @Meshx86 ,
                        I realized that I also have some of the WeMoS D1 minis and I tried to create a RFM69 WiFi Gateway with one.
                        I am having the same experience as you and can not seem to get it working reliably.
                        Let me know if you find a working solution and I will do the same if I find a working solution.
                        • Tomas
                          Hi @Meshx86 ,
                          Meshx86M
                          Meshx86M
                          Meshx86
                          wrote on last edited by Meshx86
                          @korttoma
                          on the RFM69 Gateway-Node Example by Felix i managed to get Wemos to talk to Arduino Pro mini by changing IRQ_PIN and IRQ_NUM to 4 both send & receive
                          now on the MySensors example, i can see the gateway (Wemos running MQTT gateway example) receiving the broadcast from the Arduino Pro Mini Node, and it replies to it, but the Arduino isn't receiving anything.
                          I am not sure if it is wiring, or something with the node/gateway code
                          • Meshx86M
                            Meshx86M
                            Meshx86
                            i just remembered i need a controller to distribute ID's for the nodes, i installed MyController.org and it works fine
