  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.2k Views 38 Watching
  • BarnaB
    BarnaB
    Barna
    maybe this
    http://www.ebay.com/itm/2A-DC-DC-Boost-Step-up-Conversion-Module-MicroUSB-2V-24V-to-5V-28V-9V-12V-24V-/321928461470?hash=item4af46e7c9e:g:4mgAAOSwbdpWUq5p
    • BarnaB Barna
      I'm not profi, is my logic correct?
      general, not PBC related
      I could power the mini 5V with 9V and mini's regulator converts it to 5V.
      Mini could give power to radio by 5->3.3 regulator.
      I could measure the voltage without booster, but the booster is good to use the battery until it is possible ?
      sundberg84S
      sundberg84S
      @Barna Your logic is correct - you can power a mini through raw and the minis regulator will convert it to 5v but then you can not use the booster. You will have power as long as the battery is between aprox. 6 and 9 v (minis voltage converter specs), below that it will die.
      • tlpeterT
        tlpeterT
        tlpeter
        I have ordered some boards and i am looking forward to play with them.
        I tried soldering some part and a nano on a soldering board but apparently my soldering skills and patience isn't what it used to be in the past.
        @sundberg84 it looks good.
        • tlpeterT tlpeter
          sundberg84S
          sundberg84S
          @tlpeter thank you and good luck. Just give a shout if you have questions.
          • tlpeterT
            tlpeterT
            tlpeter
            I do have some questions :smiley:
            I think i got it a bit. When i use a 3,3V mini then i do not need the 3,3V regulator and it is powered with a battery. If i use a 5V mini then i need the regulator. Is this correct?
            Do i need the booster if batteries are used?
            How about the RAW option? How does it go to 5V? i need the regulator to go to 3,3V so how do i loose the 6-12V :smiley:
            • tlpeterT tlpeter
              sundberg84S
              sundberg84S
              Correct!! You need to add the jumper to BAT if you go with 3.3 and battery or REG if you go with 5v and voltage regulator.
              No, you can bypass it with a jumper/wire - but it will give you alot of extra. Without the booster the arduino 3.3v will die somewhere between 2.8 and 3 volts, with booster you can go down to 1.9v.
              There is a voltage regulater on board the pro mini that handels from 6-12v (be cautious using 12 v, 9v is max i recommend on clones). This will convert your RAW to 5v and provide the board with this. Then the external regulator will go from 5 to radio 3.3v.
              • tlpeterT
                tlpeterT
                tlpeter
                Ok, very clear.
                So now i have a new question, i want to use a solar panel and a battery but this will go above the 3.7V when there is light and the battery pack is 3.7V so i must use the raw connection.
                I also want to measure the battery and i think this needs PWR :smiley:
                Can i do this?
                I want to build the solar powered mini weather station:
                https://forum.mysensors.org/topic/841/solar-powered-mini-weather-station
                Thanks already.
                • tlpeterT tlpeter
                  Ok, very clear.
                  Can i do this?
                  Thanks already.
                  sundberg84S
                  sundberg84S
                  @tlpeter You can use raw for 3.7V and make it down to 3.3 with the internal voltage regulator onboard the arduino, but you can not connect anything to PWR then because this will allready be 3.3V! The internal voltage regulator vill output 3.3v to the PCB from the arduino.
                  However, I think you can connect the battery directly to the battery measurment on the board as long as you use the same ground for both. You will need to make some new calculations (most are based on 2xAA = 3.0V) for your battery.
                  • tlpeterT
                    tlpeterT
                    tlpeter
                    wrote on last edited by tlpeter
                    #90
                    I didn't use your board in this case (the weather station) but i will do in the future.
                    I did connect the battery to the raw pin and it is working fine.
                    Funny, a solar panel with a battery powering the pro mini with DHT22 and BMP180.
                    For now i will keep it simple but later on i want a rain gauge and windmeter too.
                    Rain sensor is on a different Nano as this needs to be powered all the time.
                    It will control my sunscreen later on.
                    • NiklasON
                      NiklasON
                      NiklasO
                      This board looks great! Definitely going to order some.
                      Just getting started with MySensors. Waiting for over 20 orders from eBay with stuff. Should be fun!
                      Already running Domoticz (Pi 2) with RFXtrx433, 1-wire and z-wave. Going to build a serial gateway for direct connection to the Pi.
                      My last name before I married (now divorced) was Sundberg btw. Could have had Sundberg82 as nickname. ;)
                      • NiklasON NiklasO
                        sundberg84S
                        sundberg84S
                        @NiklasO - Thanks! I hope it will suite you well!
                        The wait is a pain, but well worth it in the end. Sounds like got alof going already!
                        Hehe, we can create a forum group - "sundberg dreamteam!" ;)
                        NiklasON 1 Reply Last reply
                        • Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          Recived my boards today and I love them, I ordered the white ones and they are looking really great
                          Thanks @sundberg84 !
                          MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                          • Martin TellblomM Martin Tellblom
                            sundberg84S
                            sundberg84S
                            @Martin-Tellblom - good luck with your projects!
                            • sundberg84S sundberg84
                              NiklasON
                              NiklasON
                              NiklasO
                              hehe yeah, just need to change my last name back to my original one but I don't know if my kids likes that idea. ;)
                              Where do you get your x to 3.3v boost converter? Found some on eBay but they are quite expensive if comparing to x to 5v versions.
                              • NiklasON NiklasO
                                sundberg84S
                                sundberg84S
                                @NiklasO - they are quite expencive yes, but i order the ones in the mysensors store
                                • ileneken3I
                                  ileneken3I
                                  ileneken3
                                  Has anyone tried one of these boosters:
                                  https://www.aliexpress.com/item/High-current-2A-DC-DC-SX1308-adjustable-boost-module/32751065114.html?ws_ab_test=searchweb0_0,searchweb201602_1_116_10065_117_10068_114_10067_115_10069_113_10017_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10033_10059_10032_10078_10079_10077_10073_10070_421_420_10052_10053_10050_10051,searchweb201603_7&btsid=c5657706-88c2-41fb-bdfe-866e4cffe76a
                                  • They are sometimes much cheaper than the 3.3v ones
                                  • Since they are adjustable, I would think you could optimize the output voltage for maximum battery.
                                  I'm not sure, is there a problem using them with the PCB boards? I imagine the input and output ground would have to be connected together.
                                  • ileneken3I ileneken3
                                    sundberg84S
                                    sundberg84S
                                    @ileneken3 - sorry never tried them.
                                    The footprint looks different from the PCB so you need to connect this with wires to the PCB.
                                    ileneken3I 1 Reply Last reply
                                      ileneken3I
                                      ileneken3I
                                      ileneken3
                                      @sundberg84
                                      I took a chance and tried these boosters. After adjusting the pot to boost to 3.3V, and using wires to connect, they seem to work the same as the "recommended" ones. I am hoping they produce less noise for the radio - I seem to have trouble with that, even with adding the capacitors. (Maybe my radios are not good).
                                      Another experiment - boosting them to just over the 2.8V fuse limit. I would think that would be more energy efficient.
                                      • jumpingJ
                                        jumpingJ
                                        jumping
                                        @ileneken3 in my experienxe the 3.3v booster gives a lot of problem with radio :-)
                                        Raspberrry PI3 - Domoticz
                                        ESP8266 GW - MySensors 2.1.1
                                        • jumpingJ jumping
                                          sundberg84S
                                          sundberg84S
                                          @jumping - correct, if you can make a node without its better for the radio but its easier to do with a booster, radio and a pre-made Arduino pro mini.
                                          jumpingJ ileneken3I 2 Replies Last reply
