  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.2k Views 38 Watching
  • tlpeterT
    tlpeterT
    tlpeter
    Ok, very clear.
    So now i have a new question, i want to use a solar panel and a battery but this will go above the 3.7V when there is light and the battery pack is 3.7V so i must use the raw connection.
    I also want to measure the battery and i think this needs PWR :smiley:
    Can i do this?
    I want to build the solar powered mini weather station:
    https://forum.mysensors.org/topic/841/solar-powered-mini-weather-station
    Thanks already.
    • tlpeterT tlpeter
      Ok, very clear.
      Can i do this?
      Thanks already.
      sundberg84S
      sundberg84S
      @tlpeter You can use raw for 3.7V and make it down to 3.3 with the internal voltage regulator onboard the arduino, but you can not connect anything to PWR then because this will allready be 3.3V! The internal voltage regulator vill output 3.3v to the PCB from the arduino.
      However, I think you can connect the battery directly to the battery measurment on the board as long as you use the same ground for both. You will need to make some new calculations (most are based on 2xAA = 3.0V) for your battery.
      • tlpeterT
        tlpeterT
        tlpeter
        wrote on last edited by tlpeter
        #90
        I didn't use your board in this case (the weather station) but i will do in the future.
        I did connect the battery to the raw pin and it is working fine.
        Funny, a solar panel with a battery powering the pro mini with DHT22 and BMP180.
        For now i will keep it simple but later on i want a rain gauge and windmeter too.
        Rain sensor is on a different Nano as this needs to be powered all the time.
        It will control my sunscreen later on.
        • NiklasON
          NiklasON
          NiklasO
          This board looks great! Definitely going to order some.
          Just getting started with MySensors. Waiting for over 20 orders from eBay with stuff. Should be fun!
          Already running Domoticz (Pi 2) with RFXtrx433, 1-wire and z-wave. Going to build a serial gateway for direct connection to the Pi.
          My last name before I married (now divorced) was Sundberg btw. Could have had Sundberg82 as nickname. ;)
          • NiklasON NiklasO
            sundberg84S
            sundberg84S
            @NiklasO - Thanks! I hope it will suite you well!
            The wait is a pain, but well worth it in the end. Sounds like got alof going already!
            Hehe, we can create a forum group - "sundberg dreamteam!" ;)
            NiklasON 1 Reply Last reply
            • Martin TellblomM
              Martin TellblomM
              Martin Tellblom
              Recived my boards today and I love them, I ordered the white ones and they are looking really great
              Thanks @sundberg84 !
              MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
              • Martin TellblomM Martin Tellblom
                sundberg84S
                sundberg84S
                @Martin-Tellblom - good luck with your projects!
                • sundberg84S sundberg84
                  NiklasON
                  NiklasON
                  NiklasO
                  hehe yeah, just need to change my last name back to my original one but I don't know if my kids likes that idea. ;)
                  Where do you get your x to 3.3v boost converter? Found some on eBay but they are quite expensive if comparing to x to 5v versions.
                  • NiklasON NiklasO
                    sundberg84S
                    sundberg84S
                    @NiklasO - they are quite expencive yes, but i order the ones in the mysensors store
                    • ileneken3I
                      ileneken3I
                      ileneken3
                      Has anyone tried one of these boosters:
                      https://www.aliexpress.com/item/High-current-2A-DC-DC-SX1308-adjustable-boost-module/32751065114.html?ws_ab_test=searchweb0_0,searchweb201602_1_116_10065_117_10068_114_10067_115_10069_113_10017_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10033_10059_10032_10078_10079_10077_10073_10070_421_420_10052_10053_10050_10051,searchweb201603_7&btsid=c5657706-88c2-41fb-bdfe-866e4cffe76a
                      • They are sometimes much cheaper than the 3.3v ones
                      • Since they are adjustable, I would think you could optimize the output voltage for maximum battery.
                      I'm not sure, is there a problem using them with the PCB boards? I imagine the input and output ground would have to be connected together.
                      • ileneken3I ileneken3
                        sundberg84S
                        sundberg84S
                        @ileneken3 - sorry never tried them.
                        The footprint looks different from the PCB so you need to connect this with wires to the PCB.
                        ileneken3I 1 Reply Last reply
                          ileneken3I
                          ileneken3I
                          ileneken3
                          @sundberg84
                          I took a chance and tried these boosters. After adjusting the pot to boost to 3.3V, and using wires to connect, they seem to work the same as the "recommended" ones. I am hoping they produce less noise for the radio - I seem to have trouble with that, even with adding the capacitors. (Maybe my radios are not good).
                          Another experiment - boosting them to just over the 2.8V fuse limit. I would think that would be more energy efficient.
                          • jumpingJ
                            jumpingJ
                            jumping
                            @ileneken3 in my experienxe the 3.3v booster gives a lot of problem with radio :-)
                            Raspberrry PI3 - Domoticz
                            ESP8266 GW - MySensors 2.1.1
                            • jumpingJ jumping
                              sundberg84S
                              sundberg84S
                              @jumping - correct, if you can make a node without its better for the radio but its easier to do with a booster, radio and a pre-made Arduino pro mini.
                              jumpingJ ileneken3I 2 Replies Last reply
                                jumpingJ
                                jumpingJ
                                jumping
                                hi @sundberg84, if you have some free time you can see my post about a "new" PCB
                                https://forum.mysensors.org/topic/5314/pcbs-for-battery-based-sensor :-)
                                  ileneken3I
                                  ileneken3I
                                  ileneken3
                                  @sundberg84
                                  It's definitely easier with a booster - but not cheaper or more reliable. (Why does the booster cost more than the Arduino?)
                                  Everything is about tradeoff's. When you solve one problem, it can easily introduce another. At first, I ignored the whole booster thing. But after a lot of experiments, I ended up with a pile of 1.35 V batteries. So I tried the booster, and ended up with transmission problems (partially solved by capacitors). So then I tried changing the bootloader (1Mhz, no brown out), and it seems to be OK - but I know there will be other problems. Example: I now need to boost to 3.3V for sensors that require it. Also, are there compatibility problems with mysensors?
                                  Even still, thanks for the great board - I've had a lot of fun and learned a lot with it!
                                    @sundberg84
                                    sundberg84S
                                    sundberg84S
                                    #104
                                    @ileneken3 - you are so right, and that is the fun with electronics! There is no right or wrong (more or less)!
                                    Newbie/Easy PCB is what it sounds like and my only aim is to make it as easy as possible. Im happy to evaluate it but at the moment booster and a few non compatible sensors is the price i pay.
                                    I have probably 15 of these PCB with boosters now, and yes - there are times when the booster makes it unreliable but most of the times it works. I have maybe trashed 5 nodes in all which is fair less amount that I had to trash soldering wires. I have also tried bare atmegas in different shapes and even with them there are problems (not including flashing bootloaders and stuff you dont have to do with EasyPCB).
                                    We also needs to remember this is DIY, not factory manufactured which can introduce alof of errors. We learn as we go and I hope EasyPCB can be a great platform for new people like you said. Nice to hear, thank you!
                                      martim
                                      Yesterday I have received Rev 9 of Newbie PCB board. I am a newbie and I purchased this board to make building easier. I have soldered a radio and Arduino Pro Mini 3.3 V to it and the radio module with a 47uF cap. The power is supplied using the FTD232 board. Because the radio module is not powered using the 3.3V of arduino I wired this using a separate wire. I also connected a DTH 11 with the resistor on the board (4K7). I used a test sketch to read the DTH 11 and this is working well.
                                      When I load the MySensors sketch I get a radio failure. I have no Idea what this is? Bad wiring, not correct power?? Anyone can help me started?
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      12 !TSM:INIT:TSP FAIL
                                      14 TSM:FAIL:CNT=1
                                      16 TSM:FAIL:PDT
                                      10018 TSM:FAIL:RE-INIT
                                      10020 TSM:INIT
                                      10027 !TSM:INIT:TSP FAIL
                                      10031 TSM:FAIL:CNT=2
                                      10033 TSM:FAIL:PDT```
                                      Nca78N 1 Reply Last reply
                                      • M martim
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        14 TSM:FAIL:CNT=1
                                        16 TSM:FAIL:PDT
                                        10020 TSM:INIT
                                        wrote on last edited by Nca78
                                        #106
                                        @martim said in Easy/Newbie PCB for MySensors:
                                        Can you show a picture of your setup and give more explanation on this sentence ? This part about connection of the radio smells fishy ;)
                                        It seems the radio cannot be initialized, so I suppose the power supplied to it is not correct, but I'm not sure of what you did.
                                          martim
                                          This is the front part. The connected cable goes to the FTD232 which also is currently the power supply.
                                          0_1486835929737_IMG_3545.JPG !
                                          The red wire on the back plane connects the plus from arduino to the plus for the radio (soldered on the + of cap)
                                          0_1486835943373_IMG_3546.JPG !
                                          Try to zoom in.
