  3. Domoticz as controller **and** a gateway for MySensor nodes running on a Raspberry Pi 2
47 Posts 14 Posters 32.6k Views 16 Watching
  • Tore André RosanderT Tore André Rosander
    Is there any pros/cons for using the nrf directly on the RPi instead of a NodeMCU?
    Right now i use NodeMCU (esp) with nrf radio as gateway, but i want to reduce the nuber of units around my house so connecting directly to the RPi would be better as long as there is no negative sides to it.
    GertSandersG
    GertSandersG
    GertSanders
    @Tore-André-Rosander
    For me there are no downsides. I use the raspberry as both gateway (with the NRF mounted) and as Domoticz controller. It is part of my home network and I can reach my Domoticz from the internet. So far I have 13 sensor nodes running and communicating with the raspberry.
    • rmtuckerR rmtucker
      Anyone got a spare pcb i can purchase in the UK ?
      Seems a waste ordering a batch.
      An SD image would be good too??
      C
      C
      chickey
      @rmtucker I was thinking the same, don't need a whole batch. Anyone got a spare board, happy to pop some cash your way via a paypal gift.
      • GertSandersG
        GertSandersG
        GertSanders
        I distributed my two other boards to friends locally. If you make the boards at OSH Park you get three boards (for a cost of 2.20 USD - shipping included).
        https://oshpark.com/shared_projects/aXLXBO3f
        C 1 Reply Last reply
        • DwaltD
          DwaltD
          Dwalt
          wrote on last edited by Dwalt
          #38
          I have the two spares from my order. If anyone wants one, send me a private chat message with your postal address. I am in the US, so it could take a few extra days to arrive if you are unfortunate enough to live on the wrong side of the pond.
          • GertSandersG GertSanders
            C
            C
            chickey
            @GertSanders Thanks for the heads up. I'd incorrectly assumed that it was going to be something like $10 plus shipping. At $2.20 it's nothing so ordered a few just for testing. Got carried away though and ordered a few 8266 breakout boards too :-)
            Col
            • SeanMarshS
              SeanMarshS
              SeanMarsh
              I"m troubled. I know this will make me sound like a total newbie, but that's ok. From someone that is new to the form, it seems like you magically made the NRF work while it is physically attached to the RPi. I'm not finding any directions on how you made it work. I did find an old link that said that the directions on there will only work with 1.5X or below. Please show me the light.
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Yes. I read too. NRF working directly with mysenosrs 1.5x. 2.0 not supported today.
                • Iraklis KourtisI
                  Iraklis KourtisI
                  Iraklis Kourtis
                  Hi Gert,
                  Nice project! I am new to MySensors and Domoticz. Could you please briefly explain how to add the device to Domoticz. I have successfully done the steps from mfalkvidd's guide, but I am not sure how proceed in Domoticz. Any advise would be appreciated..
                  Best ,
                  IK<
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    If you sensors working ok than you need to go domoticz hardware-> devices. Marked with green arrow is new node. You need to press to green arrow and....... you see what you want.
                    Sorry my english. Maybe you understand. :)
                    • Iraklis KourtisI
                      Iraklis KourtisI
                      Iraklis Kourtis
                      wrote on last edited by Iraklis Kourtis
                      #44
                      Hi Fat Fly,
                      Thank you for your response. Unfortunately, I don't see a green arrow in hardware -> devices. My issue is that I don't understand how to add properly the Gateway. Should I add itas "MySensors Gateway USB"? Screen Shot 2016-09-18 at 19.43.51.png
                      PS: your english are perfect :thumbsup:
                      • bjacobseB
                        bjacobseB
                        bjacobse
                        #45
                        I would in Domoticz use MySensors Gateway USB and point to /dev/ttyMySensorsGateway
                        did you read the last part of the guide? where Mrfalkvidd specifically added a note for Domoticz , the below is taken from the link you are referring to:
                        "Enable the gateway for use with Domoticz
                        Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                        sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                        And change /etc/rc.local from this
                        exit 0
                        to this:
                        exit 0
                        If this still isn't working for you, then make the standard serial gateway, with Arduino nano+NRF24L01+ (And capacitor on Vcc/GND as close to NRF module as possible) - this is for sure working :-)
                        • Iraklis KourtisI
                          Iraklis KourtisI
                          Iraklis Kourtis
                          Thank you bjacobse!
                          It now works like a charm..
                          Best,
                          IK<
                          bjacobseB 1 Reply Last reply
                          • Iraklis KourtisI Iraklis Kourtis
                            Thank you bjacobse!
                            Best,
                            IK<
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @Iraklis-Kourtis
                            Glad that you good it working :-) and also replied that it's working for you :-)
