  3. Domoticz as controller **and** a gateway for MySensor nodes running on a Raspberry Pi 2
47 Posts 14 Posters 32.7k Views 16 Watching
  • Fat FlyF Fat Fly
    What i select from drop down menu? Mysensors gateway USB ?
    GertSandersG
    GertSandersG
    GertSanders
    yes, follow these instructions:
    http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway
    • Tore André RosanderT
      Tore André Rosander
      Is there any pros/cons for using the nrf directly on the RPi instead of a NodeMCU?
      Right now i use NodeMCU (esp) with nrf radio as gateway, but i want to reduce the nuber of units around my house so connecting directly to the RPi would be better as long as there is no negative sides to it.
      • Tore André RosanderT Tore André Rosander
        GertSandersG
        GertSandersG
        GertSanders
        @Tore-André-Rosander
        For me there are no downsides. I use the raspberry as both gateway (with the NRF mounted) and as Domoticz controller. It is part of my home network and I can reach my Domoticz from the internet. So far I have 13 sensor nodes running and communicating with the raspberry.
        • rmtuckerR rmtucker
          Anyone got a spare pcb i can purchase in the UK ?
          Seems a waste ordering a batch.
          An SD image would be good too??
          C
          C
          chickey
          @rmtucker I was thinking the same, don't need a whole batch. Anyone got a spare board, happy to pop some cash your way via a paypal gift.
          • GertSandersG
            GertSandersG
            GertSanders
            I distributed my two other boards to friends locally. If you make the boards at OSH Park you get three boards (for a cost of 2.20 USD - shipping included).
            https://oshpark.com/shared_projects/aXLXBO3f
            C 1 Reply Last reply
            • DwaltD
              DwaltD
              Dwalt
              wrote on last edited by Dwalt
              #38
              I have the two spares from my order. If anyone wants one, send me a private chat message with your postal address. I am in the US, so it could take a few extra days to arrive if you are unfortunate enough to live on the wrong side of the pond.
              • GertSandersG GertSanders
                C
                C
                chickey
                @GertSanders Thanks for the heads up. I'd incorrectly assumed that it was going to be something like $10 plus shipping. At $2.20 it's nothing so ordered a few just for testing. Got carried away though and ordered a few 8266 breakout boards too :-)
                Col
                • SeanMarshS
                  SeanMarshS
                  SeanMarsh
                  I"m troubled. I know this will make me sound like a total newbie, but that's ok. From someone that is new to the form, it seems like you magically made the NRF work while it is physically attached to the RPi. I'm not finding any directions on how you made it work. I did find an old link that said that the directions on there will only work with 1.5X or below. Please show me the light.
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    Yes. I read too. NRF working directly with mysenosrs 1.5x. 2.0 not supported today.
                    • Iraklis KourtisI
                      Iraklis KourtisI
                      Iraklis Kourtis
                      Hi Gert,
                      Nice project! I am new to MySensors and Domoticz. Could you please briefly explain how to add the device to Domoticz. I have successfully done the steps from mfalkvidd's guide, but I am not sure how proceed in Domoticz. Any advise would be appreciated..
                      Best ,
                      IK<
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        If you sensors working ok than you need to go domoticz hardware-> devices. Marked with green arrow is new node. You need to press to green arrow and....... you see what you want.
                        Sorry my english. Maybe you understand. :)
                        • Iraklis KourtisI
                          Iraklis KourtisI
                          Iraklis Kourtis
                          wrote on last edited by Iraklis Kourtis
                          #44
                          Hi Fat Fly,
                          Thank you for your response. Unfortunately, I don't see a green arrow in hardware -> devices. My issue is that I don't understand how to add properly the Gateway. Should I add itas "MySensors Gateway USB"? Screen Shot 2016-09-18 at 19.43.51.png
                          PS: your english are perfect :thumbsup:
                          • bjacobseB
                            bjacobseB
                            bjacobse
                            #45
                            I would in Domoticz use MySensors Gateway USB and point to /dev/ttyMySensorsGateway
                            did you read the last part of the guide? where Mrfalkvidd specifically added a note for Domoticz , the below is taken from the link you are referring to:
                            "Enable the gateway for use with Domoticz
                            Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                            sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                            And change /etc/rc.local from this
                            exit 0
                            to this:
                            exit 0
                            If this still isn't working for you, then make the standard serial gateway, with Arduino nano+NRF24L01+ (And capacitor on Vcc/GND as close to NRF module as possible) - this is for sure working :-)
                            • Iraklis KourtisI
                              Iraklis KourtisI
                              Iraklis Kourtis
                              Thank you bjacobse!
                              It now works like a charm..
                              Best,
                              IK<
                              bjacobseB 1 Reply Last reply
                              • Iraklis KourtisI Iraklis Kourtis
                                Thank you bjacobse!
                                Best,
                                IK<
                                bjacobseB
                                bjacobseB
                                bjacobse
                                @Iraklis-Kourtis
                                Glad that you good it working :-) and also replied that it's working for you :-)
