  3. question about repeater node
10 Posts 4 Posters 4.9k Views 3 Watching
  • R Offline
    R Offline
    Reza
    wrote on last edited by Reza
    hi guys
    i have one question
    if i want all of my nodes be also a repeater node , so i just add this line to all of sensors?
    #define MY_REPEATER_FEATURE
    or also add this : ( for example motion sensor)
    sendSketchInfo("Repeater Node", "1.0");
    • R Reza
      hi guys
      i have one question
      @Reza the sketch info is just a human-friendly name. It does not affect the functionality. So you can put anything you like there.
      R 1 Reply Last reply
        R Offline
        R Offline
        Reza
        hi my friend you speak about this line ?
        can I delete it from sketch ?
        so for convert each sensors and each relay actor to repeater +sensor just enough add this line ?
        • R Reza
          I don't know.
          • tlpeterT Offline
            tlpeterT Offline
            tlpeter
            yes add the line but only on non battery powered nodes.
            If battery powered this will kill battery life.
            I have a couple repeater nodes at home to extend the range.
            • tlpeterT tlpeter
              R Offline
              R Offline
              Reza
              @tlpeter
              hi my friend .thank you
              all of my node are non battery powered and no problem. but just my question about codes.
              just i add this line ? (#define MY_REPEATER_FEATURE) and dont need any change in sketch?for example delete this line :
              sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME); ???
              S 1 Reply Last reply
              • R Reza
                @tlpeter
                @Reza - it depends on what you want to do, and in which sketch.
                Maybe you should post your sketch and explain what you are planning to do.
                Generally you just add #define MY_REPEATER_FEATURE to make it a repeater node and as you said, remove the sleep() function.
                • S sundberg84
                  R Offline
                  R Offline
                  Reza
                  for example:
                  // Initialize motion message
                  void presentation()  {
                    present(CHILD_ID, S_MOTION);
                    // Read digital motion value
                    Serial.println(tripped);
                   ** sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);**
                  • R Reza
                    for example:
                    @Reza - I added ``` so your code is easier to read.
                    Remove: unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                    Remove: ** sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);**
                    Add: #define MY_REPEATER_FEATURE below #define MY_RADIO_NRF24
                    You also might want to add send() with a If statement so it doesnt sent all the time. The example code is build on a interupt.
                    For example:
                    //Read digital motion value
                    tripped = digitalRead(DIGITAL_INPUT_SENSOR);
                    if (tripped != oldTripped){
                      Serial.println("Motion");
                      oldTripped = tripped;
                    I have one example at github: https://github.com/sundberg84/MySensors-2.0/blob/master/MotionRep/MotionRepAS.ino
                    • S sundberg84
                      For example:
                      R Offline
                      R Offline
                      Reza
                      @sundberg84
                      thank you my friend <3
                      12.2k
