  3. [SOLVED] Wifi gateway crashing ~20min
6 Posts 4 Posters 3.5k Views 2 Watching
  • carlylerC
    carlylerC
    carlyler
    Re: WifiGateway crashes after 1 or 2 days
    Similar issue: ESP8266 GW with local pulse counter sensor, no radio, no other children, development branch, v2.0.1-beta. After about 20min Domoticz shows:
    2016-09-18 12:24:49.422 (ESP) Usage (Usage)
    2016-09-18 12:24:49.443 (ESP) General/kWh (Meter)
    2016-09-18 12:24:59.387 (ESP) General/kWh (Meter)
    2016-09-18 12:24:59.454 (ESP) Usage (Usage)
    2016-09-18 12:24:59.479 (ESP) General/kWh (Meter)
    2016-09-18 12:25:38.449 Error: MySensors: The semaphore timeout period has expired
    2016-09-18 12:25:38.449 TCP: Reconnecting in 30 seconds...
    2016-09-18 12:26:08.477 TCP: Reconnecting...
    Watching the serial, the error builds up over time and then boom! See attached file 0_1474217602140_LmacRxBlk Issue.txt.
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    0;255;3;0;9;No free slot available
    Recovers after about 10min, maybe a timeout or cleanup of some sort?
    Watt:727
    Interval:4950348
    kWH: 9.84
    0;255;3;0;9;Client 0 disconnected
    Watt:714
    Interval:5035182
    kWH: 9.84
    0;255;3;0;9;Client 0 connected
    Watt:721
    Interval:4988227
    kWH: 9.84
    0;255;3;0;9;Client 0: 0;0;3;0;2;
    Watt:710
    Interval:5068874
    kWH: 9.84
    I tend to agree with the suggestion in the other post about using up the sockets, but I need help with what to do about it.
    Any ideas, please?
    • carlylerC carlyler
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      LmacRxBlk:1
      Watt:727
      Interval:4950348
      kWH: 9.84
      Watt:714
      Interval:5035182
      kWH: 9.84
      Watt:721
      Interval:4988227
      kWH: 9.84
      Watt:710
      Interval:5068874
      kWH: 9.84
      Any ideas, please?
      sundberg84S
      sundberg84S
      @carlyler - do you have any other hardware connected to Domoticz?
      I saw this issue trying to connect two different controllers to the same gateway.
      • carlylerC
        carlylerC
        carlyler
        Hi sundberg84. Thank you for the reply.
        Currently I just have the 1 ESP8266.
        I think I found the issue. There is a a lot written online about the error and what I got from it was the ESP8266 is being asked to do more than it has time to do. Given that I was only transmitting every 10sec I started looking at what might be tying things up. From the MySensors ESP8266 example I had, naively, changed the sleeps to delays, since I did not want it sleeping. I realized that might be killing the ESP8266. So I changed the loop function to run freely and the code to be executed on interval. I have not seen the error since.
          sundberg84S
          sundberg84S
          @carlyler - good to hear! Thanks for reporting back.
          • O
            O
            Oleg Greengo
            Hello everybody.
            Today I started testing a bundle of ESP - MQTT version lib Mysensors 2.2.0 | 0x020200FF | final
            I ran the stress test and after 5 minutes of requests, the ESP drops down.
            I changed 3 times all equipment
            As MQTT, I used different services, but the result is always the same.
            Is this the problem in the chip ESP8266?
            This problem was associated with sockets on ESP and was voiced a year and a half ago, but it seems that neither has changed.
            Maybe I missed something, if there are answers, please tell me how to fix this error.
            58002998 Sending message on topic: gateway-1870439-out/2/0/1/0/2
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            58008004 TSF:MSG:READ,2-2-0,s=1,c=2,t=38,pt=0,l=0,sg=0:
            58008009 Sending message on topic: gateway-1870439-out/2/1/2/0/38
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            58013017 TSF:MSG:SEND,0-0-2-2,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:220
            58013024 TSF:MSG:READ,2-2-0,s=1,c=1,t=39,pt=7,l=5,sg=0:2.99
            58013030 Sending message on topic: gateway-1870439-out/2/1/1/0/39
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            58018037 TSF:MSG:READ,2-2-0,s=1,c=1,t=38,pt=7,l=5,sg=0:220
            58018042 TSF:MSG:ACK
            58018044 Sending message on topic: gateway-1870439-out/2/1/1/1/38
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            LmacRxBlk:1
            IP: 192.168.0.15
            58023051 Attempting MQTT connection...
            58023400 MQTT connected
              Are you running the default sketch? What arduino ide do you have? What version of esp8266 library are you using?
