Can't add nodes to HA
I have about 15 nodes and they works well with openhab. But I can't add them to HA.
configuration.yaml
homeassistant: name: Home elevation: 185 unit_system: metric time_zone: Europe/Kiev frontend: http: mysensors: gateways: - device: '/dev/ttyUSB0' persistence_file: '/home/homeassistant/mysensors.json' baud_rate: 115200 debug: true optimistic: true persistence: true version: 1.5 logger: default: debugexample of sketch:
#include <SPI.h> #include <MySensor.h> #include <MySigningAtsha204Soft.h> #include <BH1750.h> #include <Wire.h> #include <dht.h> #define NodeID 1 #define DHT22_VCC 7 #define DHT22_PIN 6 #define LIGHT_VCC 8 #define MOTION_PIN 3 #define LED_PIN 4 // Declare interrupt pin #define INTERRUPT MOTION_PIN-2 #define CHILD_ID_LIGHT 0 #define CHILD_ID_HUM 1 #define CHILD_ID_TEMP 2 #define CHILD_ID_MOTION 3 unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds) BH1750 lightSensor; dht DHT; MyTransportNRF24 radio; MyHwATMega328 hw; //uint8_t soft_serial[SHA204_SERIAL_SZ] = {0x027,0x03,0xa1,0xaa,0x06,0x11,0x25,0xa3,0xa1}; MySigningAtsha204Soft signer; //(true, 0, NULL, soft_serial); MySensor gw(radio, hw, signer); MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgMot(CHILD_ID_MOTION, V_TRIPPED); // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL); boolean interrupt = false; void blink() { digitalWrite(LED_PIN, HIGH); gw.wait(1000); digitalWrite(LED_PIN, LOW); } long readVcc() { // Read 1.1V reference against AVcc // set the reference to Vcc and the measurement to the internal 1.1V reference #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) ADMUX = _BV(MUX5) | _BV(MUX0); #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) ADMUX = _BV(MUX3) | _BV(MUX2); #else ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); #endif delay(2); // Wait for Vref to settle ADCSRA |= _BV(ADSC); // Start conversion while (bit_is_set(ADCSRA,ADSC)); // measuring uint8_t low = ADCL; // must read ADCL first - it then locks ADCH uint8_t high = ADCH; // unlocks both long result = (high<<8) | low; result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000 return result; // Vcc in millivolts } void setup() { pinMode(DHT22_VCC, OUTPUT); pinMode(MOTION_PIN, INPUT); pinMode(LED_PIN, OUTPUT); digitalWrite(LED_PIN, LOW); analogReference(INTERNAL); gw.begin(NULL, NodeID, false); gw.sendSketchInfo("Light Lux Sensor", "2.1"); // Register all sensors to gateway (they will be created as child devices) gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); gw.present(CHILD_ID_MOTION, S_MOTION); lightSensor.begin(BH1750_ONE_TIME_LOW_RES_MODE); } void loop() { digitalWrite(DHT22_VCC, HIGH); // Turn on DHT22 here to save time. unsigned long dht_time = millis(); float batteryV = readVcc(); int batteryPcnt = ( ( batteryV - 3000 ) / 1200 ) * 100; Serial.print("Battery Voltage: "); Serial.print(batteryV); Serial.print(" mV; "); Serial.print("percentage: "); Serial.print(batteryPcnt); Serial.println(" %"); gw.sendBatteryLevel(batteryPcnt); // Motion int tripped; if (interrupt) { //blink(); tripped = 1; } else { if (digitalRead(MOTION_PIN) == HIGH) { //blink(); tripped = 1; } else { tripped = 0; } } Serial.print("Motion detected: "); Serial.println(tripped); gw.send(msgMot.set(tripped)); // Send tripped value to gw //Light lightSensor.configure(BH1750_ONE_TIME_LOW_RES_MODE); uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.print("Light: "); Serial.print(lux); Serial.println(" lx"); gw.send(msgLight.set(lux)); // Temp & Hum if ((millis() - dht_time) < 1000 ) { Serial.print("Wait fro DHT22: "); Serial.println(1000 - (millis() - dht_time)); gw.wait(1000 - (millis() - dht_time)); } Serial.print("DHT22, \t"); int chk = DHT.read22(DHT22_PIN); digitalWrite(DHT22_VCC, LOW); switch (chk) { case DHTLIB_OK: Serial.print("OK,\t"); break; case DHTLIB_ERROR_CHECKSUM: Serial.println("Checksum error,\t"); break; case DHTLIB_ERROR_TIMEOUT: Serial.println("Time out error,\t"); break; default: Serial.println("Unknown error,\t"); break; } // DISPLAY DATA if (chk == DHTLIB_OK ) { float temperature = DHT.temperature; float humidity = DHT.humidity; Serial.print(DHT.humidity, 1); Serial.print(",\t"); Serial.println(DHT.temperature, 1); gw.send(msgTemp.set(temperature, 1)); gw.send(msgHum.set(humidity, 1)); } //We don't need to send motion trigger every minute. if (interrupt) { interrupt = false; gw.sleep(SLEEP_TIME); } else { interrupt = gw.sleep(INTERRUPT,RISING, SLEEP_TIME); } }I'm getting next output in the HA log after restarting the node :
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create> INFO:homeassistant.bootstrap:Home Assistant core initialized INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger INFO:homeassistant.loader:Loaded http from homeassistant.components.http INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend INFO:homeassistant.loader:Loaded api from homeassistant.components.api INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger> WARNING:mysensors.mysensors:File does not exist or is not readable: /home/homeassistant/mysensors.json WARNING:mysensors.mysensors:Trying backup file: /home/homeassistant/mysensors.json.bak WARNING:mysensors.mysensors:File does not exist or is not readable: /home/homeassistant/mysensors.json.bak WARNING:mysensors.mysensors:Failed to load sensors from file: /home/homeassistant/mysensors.json INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors> INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch INFO:homeassistant.loader:Loaded light from homeassistant.components.light INFO:homeassistant.loader:Loaded binary_sensor from homeassistant.components.binary_sensor INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend> INFO:homeassistant.core:Starting Home Assistant (7 threads) INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]> INFO:homeassistant.core:Timer:starting INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0 INFO:mysensors.mysensors:/dev/ttyUSB0 is open... INFO:mysensors.mysensors:Connected to /dev/ttyUSB0 INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=toggle> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=load_platform.light, platform=mysensors> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=binary_sensor> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=load_platform.binary_sensor, platform=mysensors> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=load_platform.sensor, platform=mysensors> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=toggle> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=load_platform.switch, platform=mysensors> INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors INFO:homeassistant.loader:Loaded binary_sensor.mysensors from homeassistant.components.binary_sensor.mysensors INFO:homeassistant.loader:Loaded light.mysensors from homeassistant.components.light.mysensors INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=mysensors_send_ir_code> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart> INFO:homeassistant.components.http:Serving /api/stream to 192.168.0.14 (auth: True) DEBUG:homeassistant.components.api:STREAM 1991040496 ATTACHED DEBUG:homeassistant.components.api:STREAM 1991040496 WRITING data: ping INFO:homeassistant.components.http:Serving /api/bootstrap to 192.168.0.14 (auth: True) WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 0. WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 1. WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 2. WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknownGW and nodes are on 1.5.
Do I need to fix something in the presentation procedure? Is it possible to add nodes manually?
Have you checked the serial output from your node? My guess is you don't have perfect communication between node and gateway and are dropping some messages. You can also try adding a short wait between presentation messages. The missing message from your log is the presentation message of the node, which is sent in the begin method in your sketch.
It's possible to add sensors manually by editing the JSON persistence file, but it's not the recommended approach. If you have comm issues, I would try to fix those first, cause they would impact the performance of your sensors even if you would have them added in home assistant.
Please post a parallel serial log from your node and the home assistant log after start. Also make sure you set log level to debug for
mysensors.mysensorsand include all lines from mysensors. You should have more lines in your log than posted above. -
@martinhjelmare said:
Fixed code with gw.wait(50). There was an error on sending third child before that:
... send: 1-1-0-0 s=3,c=0,t=1,pt=0,l=0,sg=0,st=fail: ...Now sketch looks like that:
... gw.begin(NULL, NodeID, false); gw.wait(50); gw.sendSketchInfo("Light Lux Sensor", "2.1"); gw.wait(50); gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); gw.wait(50); gw.present(CHILD_ID_HUM, S_HUM); gw.wait(50); gw.present(CHILD_ID_TEMP, S_TEMP); gw.wait(50); gw.present(CHILD_ID_MOTION, S_MOTION); ...Sensor log:
send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:1 read: 0-0-1 s=255,c=3,t=15,pt=2,l=2,sg=0:1 send: 1-1-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:01C5B0DC963CB71F2DCD27C8B0F6D158F42093428EB9CC8D57 send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=1,st=ok:1.5.4 send: 1-1-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:017372F9A88F43BC6507E63AF0E71A395A1D40BA4DE874C687 send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0 sensor started, id=1, parent=0, distance=1 send: 1-1-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:019A79B90F8BC63410C3F580DA25F2F468EFA1419E3B4E5FFE send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,sg=1,st=ok:Light Lux Sensor send: 1-1-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:019A79B90F8BC63410C3F580DA25F2F468EFA1419E3B4E5FFE send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=1,st=ok:2.1 send: 1-1-0-0 s=0,c=0,t=16,pt=0,l=0,sg=0,st=ok: send: 1-1-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok: send: 1-1-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,st=ok: send: 1-1-0-0 s=3,c=0,t=1,pt=0,l=0,sg=0,st=ok: Battery Voltage: 4077.00 mV; percentage: 89 % send: 1-1-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:01857D3E43A059F8EBDBA3F632014EB2B1CE62B3F58C017BE0 send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=1,st=ok:89 Motion detected: 1 send: 1-1-0-0 s=3,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:017372F9A88F43BC6507E63AF0E71A395A1D40BA4DE874C687 send: 1-1-0-0 s=3,c=1,t=16,pt=2,l=2,sg=1,st=ok:1 Light: 3 lx send: 1-1-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:01857D3E43A059F8EBDBA3F632014EB2B1CE62B3F58C017BE0 send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=1,st=ok:3 Wait fro DHT22: 288 DHT22, OK, 50.3, 24.6 send: 1-1-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:011D852C06DD95F9234FD0E592B9A2DDA3429BCA9F77526474 send: 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=1,st=ok:24.6 send: 1-1-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=ok: read: 0-0-1 s=255,c=3,t=17,pt=6,l=25,sg=0:013CD41180660904233472CD7B7B8A48DC6CAB595096EC18FC send: 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=1,st=ok:50.3Gateway:
1;255;3;0;6;0 1;255;3;0;11;Light Lux Sensor 1;255;3;0;12;2.1 1;0;0;0;16; 1;1;0;0;7; 1;2;0;0;6; 1;3;0;0;1; 1;255;3;0;0;89 1;3;1;0;16;1 1;0;1;0;23;3 1;2;1;0;0;24.6 1;1;1;0;1;50.3Log of HA is the same:
WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 0. WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 1. WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 2. WARNING:mysensors.mysensors:Node 1 is unknown ERROR:mysensors.mysensors:Node 1 is unknown, will not add child 3. WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknown WARNING:mysensors.mysensors:Node 1 is unknownI added logger with debug. Also "debug: true" in mysensors section. Also --debug to hass command line. But there are no debug messages.
Config:homeassistant: name: Home elevation: 185 unit_system: metric time_zone: Europe/Kiev logger: default: debug logs: mysensors.mysensors: debug frontend: http: history: logbook: mysensors: gateways: - device: '/dev/ttyUSB0' persistence_file: '/home/homeassistant/.homeassistant/mysensors.json' baud_rate: 115200 debug: true optimistic: true persistence: true version: 1.5 -
Config:homeassistant: name: Home elevation: 185 unit_system: metric time_zone: Europe/Kiev logger: default: debug logs: mysensors.mysensors: debug frontend: http: history: logbook: mysensors: gateways: - device: '/dev/ttyUSB0' persistence_file: '/home/homeassistant/.homeassistant/mysensors.json' baud_rate: 115200 debug: true optimistic: true persistence: true version: 1.5The node presentation message is missing from the gateway log. It should be in the beginning.
What version of home assistant are you running?
$ hass --version 0.28.2Not really sure why there are no presentation messages on GW side. According to the log it was sent successfully.
It's possible to add sensors manually by editing the JSON persistence file.
Can you share an example of this file.
Here's an example of a JSON persistence file:
{ "0": { "type": 18, "sensor_id": 0, "battery_level": 0, "children": {}, "sketch_version": null, "protocol_version": "2.0.1-beta", "sketch_name": null }, "1": { "type": 17, "sensor_id": 1, "battery_level": 0, "children": { "1": { "type": 0, "description": "", "values": { "16": "0" }, "id": 1 }, "2": { "type": 3, "description": "", "values": { "2": "0" }, "id": 2 } }, "sketch_version": "1.0", "protocol_version": "2.0.1-beta", "sketch_name": "Binary Sensor" } } -
i have "the same" problem at Home Assistant
I have got only Serial Gateway with 2 temperature sensors (only for test). MySensors V2.0 in the Arduino IDE. I do the presentation:0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0) 0;255;3;0;14;Gateway startup complete. 0;255;3;0;11;Szafa 0;255;3;0;12;0.1 0;0;0;0;6; 0;1;0;0;6; 0;255;3;0;9;No registration required 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1 0;0;1;0;0;0 0;0;2;0;2; 0;1;1;0;0;0 0;1;2;0;2;HA response:
"Node 0 is unknown." "Requesting new presentation for node 0" "Node 0 is unknown , will not add child 0." "Requesting new presentation for node 0" "Node 0 is unknown , will not add child 1." "Requesting new presentation for node 0"I even try send this strings by arduino Serial and SoftwareSerial ..
When HA says about Requesting serial gets "0;255;3;0;19;"0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0) //no effect on HA log 0;255;3;0;14;Gateway startup complete. //no effect on HA log 0;255;3;0;11;Szafa // HA: 0;255;3;0;19; 0;255;3;0;12;0.1 //HA: 0;255;3;0;19; 0;0;0;0;6; //HA: 0;255;3;0;19; 0;1;0;0;6; //HA: 0;255;3;0;19;I don't know, what to do... i need to connect 2 or 3 Serial Gateways with 5 sensors each GW.
There's a bug in mysensors 2.0 where the gateway doesn't present itself in all cases. See here: https://github.com/theolind/pymysensors/issues/51
Either use the workaround mentioned in the github issue, or upgrade to dev branch of mysensors, where this bug is fixed.
