  3. no debug logs on sensebender micro, why?
13 Posts 3 Posters 3.5k Views 3 Watching
  • ikkeTI
    ikkeTI
    ikkeT
    To be clear, this is what the printouts are. I changed the NodeId to make sure the code being run is mine, so the upload succeeded:
    TSM:INIT
    TSM:INIT:TSP OK
    TSM:INIT:STATID,ID=8
    TSF:ASID:OK,ID=8
    TSM:FPAR
    TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:FAIL
    TSM:FAILURE
    TSM:FAILURE:PDT
    • Q
      Q
      Qu3Uk
      This is because the sensor is still initialising and unable to complete as it is unable to find the gateway. It'll loop until it does find a gateway/parent, once it has it'll then go on to process your code.
      Have you set up a gateway already?
      I had this problem recently. Turned out to be a bad radio.
      • ikkeTI
        ikkeTI
        ikkeT
        Thanks for the tip. I do have RaspberryPi with nrf24l01+ and I have terminal open there with serial gateway running in foreground. The radio on raspi side seems to report it's address and info at the start. Only very rarely I see some read:* send: pairs there. Both radios have a 100uF capacitor in place, as I didn't have smaller.
        Perhaps I need to try with a new radio. All the parts are brand new, apart from the Raspi.
        • ikkeTI
          ikkeTI
          ikkeT
          BTW, this is the output on Raspi side, somehow it sees the nodeid 8:
          $ sudo PiGatewaySerial
          Starting PiGatewaySerial...
          Protocol version - 1.4
          Created PTY '/dev/pts/1'
          Gateway tty: /dev/ttyMySensorsGateway
          ================ SPI Configuration ================
          CSN Pin = CE0 (PI Hardware Driven)
          CE Pin = Custom GPIO25
          Clock Speed = 8 Mhz
          ================ NRF Configuration ================
          STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
          RX_ADDR_P0-1 = 0xa8a8e1fc08 0xa8a8e1fc00
          RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
          TX_ADDR = 0xa8a8e1fc08
          RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
          EN_AA = 0x3b
          EN_RXADDR = 0x06
          RF_CH = 0x4c
          RF_SETUP = 0x23
          CONFIG = 0x0e
          DYNPD/FEATURE = 0x3f 0x06
          Data Rate = 250KBPS
          Model = nRF24L01+
          CRC Length = 16 bits
          PA Power = PA_LOW
          read: 8-8-255 s=255,c=3,t=7,pt=0,l=0:
          send: 0-0-8-8 s=255,c=3,t=8,pt=1,l=1,st=fail:0
          • ikkeTI
            ikkeTI
            ikkeT
            and now after while there are occational OKs:
            send: 0-0-8-8 s=255,c=3,t=8,pt=1,l=1,st=ok:0
            • ikkeTI
              ikkeTI
              ikkeT
              Damned. I changed both of the radios, and the sensebender. No help. Still no connection forming. Is there some radio parameters I could try tweaking? Or am I so unlucky that all the radios are broken as new?
              I get lots of these:
              !TSM:FPAR:NO REPLY
              TSM:FPAR
              !TSM:FPAR:NO REPLY
              TSM:FPAR
              !TSM:FPAR:FAIL
              TSM:FAILURE
              TSM:FAILURE:PDT
              and on raspi side some of these:
              read: 8-8-0 s=255,c=3,t=24,pt=1,l=1:1
                What happens if you create a 2.0 serial gateway (you could use one of your sensebenders) and attach it to your raspberry?
                ikkeTI 2 Replies Last reply
                  ikkeTI
                  ikkeTI
                  ikkeT
                  @hek I'll try that.
                    ikkeTI
                    ikkeTI
                    ikkeT
                    @hek to be honest, it's going to take some time, as I have yet no glue how I would attach it to my raspberry :)
                      Through the usb-port...
                      • ikkeTI
                        ikkeTI
                        ikkeT
                        Thanks, and now that I had a second thought, I recalled I already wired another arduino once via serial ports without usb. That would do. But I would like to do it without extra arduino, so I'll try the raspi2 + mysensors hinted in the other hardware thread. It seems to work for some, I'll give it a shot.
                        • ikkeTI
                          ikkeTI
                          ikkeT
                          Just FYI for someone googling this, it works immediately with Mysensors 2.0 with Raspi2 instead of Raspi1. The problem was I never realized the pinouts were not for the raspi with 26 pins but the raspis with 40 pins, like b+/2/3.
