  3. no debug logs on sensebender micro, why?
13 Posts 3 Posters 3.5k Views 3 Watching
  • ikkeTI
    ikkeTI
    ikkeT
    Thanks for the tip. I do have RaspberryPi with nrf24l01+ and I have terminal open there with serial gateway running in foreground. The radio on raspi side seems to report it's address and info at the start. Only very rarely I see some read:* send: pairs there. Both radios have a 100uF capacitor in place, as I didn't have smaller.
    Perhaps I need to try with a new radio. All the parts are brand new, apart from the Raspi.
    • ikkeTI
      ikkeTI
      ikkeT
      BTW, this is the output on Raspi side, somehow it sees the nodeid 8:
      $ sudo PiGatewaySerial
      Starting PiGatewaySerial...
      Protocol version - 1.4
      Created PTY '/dev/pts/1'
      Gateway tty: /dev/ttyMySensorsGateway
      ================ SPI Configuration ================
      CSN Pin = CE0 (PI Hardware Driven)
      CE Pin = Custom GPIO25
      Clock Speed = 8 Mhz
      ================ NRF Configuration ================
      STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1 = 0xa8a8e1fc08 0xa8a8e1fc00
      RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
      TX_ADDR = 0xa8a8e1fc08
      RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
      EN_AA = 0x3b
      EN_RXADDR = 0x06
      RF_CH = 0x4c
      RF_SETUP = 0x23
      CONFIG = 0x0e
      DYNPD/FEATURE = 0x3f 0x06
      Data Rate = 250KBPS
      Model = nRF24L01+
      CRC Length = 16 bits
      PA Power = PA_LOW
      read: 8-8-255 s=255,c=3,t=7,pt=0,l=0:
      send: 0-0-8-8 s=255,c=3,t=8,pt=1,l=1,st=fail:0
      • ikkeTI
        ikkeTI
        ikkeT
        and now after while there are occational OKs:
        send: 0-0-8-8 s=255,c=3,t=8,pt=1,l=1,st=ok:0
        • ikkeTI
          ikkeTI
          ikkeT
          Damned. I changed both of the radios, and the sensebender. No help. Still no connection forming. Is there some radio parameters I could try tweaking? Or am I so unlucky that all the radios are broken as new?
          I get lots of these:
          !TSM:FPAR:NO REPLY
          TSM:FPAR
          TSF:MSG:SEND,8-8-255-255,s=255,c=3,t
          =7,pt=0,l=0,sg=0,ft=0,st=bc:
          !TSM:FPAR:NO REPLY
          TSM:FPAR
          ,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          !TSM:FPAR:FAIL
          TSM:FAILURE
          TSM:FAILURE:PDT
          and on raspi side some of these:
          read: 8-8-0 s=255,c=3,t=24,pt=1,l=1:1
            What happens if you create a 2.0 serial gateway (you could use one of your sensebenders) and attach it to your raspberry?
            ikkeTI 2 Replies Last reply
              ikkeTI
              ikkeTI
              ikkeT
              @hek I'll try that.
                ikkeTI
                ikkeTI
                ikkeT
                @hek to be honest, it's going to take some time, as I have yet no glue how I would attach it to my raspberry :)
                  Through the usb-port...
                  • ikkeTI
                    ikkeTI
                    ikkeT
                    Thanks, and now that I had a second thought, I recalled I already wired another arduino once via serial ports without usb. That would do. But I would like to do it without extra arduino, so I'll try the raspi2 + mysensors hinted in the other hardware thread. It seems to work for some, I'll give it a shot.
                    • ikkeTI
                      ikkeTI
                      ikkeT
                      Just FYI for someone googling this, it works immediately with Mysensors 2.0 with Raspi2 instead of Raspi1. The problem was I never realized the pinouts were not for the raspi with 26 pins but the raspis with 40 pins, like b+/2/3.
