  3. Switchcases?
Switchcases?
4 Posts 4 Posters 1.7k Views 3 Watching
  • kk02067K
    kk02067K
    kk02067
    Hi.
    I need a little advice on where I can get cases similar to these:
    http://se.rs-online.com/web/p/products/0583432/
    Cheaper would be better. If I get these cases the complete switching module gets as expensive as generic z-wave device. And then there is almost no point in making them myself.
      hello
      if you live in EU, you can have a look at tme.
      • mfalkviddM
        There is still a point. They will be better :-D
        The cheapest I've seen are these
        • https://www.kjell.com/se/sortiment/el-verktyg/smarta-hem/433-mhz/fjarrstrombrytare/utanpaliggande-brytare/luxorparts-fjarrstrombrytare-2000-w-3-pack-p50219
        • http://www.clasohlson.com/se/Fjärrströmbrytare-3-pack-Nexa-PE-3/36-4602
        • http://www.rusta.com/se/fjarrstrombrytare-3i1-p92201069.aspx
        • http://www.biltema.se/sv/Bygg/El/Elektrikerverktyg/Fjarrstrombrytare-mini-3-pack-2000021449/ (not sure if these are big enough)
          They can be retrofitted with MySensor nodes.
        Another alternative might be to see if there is room enough in something like this, but it will be tight http://www.biltema.se/sv/Bygg/El/Grenkontakt/Grenuttag-med-brytare-2000038281/
        • Nca78N
          You can also use this solution. It's not extremely cheap but it's all already done, you can reprogram the ESP8266 inside to put a MySensors gateway sketch.
          https://www.itead.cc/smart-home/smart-socket-eu.html
