  3. nodeMCU, MY_GATEWAY_ESP8266 and Temp Sensor
22 Posts 6 Posters 9.7k Views 5 Watching
  • mysensors-6043M
    mysensors-6043M
    mysensors-6043
    Hi since I am new to mysensors, I starting with examples, don't have much experience right now.
    Here is my sketch.
    #include <ESP8266WiFi.h>
    #include <OneWire.h>
    #include <EEPROM.h>
    #define MY_BAUD_RATE 115200
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_ESP8266
    // Enable UDP communication
    #define MY_USE_UDP
    #define MY_PORT 5003
    #define MY_ESP8266_HOSTNAME "nodeMCUTemperatureECM"
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 152
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    #include <WiFiUdp.h>
    #include <MyConfig.h>
    #define ONE_WIRE_BUS 2
    #define MAX_ATTACHED_DS18B20 4
    int numSensors=0;
      //sensors.begin();
      sendSketchInfo("nodeMCUTemperatureECM", "1.0");
      Serial.print("----------------- # of Sensors found >>> ");
      Serial.println(numSensors);
         present(i, S_TEMP);
      Serial.print("Requesting temperatures...");
      sensors.requestTemperatures(); // Send the command to get temperatures
      Serial.println("DONE");
      delay(1000);
    • mysensors-6043M
      mysensors-6043M
      mysensors-6043
      Ok, thank You. So how I declare MySensor gw; in mysensors Version 2 ?
      • mysensors-6043M mysensors-6043
        Here is my sketch.
        #include <EEPROM.h>
        #define MY_USE_UDP
        int numSensors=0;
          //sensors.begin();
             present(i, S_TEMP);
          delay(1000);
        @mysensors-6043 looks like you have used some of the DallasTemperatureSensor example, is that correct?
        If that is the case, it seems heavily modified. Lots of includes that shouldn't be there (MyConfig.h for example) and sensors.begin is called from the wrong funchtion (should be before(), not setup() )
        Try starting with the bare example and get that working. Then extend it little by little while checking that it still works.
        • mysensors-6043M
          mysensors-6043M
          mysensors-6043
          ok, I'll give it another try. Learning by doing :-)
          Starting with the ESP8266 example and adding the Dallas Temp parts ?
            You don't. It is not used in MySensors 2. https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x describes the differences between version 1.5 and 2.0
              Yes that is a good approach. To me it is the best and the most fun way to learn.
              The Dallas example works on several platforms, it is not esp specific. It does require a specific version of the Dallas library though. You can get the example and the library by downloading https://github.com/mysensors/MySensorsArduinoExamples
              • mysensors-6043M
                mysensors-6043M
                mysensors-6043
                Hey great, I started with a new sketch and did what You recommended. I get the number of sensors now without exception and stack trace. On a good way now I guess. Many thank's and best regards from Switzerland
                  Using mysensors 2.0 on a nodeMCU, I can deploy the DS18B20 to read temp values. Secondly using the mysensors Gateway works to join the WLAN and sending Messages to iobroker mysensors instance.
                  Serial log
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  scandone
                  f 0, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 1
                  cnt
                  connected with ho..., channel 1
                  dhcp client start...
                  chg_B1:-40
                  .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                  .IP: 192.168.1.103
                  ----------------- # of Sensors found >>> 1
                  iobroker log
                  mysensors-0 2016-09-30 07:24:06.103 info Version from 192.168.1.103 :1.1
                  mysensors-0 2016-09-30 07:24:06.101 info Name from 192.168.1.103 :nodeMCUTemperatureECM
                  mysensors-0 2016-09-30 07:24:06.095 info Connected 192.168.1.103:5003
                  As soon as I call sensor.begin() I get an exception and stack trace
                  Fatal exception 9(LoadStoreAlignmentCause):
                  epc1=0x402028e8, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000002f, depc=0x00000000
                  Exception (9):
                  epc1=0x402028e8 epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                  ctx: cont
                  sp: 3ffef850 end: 3ffefaf0 offset: 01a0
                  stack>>>
                  3ffef9f0: 00000000 00008000 3ffeeabc 00000030
                  3ffefa00: 3ffe8be0 3ffefa10 000000ff 40225ad5
                  3ffefa10: ffffffff 0000138b 3fff13fc 40228271
                  3ffefa20: 3fff1774 3fff1238 3fff13fc 3ffeeabc
                  3ffefa30: 3fffdad0 3ffefbaf 3ffefb98 40203d38
                  3ffefa40: 000000f3 00000000 3ffefb6c 402047be
                  3ffefa50: 000000e7 3ffefe38 3ffefb98 4020295d
                  3ffefa60: 00000001 3ffefe38 3ffefb98 3ffeeabc
                  3ffefa70: 3ffefbb0 00000001 3ffefb98 40202a44
                  3ffefa80: 3fffdad0 00000000 00000006 40202316
                  3ffefa90: 00000000 3ffefd04 3ffeea80 3ffeeabc
                  3ffefaa0: 3fffdad0 00000000 00000005 40204b2c
                  3ffefab0: 3fffdad0 00000000 3ffeea80 40204d19
                  3ffefac0: 00000000 00000000 3ffeea80 40204460
                  3ffefad0: 3fffdad0 00000000 3ffeea80 40204e34
                  3ffefae0: feefeffe feefeffe 3ffeead0 40100114
                  <<<stack<<<
                  ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                  load 0x4010f000, len 1384, room 16
                  tail 8
                  chksum 0x2d
                  csum 0x2d
                  v3de0c112
                  ~ld
                  0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                  scandone
                  f 0, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 1
                  cnt
                  I found another script where MySensor gw; is declared, but this gives me an error. And in the same example #include MySensor.h is declared. But I have to use #include MySensors.h. Is this a matter of mysensors Version ?
                  This is usually caused by a library which is not (fully) compatible with 32-bit processors (AVR is 8-bit).
                  The MySensors library has been ported to ESP8266 and does not throw such exceptions (to my knowledge).
                  If the DS18B20 library @mfalkvidd pointed at does not solve your issue I would search the net for other people having issues with the same library & ESP8266, to see how they solved it.
                  • mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    ok, yes lokks like this. A soon as I try to get temp values then I run into an exception again.
                      delay(1000);
                    • korttomaK
                      korttomaK
                      korttoma
                      Do not use:
                       delay(1000);
                      Instead try:
                      wait(1000);
                      • Tomas
                        @mysensors-6043
                        As @Yveaux said, it can be lib compatibility with esp.
                        So If you want to try, I use this lib for ds18b20, with other mcus : http://www.pjrc.com/teensy/td_libs_OneWire.html (his stuff is neat).
                        I have not tried with esp8266 though, but i'm pretty sure it works ;) there are defines for esp8266 which are not present in mysensors git..
                        • mysensors-6043M
                          mysensors-6043M
                          mysensors-6043
                          ok, i'll try, hmmmm how to import / use this lib ?
                            @mysensors-6043
                            how did you import Mysensors? ;) that's the same for every lib :)
                            So if you don't find it in lib manager, then download it and unzip it in your lib folder. restart arduino. go to examples. simple.
                            You will find this one in lib manager (look at the one with Paul PaulStoffregen contributor). or download it from his git
                            • CravecodeC
                              CravecodeC
                              Cravecode
                              @mysensors-6043,
                              Have you been able to confirm that you get temperature readings on the sensor? I would try to simplify your sketch to rule things out.
                              Here's what I'd do, in the following order:
                              • Remove all MySensors related code and just get the sensor reading to the serial monitor.
                              • I see you're looping over several temperature sensors on the node, simplify this, only read one for starters.
                              • Verify your gateway is on the network by using telnet or netcat. I.e.: nc xxx.xxx.xxx.xxx 5003
                              • Try just getting your node to "present" to the gateway. Reading the sensor debug via the serial monitor and watch the gateway via netcat.
                              • mysensors-6043M
                                mysensors-6043M
                                mysensors-6043
                                Hi, yes, the Hardware is ok. running a Dallas example script shows the temperature from the sensor.
                                The Gateway is on the Network, I see a DHCP request and get Messages on the iobroker.
                                • CravecodeC
                                  CravecodeC
                                  Cravecode
                                  @mysensors-6043,
                                  The sketch you posted looks like you combined the sensors with the NodeMCU, is this true? Is this NodeMCU acting as a gateway as well?
                                  • mysensors-6043M
                                    mysensors-6043M
                                    mysensors-6043
                                    wrote on last edited by mysensors-6043
                                    yes, but i'm not shure whether this is correct
                                    All I Need is a sensor that sends the temperature via WLAN to UDP Port 5003 of the iobroker (acting as Controller)
                                    Could also be an Arduino Nano with a Radio, e.g. NRF24L01
                                    • CravecodeC
                                      CravecodeC
                                      Cravecode
                                      @mysensors-6043,
                                      The normal setup involves 3 pieces:
                                      1. The sensor (aka node) emitting data via RF using something like a NRF24L01
                                      2. A gateway that receives the sensor data via the RF module (NRF24L01) and sends it to a controller over ethernet or wifi.
                                      3. A controller to manage connected nodes and present data to the user.
                                      It seems like you're combining the sensor and gateway into one device. If this is the case, I think you can comment out the #define MY_RADIO_RFM69 line as there is no radio connected. I don't know how this plays into the registration process of a sensor. There is no ID getting associated to the sensor because this is a gateway.
                                      Maybe someone else can chime in who knows whether it's okay to combine the gateway and sensor into one device. If so, how is registration and ID assignment handled?
                                      @mysensors-6043,
                                      Post a updated version of your sketch.
                                      • mysensors-6043M
                                        mysensors-6043M
                                        mysensors-6043
                                        ok, looks better, I included the library from Paul Stoffregen and commented out #define MY_RADIO_RFM69.
                                        So far no exception. I still can join my home WLAN, but sensor data can not be read.
                                        All I Need is a temp sensor and send the data do a iobroker instance.
                                        The question is whether I'm on the right track with a nodeMCU ?
                                        • mysensors-6043M
                                          mysensors-6043M
                                          mysensors-6043
                                          Hey Folks
                                          Thank's a lot, the issue is solved. nodeMCU as a gateway measures the temperature, pass it over to an iobroker / mysensors instance. There with a JavaScript, I set a Homematic System Variable which is displayed in the iPad.
                                          So now, I know, when the coffee machine has the right temp.
                                          cheers
