  3. Is it possible to run more than one pin to an interrupt for sleep/wake purposes?
55 Posts 7 Posters 19.3k Views 5 Watching
  • AWIA AWI
    @karl261 Thats good news! What you now have is 4 rows high/ 4 colums low (or v.v.). Now short a column with a row and and expect :baby: an interrupt (= keypress). If that is the case, you can create (or copy) a routine to read the key or keys pushed.
    karl261K
    karl261K
    karl261
    @AWI Ok, so far so good. If I connect 4 high wires to rows and 4 low wires to columns (or vice versa, no idea) then the interrupt pin indeed changes to 0. If I connect the interrupt pin of the IC to D3of the Arduino and then both through a pull up of 10 kOhm to Vcc, the interrupt is at 3.3 V. If I press a key it goes down to 0.040 V. That should be enough to read it as low.
    That sounds good, doesn't it? The question is, whether the key library still works...
    AWIA 1 Reply Last reply
    • karl261K karl261
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      #43
      @karl261 Certainly and it can be pretty straight forward from here. Stick to the library you use (this), it contains all you need. You need to let MySensors catch the interrupt (in the sleep function) and have the callback routine (receive) execute char key = kpd.get_key(); as described in the example.
      • AWIA AWI
        karl261K
        karl261K
        karl261
        @AWI It does not compile... I get this stupid error again:
        collect2.exe: error: ld returned 5 exit status
        But I don't know what to do with it.
        • karl261K
          karl261K
          karl261
          current code
          sketch
          #include <i2ckeypad.h>
          #define ROWS 4
          #define COLS 4
          // With A0, A1 and A2 of PCF8574 to ground I2C address is 0x20
          #define PCF8574_ADDR 0x38
          #define PCF8574_PIN_CONFIG 0xf0
          i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS, PCF8574_PIN_CONFIG);
            Serial.begin(9600);
            Wire.begin();
            kpd.init();
            Serial.print("Testing keypad/PCF8574 I2C port expander arduino lib\n\n");
          //  pcf8574_write(pcf8574_i2c_addr, 0xf0);
            if(key != '\0') {
                  Serial.print(key);
          .cpp
           *  i2ckeypad.cpp v0.1 - keypad/I2C expander interface for Arduino
           *  Copyright (c) 2009 Angel Sancho <angelitodeb@gmail.com>
           *  All rights reserved.
           *  Original source from keypad v0.3 of Mark Stanley <mstanley@technologist.com>
           *  (http://www.arduino.cc/playground/Main/KeypadTutorial)
           *  LICENSE
           *  This program is free software: you can redistribute it and/or modify
           *  it under the terms of the GNU General Public License as published by
           *  the Free Software Foundation, either version 3 of the License, or
           *  (at your option) any later version.
           *  This program is distributed in the hope that it will be useful,
           *  but WITHOUT ANY WARRANTY; without even the implied warranty of
           *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
           *  GNU General Public License for more details.
           *  You should have received a copy of the GNU General Public License
           *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
           *  EXPLANATION
           *  This library is designed for use with PCF8574, but can possibly be
           *  adapted to other I2C port expanders
           *  Wiring diagrams for PCF8574 and 4x3 keypad can be found under
           *  examples directory. Library runs correctly without cols pull-up
           *  resistors but it's better to use it
           *  You can change pin connections between PCF8574 and keypad under
           *  PIN MAPPING section below
           *  IMPORTANT! You have to call Wire.begin() before init() in your code
           *  ... and sorry for my poor english!
          #include "i2ckeypad.h"
          //extern "C" {
          //  #include "WConstants.h"
           *  PIN MAPPING
           *  Here you can change your wire mapping between your keypad and PCF8574
           *  Default mapping is for sparkfun 4x3 keypad
          #define COL0  2  // P2 of PCF8574, col0 is usually pin 3 of 4x3 keypads
          #define COL1  0  // P0 of PCF8574, col1 is usually pin 1 of 4x3 keypads
          #define COL2  4  // P4 of PCF8574, col2 is usually pin 5 of 4x3 keypads
          #define COL3  7  // sorry, don't have a 4x4 keypad to try it
          #define ROW0  1  // P1 of PCF8574, row0 is usually pin 2 of 4x3 keypads
          #define ROW1  6  // P6 of PCF8574, row1 is usually pin 7 of 4x3 keypads
          #define ROW2  5  // P5 of PCF8574, row2 is usually pin 6 of 4x3 keypads
          #define ROW3  3  // P3 of PCF8574, row3 is usually pin 4 of 4x3 keypads
           *  KEYPAD KEY MAPPING
           *  Default key mapping for 4x4 keypads, you can change it here if you have or
           *  like different keys
          const char keymap[4][5] =
            "123A",
            "456B",
            "789C",
            "*0#D"
           *  VAR AND CONSTANTS DEFINITION. Don't change nothing here
          // Default row and col pin counts
          int num_rows = 4;
          int num_cols = 3;
          // PCF8574 i2c address
          int pcf8574_i2c_addr;
          // PCF8574 i2c pin configuration (high low)
          int pcf8574_i2c_pin_cfg;
          // Current search row
          static int row_select;
          // Current data set in PCF8574
          static int current_data;
          // Hex byte statement for each port of PCF8574
          const int hex_data[8] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
          // Hex data for each row of keypad in PCF8574
          const int pcf8574_row_data[4] =
            hex_data[ROW1] | hex_data[ROW2] | hex_data[ROW3] |
            hex_data[COL0] | hex_data[COL1] | hex_data[COL2] | hex_data[COL3],
            hex_data[ROW0] | hex_data[ROW2] | hex_data[ROW3] |
            hex_data[ROW0] | hex_data[ROW1] | hex_data[ROW3] |
            hex_data[ROW0] | hex_data[ROW1] | hex_data[ROW2] |
          // Hex data for each col of keypad in PCF8574
          int col[4] = {hex_data[COL0], hex_data[COL1], hex_data[COL2], hex_data[COL3]};
           *  CONSTRUCTORS
          i2ckeypad::i2ckeypad(int addr)
            pcf8574_i2c_addr = addr;
          i2ckeypad::i2ckeypad(int addr, int r, int c, int pinc)
            num_rows = r;
            num_cols = c;
            pcf8574_i2c_pin_cfg = pinc;
           *  PUBLIC METHODS
          void i2ckeypad::init()
            // All PCF8574 ports high
            pcf8574_write(pcf8574_i2c_addr, pcf8574_i2c_pin_cfg);
            // Start with the first row
            row_select = 0;
          char i2ckeypad::get_key()
            static int temp_key;
            int tmp_data;
            int r;
            int key = '\0';
            // Search row low
            pcf8574_write(pcf8574_i2c_addr, pcf8574_row_data[row_select]);
            for(r=0;r<num_cols;r++) {
              // Read pcf8574 port data
              tmp_data = pcf8574_byte_read(pcf8574_i2c_addr);
              // XOR to compare obtained data and current data and know
              // if some column are low
              tmp_data ^= current_data;
              // Key pressed!
              if(col[r] == tmp_data) {
                temp_key = keymap[row_select][r];
                return '\0';
            // Key was pressed and then released
            if((key == '\0') && (temp_key != '\0'))
              key = temp_key;
              temp_key = '\0';
              return key;
            // All PCF8574 ports high again
            // Next row
            row_select++;
            if(row_select == num_rows) {
              row_select = 0;
            return key;
           *  PRIVATE METHODS
          void i2ckeypad::pcf8574_write(int addr, int data)
            current_data = data;
            Wire.beginTransmission(addr);
            Wire.write(data);
            Wire.endTransmission();
          int i2ckeypad::pcf8574_byte_read(int addr)
            Wire.requestFrom(addr, 1);
            return Wire.read();
          .h
          #ifndef i2ckeypad_h
          #define i2ckeypad_h
          #include <inttypes.h>
          #if ARDUINO >= 100
          #include "Arduino.h"
          #include "WProgram.h"
          class i2ckeypad {
          public:
            i2ckeypad(int);
            i2ckeypad(int, int, int, int);
            char get_key();
            void init();
          private:
            void pcf8574_write(int, int);
            int pcf8574_byte_read(int);
          • karl261K karl261
            current code
            sketch
            #define ROWS 4
            #define COLS 4
              Serial.begin(9600);
              Wire.begin();
              kpd.init();
              if(key != '\0') {
                    Serial.print(key);
            .cpp
             *  LICENSE
             *  EXPLANATION
            //extern "C" {
             *  PIN MAPPING
              "123A",
              "456B",
              "789C",
              "*0#D"
            int num_rows = 4;
            int num_cols = 3;
             *  CONSTRUCTORS
              num_rows = r;
              num_cols = c;
             *  PUBLIC METHODS
              row_select = 0;
              int tmp_data;
              int r;
              int key = '\0';
              // Search row low
                // Key pressed!
                  return '\0';
                key = temp_key;
                temp_key = '\0';
                return key;
              // Next row
              row_select++;
                row_select = 0;
              return key;
             *  PRIVATE METHODS
              Wire.write(data);
              return Wire.read();
            .h
            #ifndef i2ckeypad_h
            #define i2ckeypad_h
            #if ARDUINO >= 100
            class i2ckeypad {
            public:
              i2ckeypad(int);
              char get_key();
              void init();
            private:
            AWIA
            AWIA
            AWI
            #46
            @karl261 I compiled the thing without any errors...
            what I did:
            • All the files (including the library) in (sub)folder Keypad
            • Saved the sketch as Keypad.ino
            • Changed <i2ckeypad.h> to "i2ckeypad.h"
            p.s. a google search showed that the error occurs with many for no obvious reason...
            karl261K 2 Replies Last reply
            • AWIA AWI
              what I did:
              karl261K
              karl261K
              karl261
              @AWI yes, I checked Google too, but there is now real solution. I can go back to 1.6.5r5 maybe this works.
              • AWIA AWI
                what I did:
                karl261K
                karl261K
                karl261
                @AWI This makes no sense at all! I did what you did, and it compiled. Then I reverted the steps, to my original setup, and it compiles too. WHY? I would be SO HAPPY if somebody could explain.
                So the sketch works, but not all keys...
                • karl261K
                  karl261K
                  karl261
                  wrote on last edited by karl261
                  #49
                  Ok, the keypad works. All keys. Now I have to check the interrupt.
                  The interrupt is not working any more. At least I don't see it on the Voltmeter. The interrupt pin remains high all the time.
                  I think this is because to get the key pressed, the library is scanning through the pins and writes different high low states to the ports of the pcf. This kills again the interrupt functionality.
                  Yes, if I take out the loop function char key = kpd.get_key(); then the interrupt works again, because the library only writes 0xf0 and then it works. When the library is scanning, it does not work anymore.
                  maybe it is possible to write 0xf0 before going to sleep... Then it won't scan, just wait for the interrupt?
                  With the knew knowledge of 0xf0 writing I could also test the keypad_I2C library.
                  • karl261K karl261
                    AWIA
                    AWIA
                    AWI
                    @karl261 A lot of thoughts ;-) My idea is:
                    • write the 0x0f
                    • go to sleep
                    • if interrupt (wake-up) scan the keyboard and get the key
                    • Do whatever you need to do with the key
                    • write the 0x0f
                    • go to sleep
                    • etc...
                    karl261K 1 Reply Last reply
                    • AWIA AWI
                      • write the 0x0f
                      • go to sleep
                      • write the 0x0f
                      • go to sleep
                      • etc...
                      karl261K
                      karl261K
                      karl261
                      @AWI I am trapped between "collect2.exe: error: ld returned 5 exit status" errors and non working sketches. This is the world of pain. I am tempted to give up. It just does not make sense. I like things that do make sense...
                      • karl261K karl261
                        AWIA
                        AWIA
                        AWI
                        @karl261 don't give up.. :relaxed: we will get you there. Not much I can do about the 'collect' error but if you post your sketch..
                        • AWIA AWI
                          karl261K
                          karl261K
                          karl261
                          @AWI Ok, I got it working somehow, now with the original Keypad_I2C library, because it had the functions ready to write to the pins... But it needs some more tine tuning. And it does not work all the time, sometimes I need to reset the PCF, by disconnecting it from power and then restart the Arduino.
                          In the log below the first try does not work, the second try after reset it works.
                          And after the log the sketch. It sure needs some improvement.
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=8)
                          TSM:FPAR
                          TSP:MSG:SEND 8-8-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 0-0-8 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:PAR OK (ID=0, dist=1)
                          TSP:MSG:READ 99-99-8 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                          TSP:MSG:FPAR RES (ID=99, dist=1)
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=8)
                          TSM:UPL
                          TSP:PING:SEND (dest=0)
                          TSP:MSG:SEND 8-8-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-8 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          TSP:MSG:PONG RECV (hops=1)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          start
                          TSP:MSG:SEND 8-8-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          !TSP:MSG:SEND 8-8-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                          TSP:MSG:SEND 8-8-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                          TSP:MSG:READ 0-0-8 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          Request registration...
                          TSP:MSG:SEND 8-8-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                          TSP:MSG:READ 0-0-8 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          Node registration=1
                          Init complete, id=8, parent=0, distance=1, registration=1
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=8)
                          TSM:UPL
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          start
                          Node registration=1
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          B
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          C
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          Waking up
                          Good Night
                          #include <Keypad_I2C.h>
                          #include <Keypad.h>
                          #define I2CADDR 0x38
                          #define MY_NODE_ID 8
                          word temp_pin_state;
                          unsigned long time;
                          unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
                          const byte ROWS = 4; //four rows
                          const byte COLS = 4; //three columns
                          char keys[ROWS][COLS] = {
                            {'1','2','3','A'},
                            {'4','5','6','B'},
                            {'7','8','9','C'},
                            {'*','0','#','D'}
                          // Digitran keypad, bit numbers of PCF8574 i/o port
                          byte rowPins[ROWS] = {0, 1, 2, 3}; //connect to the row pinouts of the keypad
                          byte colPins[COLS] = {4, 5, 6, 7}; //connect to the column pinouts of the keypad
                          Keypad_I2C kpd( makeKeymap(keys), rowPins, colPins, ROWS, COLS, I2CADDR, PCF8574 );
                          void setup(){
                              Wire.begin( );
                              kpd.begin( makeKeymap(keys) );
                          //    Serial.begin(9600);
                              Serial.println( "start" );
                              temp_pin_state = kpd.pinState_set( );
                          void loop(){
                              Serial.println("Waking up");
                              kpd.port_write( temp_pin_state );
                              wait(100);
                              time = millis();
                              while ((millis() - time) < 500) {
                                char key = kpd.getKey();
                                if (key){
                                  Serial.println(key);
                              Serial.println("Good Night");
                              kpd.port_write( 0xf0 );
                              wait(100);
                              sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), FALLING, SLEEP_TIME);
                          • karl261K
                            karl261K
                            karl261
                            This sketch works a little bit better... Hm, it sometimes is not reading a key, but it seems to be the loose cable connections?!
                            #include <Keypad.h>
                            unsigned long time;
                              {'1','2','3','A'},
                              {'4','5','6','B'},
                              {'7','8','9','C'},
                              {'*','0','#','D'}
                            void setup(){
                                Wire.begin( );
                                kpd.port_write( 0xff );
                            void loop(){
                            //    wait(100);
                                time = millis();
                                while ((millis() - time) < 250) {
                                  if (key){
                                wait(50);
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=8)
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            start
                            Node registration=1
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            B
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            C
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            Waking up
                            Good Night
                            • karl261K karl261
                              #include <Keypad.h>
                              unsigned long time;
                                {'1','2','3','A'},
                                {'4','5','6','B'},
                                {'7','8','9','C'},
                                {'*','0','#','D'}
                              void setup(){
                                  Wire.begin( );
                              void loop(){
                              //    wait(100);
                                  time = millis();
                                    if (key){
                                  wait(50);
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=8)
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              start
                              Node registration=1
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              B
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              C
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              Waking up
                              Good Night
                              AWIA
                              AWIA
                              AWI
                              @karl261 it looks good to me. Try to get your connections stable.
                              12.5k
