  3. cannot compile new MQTT GW sketch
3 Posts 2 Posters 1.5k Views 2 Watching
  • siodS
    siodS
    siod
    When trying to compile my MQTT Gateway sketch:
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
    I am getting this error:
    T:\Programme\Arduino 1.6.10\arduino-builder -dump-prefs -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -hardware "C:\Users\Cito\AppData\Local\Arduino15\packages" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -tools "C:\Users\Cito\AppData\Local\Arduino15\packages" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino"
    T:\Programme\Arduino 1.6.10\arduino-builder -compile -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -hardware "C:\Users\Cito\AppData\Local\Arduino15\packages" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -tools "C:\Users\Cito\AppData\Local\Arduino15\packages" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino"
    Using board 'uno' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
    Using core 'arduino' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
    Warning: Board arduino:avr:apm96 doesn't define a 'build.board' preference. Auto-set to: AVR_APM96
    Detecting libraries used...
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dhcp.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dhcp.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dns.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Ethernet.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetClient.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetServer.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetUdp.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\utility\socket.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\utility\w5100.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
    Generating function prototypes...
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    "T:\Programme\Arduino 1.6.10\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    Sketch wird kompiliert...
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp.o"
    In file included from T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:23:0,
                     from T:\Programme\Arduino 1.6.10\libraries\MySensors/MySensors.h:261,
                     from T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino:137:
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:34:31: error: 'SPI_MODE0' was not declared in this scope
     #define MY_RF24_SPI_DATA_MODE SPI_MODE0
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:76: note: in expansion of macro 'MY_RF24_SPI_DATA_MODE'
       SoftSPI<MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, MY_RF24_SPI_DATA_MODE> _SPI;
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:97: error: template argument 4 is invalid
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:103: error: invalid type in declaration before ';' token
    In file included from T:\Programme\Arduino 1.6.10\libraries\MySensors/MySensors.h:261:0,
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp: In function 'uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)':
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:44:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
      uint8_t status = _SPI.transfer( cmd );
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:47:18: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
        status = _SPI.transfer( NOP );
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:49:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
       } else status = _SPI.transfer(*current++);
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp: In function 'bool RF24_initialize()':
    T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:261:7: error: request for member 'begin' in '_SPI', which is of non-class type 'int'
      _SPI.begin();
    Bibliothek Ethernet in Version 1.1.2 im Ordner: T:\Programme\Arduino 1.6.10\libraries\Ethernet  wird verwendet
    Bibliothek MySensors in Version 2.0.0 im Ordner: T:\Programme\Arduino 1.6.10\libraries\MySensors  wird verwendet
    Bibliothek SPI in Version 1.0 im Ordner: T:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI  wird verwendet
    exit status 1
    Fehler beim Kompilieren für das Board Arduino/Genuino Uno.
    Library is installed, using Arduino IDE 1.6.10. Any idea?
    still learning...
    BartEB 1 Reply Last reply
    • siodS siod
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
        #define MY_SOFTSPI
        _SPI.begin();
      exit status 1
      BartEB
      BartEB
      BartE
      @siod this line is missing
      You need to add this line before these includes
      • siodS
        siodS
        siod
        wrote on last edited by siod
        Mmh, thx, I just copied and pasted it from the instructions from the main page... So it must get corrected there as well...
        Thank you, I will try it later!
        edit:
        For the sake of completeness, I want to mention, that @Ernst79 already gave the hint in the comments section of "Building a MQTT Gateway" Install-Instruction on the mainpage. I just did not see it, but I would love to see @tbowmo to add this line to the code. Thank you!
        still learning...
