  3. Can't get sensors talking
24 Posts 7 Posters 10.9k Views 6 Watching
  • linus72982L linus72982
    @tekka
    Thanks for the explanation of the messages, that helped me quite a bit. I figured out that my gateway radio wasn't working very well so I bought an Addicore version that the reviews said was a bit more reliable. It came in today and works like a champ (and it has labeled pins which is helpful).
    I eagerly await the documentation of the messages. I am writing a controller in Python and with my limited C knowledge (weird, I know, as Python is a C-based language, but it's just different enough to drive me nuts), I'm going cross-eyed trying to reverse-engineer the messages from the code. Your documentation will help immensely. Just the bit you told me up there has allowed me to write most of it. Thanks, again.
    tekkaT
    tekkaT
    tekka
    @linus72982 You'll find some more information here. This is a PR (still WIP) for the dev branch and applies to the upcoming 2.0.1 release.
    linus72982L 1 Reply Last reply
    • tekkaT tekka
      linus72982L
      linus72982L
      linus72982
      @tekka
      That's good info, thank you. Quick question if you have a minute, what is the difference between CHKUPL and SANCHK? Based on the docs, they both seem to accomplish the same goal.
      tekkaT 1 Reply Last reply
        @tekka
        tekkaT
        tekkaT
        tekka
        @linus72982 No, they do different things: CHKUPL checks the uplink, i.e. connection to GW whereas SANCHK is the regular radio HW sanity check (radio register verification + SPI connection).
        • tekkaT tekka
          @linus72982 looks like you have an issue with your GW radio:
          0;255;3;0;9;!TSP:SANCHK:FAIL
          GW and repeater nodes have by default regular sanity checks enabled. In your case, the sanity check fails, most likely due to cable and/or power issues. Try fixing/reseating the radio cables and/or add a larger cap to the GW radio.
          Also, please post the node sketch for further analysis.
          As for the debug messages, here the most important ones:
          TSM:FPAR => Transport State Machine:Find PARent
          !TSM:UPL FAIL, SNP => Uplink failed, Search New Parent
          !TSP:SEND:TNR => Transport:SEND:Transport Not Ready
          TSM:PDT => PowerDown Transport
          I'm currently working on a PR to unify and document all transport debug log messages for troubleshooting
          In your case, this is what happened:
          1. Node initializes and assigns ID 3, then it fails to find a parent...
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=3)
          TSM:FPAR
          TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          1. Later on it receives a response to the find parent request from node ID 0 (=GW)
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSM:FPAR:OK
          1. and finally, the TSM is fully operational.
          TSM:READY
          1. Then the node starts sending the presentation messages...
          TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
          TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
          TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
          1. ...and fails again to (successfully) send the messages to the GW
          !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=fail:Binary Sensor
          !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
          !TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,ft=2,st=fail:
          !TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=0,pt=0,l=0,sg=0,ft=3,st=fail:
          1. Hence, start searching for a new parent...
          !TSM:UPL FAIL, SNP
          TSM:FPAR
          1. ...and (again) no reply from the GW, therefore...
          !TSP:SEND:TNR
          1. Transport not ready, and starting from the beginning...
          alexsh1A
          alexsh1A
          alexsh1
          @tekka Can we please get your info about deciphering the log in v.2 into a separate sticky thread in the Troubleshooting section?
          Thank you very much for producing it
          • alexsh1A alexsh1
            tekkaT
            tekkaT
            tekka
            @alexsh1 The debug log messages are fully documented in the upcoming 2.0.1 release, see here for a preview (dev): https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
            • tekkaT tekka
              @alexsh1 more explicitly, a description of the transport state machine messages (TSM) can be found here: https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
              • YveauxY Yveaux
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @Yveaux @alexsh1 https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/group__MyTransportgrp.html
                • tekkaT tekka
                  @tekka ehhhrrfmmm... Copy/paste on Android didn't work as expected.... Sorry
                  • CravecodeC
                    CravecodeC
                    Cravecode
                    wrote on last edited by Cravecode
                    #22
                    • Q
                      Q
                      Quinie
                      Hi All
                      I am working on the version 2 for the first time after being away for awhile.
                      The gateway is up and running.
                      8-10-2016 02:45:07	RX	0;255;3;0;9;TSP:SANCHK:OK
                      But my sensors is giving problems.
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=188)
                      TSM:FPAR
                      TSP:MSG:SEND 188-188-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      I have a 4,7 capacitor in place. Any ideas?
                      • Q
                        Q
                        Quinie
                        Changed the arduino.. not the radio .. from UNO to Nano (not the sensor but the gateway).. now it works...
                        12.5k
