  3. Can't get sensors talking
24 Posts 7 Posters 10.9k Views 6 Watching
  • sundberg84S sundberg84
    @tekka - i get this:
    TSM:FPAR
    TSP:MSG:SEND 12-12-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-12 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSP:MSG:READ 101-101-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=101, dist=1)
    TSP:MSG:READ 99-99-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=99, dist=1)
    TSP:MSG:READ 100-100-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
    TSP:MSG:FPAR RES (ID=100, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=12)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 12-12-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    in an endless repeat.
    What does it mean?
    This is the same code as before - cleared eeprom and uploaded to a working node, only change is 2.0 lib.
    My guess is that I need to update the repeater/gw as well? They are running 2.0 beta.
    tekkaT
    tekkaT
    tekka
    @sundberg84 We do not recommend nor have the bandwidth to support and troubleshoot setups with mixed MySensors versions (i.e. 1.x and 2.x). That said, mixed setups can but are not guaranteed to function. As semantic versioning suggests, a major version increment implies API changes that are not backwards compatible: For a full list of changes in 2.0.0, please refer to the change log.
    In your case, update all nodes/GW/repeaters to the most recent MySensors version, and report back if you encounter any issues.
    As @Yveaux pointed out, I am working on a PR that unifies and documents all debug messages emitted from the transport layer.
    • tekkaT tekka
      sundberg84S
      sundberg84S
      @tekka - ok, thanks @tekka. I have 25+ nodes so I guess I have some work then
      .. or maybe I'll just stick to 2.0b.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @sundberg84 Wow, how is the topology?
        • sundberg84S
          sundberg84S
          @tekka -
          GW - 2.0b
          3x Repeaters (combined with motion) - 2.0b
          Nodes about 50% 1.4-1.5 and 50% 2.0b
          but nevermind, I will hold on to your document is finished - no worries. I was just to eager to upgrade :)
          Then I will try to upgrade the gw and see what happens.
          • tekkaT tekka
            @linus72982 looks like you have an issue with your GW radio:
            0;255;3;0;9;!TSP:SANCHK:FAIL
            GW and repeater nodes have by default regular sanity checks enabled. In your case, the sanity check fails, most likely due to cable and/or power issues. Try fixing/reseating the radio cables and/or add a larger cap to the GW radio.
            Also, please post the node sketch for further analysis.
            As for the debug messages, here the most important ones:
            TSM:FPAR => Transport State Machine:Find PARent
            !TSM:UPL FAIL, SNP => Uplink failed, Search New Parent
            !TSP:SEND:TNR => Transport:SEND:Transport Not Ready
            TSM:PDT => PowerDown Transport
            I'm currently working on a PR to unify and document all transport debug log messages for troubleshooting
            In your case, this is what happened:
            1. Node initializes and assigns ID 3, then it fails to find a parent...
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=3)
            TSM:FPAR
            TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            1. Later on it receives a response to the find parent request from node ID 0 (=GW)
            TSM:FPAR:OK
            1. and finally, the TSM is fully operational.
            TSM:READY
            1. Then the node starts sending the presentation messages...
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
            TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
            TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
            1. ...and fails again to (successfully) send the messages to the GW
            !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=fail:Binary Sensor
            !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
            !TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,ft=2,st=fail:
            !TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=0,pt=0,l=0,sg=0,ft=3,st=fail:
            1. Hence, start searching for a new parent...
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            1. ...and (again) no reply from the GW, therefore...
            !TSP:SEND:TNR
            1. Transport not ready, and starting from the beginning...
            linus72982L
            linus72982L
            linus72982
            @tekka
            Thanks for the explanation of the messages, that helped me quite a bit. I figured out that my gateway radio wasn't working very well so I bought an Addicore version that the reviews said was a bit more reliable. It came in today and works like a champ (and it has labeled pins which is helpful).
            I eagerly await the documentation of the messages. I am writing a controller in Python and with my limited C knowledge (weird, I know, as Python is a C-based language, but it's just different enough to drive me nuts), I'm going cross-eyed trying to reverse-engineer the messages from the code. Your documentation will help immensely. Just the bit you told me up there has allowed me to write most of it. Thanks, again.
            • linus72982L linus72982
              @tekka
              tekkaT
              tekkaT
              tekka
              @linus72982 You'll find some more information here. This is a PR (still WIP) for the dev branch and applies to the upcoming 2.0.1 release.
              linus72982L 1 Reply Last reply
              • tekkaT tekka
                linus72982L
                linus72982L
                linus72982
                @tekka
                That's good info, thank you. Quick question if you have a minute, what is the difference between CHKUPL and SANCHK? Based on the docs, they both seem to accomplish the same goal.
                  @tekka
                  tekkaT
                  tekkaT
                  tekka
                  @linus72982 No, they do different things: CHKUPL checks the uplink, i.e. connection to GW whereas SANCHK is the regular radio HW sanity check (radio register verification + SPI connection).
                  • tekkaT tekka
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:FPAR:OK
                    TSM:READY
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    !TSP:SEND:TNR
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @tekka Can we please get your info about deciphering the log in v.2 into a separate sticky thread in the Troubleshooting section?
                    Thank you very much for producing it
                    • alexsh1A alexsh1
                      tekkaT
                      tekkaT
                      tekka
                      @alexsh1 The debug log messages are fully documented in the upcoming 2.0.1 release, see here for a preview (dev): https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
                      • tekkaT tekka
                        @alexsh1 more explicitly, a description of the transport state machine messages (TSM) can be found here: https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
                        • YveauxY Yveaux
                          tekkaT
                          tekkaT
                          tekka
                          wrote on last edited by tekka
                          @Yveaux @alexsh1 https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/group__MyTransportgrp.html
                          • tekkaT tekka
                            @tekka ehhhrrfmmm... Copy/paste on Android didn't work as expected.... Sorry
                            • CravecodeC
                              CravecodeC
                              Cravecode
                              wrote on last edited by Cravecode
                              #22
                              • Q
                                Q
                                Quinie
                                Hi All
                                I am working on the version 2 for the first time after being away for awhile.
                                The gateway is up and running.
                                8-10-2016 02:45:07	RX	0;255;3;0;9;TSP:SANCHK:OK
                                But my sensors is giving problems.
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=188)
                                TSM:FPAR
                                TSP:MSG:SEND 188-188-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                I have a 4,7 capacitor in place. Any ideas?
                                • Q
                                  Q
                                  Quinie
                                  Changed the arduino.. not the radio .. from UNO to Nano (not the sensor but the gateway).. now it works...
                                  12.5k
