  3. LCD Clock and Text sensor node with new V_TEXT
39 Posts 11 Posters 34.7k Views 21 Watching
  • NiklasON NiklasO
    Does this work with MySensors 2.0? If someone has this running on 2.0, please share the code. :)
    Q
    Q
    Qu3Uk
    @NiklasO I have something similar running on MYS 2.0 and can paste the code. I'm using a 4x1 display and using V_VAR-1-4 to send each line over.
    If that's useful to you I can post it.
    NiklasON 1 Reply Last reply
    • Q Qu3Uk
      NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      #26
      Yes please. I ported to 2.0 late yesterday and it works ok. I have 4 lines, 20 chars.
      Q 1 Reply Last reply
      • Marc-Olivier ChaubetM Marc-Olivier Chaubet
        i try to send message but nothing change on LcdDisplay.
        I d'ont undestant what is wrong.
        Can you help me pls.
        send: 49-49-20-0 s=8,c=2,t=47,pt=0,l=0,sg=0,st=ok:
        send: 49-49-20-0 s=9,c=2,t=47,pt=0,l=0,sg=0,st=ok:
        read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:test
        send: 49-49-20-0 s=9,c=1,t=16,pt=0,l=4,sg=0,st=ok:test
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        #27
        @Marc-Olivier-Chaubet Can you post a little more information (the sketch)?
        The text seems to be arriving at the node. So first check if the information comes in on serial (Serial.print(....)).
        And next: is your display working? just print something it in the local sketch.
        • NiklasON NiklasO
          Q
          Q
          Qu3Uk
          @NiklasO
          Here is it.
          //#define MY_NODE_ID 200
          #define MY_SENSOR_ID 1
          #define MY_REPEATER_FEATURE
          // LCD includes
          // MYS includes
          #define LCD_ON 1  // GPIO value to write to turn on attached relay
          #define LCD_OFF 0 // GPIO value to write to turn off attached relay
          LiquidCrystal_I2C lcd(0x3f, 20, 4); //0x3f is the LCD address.
          String LINE_BLANK = "                    ";
          void before() {
            // Set off  LCD module
            lcd.begin ();
            lcd.backlight();
            lcd.setCursor(0, 0); //
            lcd.print("Ready!"); // We expect the controller to remove this from display.
            sendSketchInfo("LCD Display", "1.0");
            present(MY_SENSOR_ID, S_INFO);
            // extra processing if required.
              // Use V_STATUS to turn on/off the LCD display
              // if supported by LCD.
            // temp string, probably don't need this.
            if (message.type == V_VAR1) {
              writeScreen(0, message.data);
            if (message.type == V_VAR2) {
              writeScreen(1, message.data);
            if (message.type == V_VAR3) {
              writeScreen(2, message.data);
            if (message.type == V_VAR4) {
              writeScreen(3, message.data);
          void writeScreen(int line, String text)
            // Trim whitespace from incoming text.
            text.trim();
            // Remove anything over 20 char in text.
            if(text.length() > 19)
                text.remove(20);
            // Clear the line
            lcd.setCursor(0, line);
            lcd.print(LINE_BLANK);
            // Set Line
            lcd.print(text);
          user1306U 1 Reply Last reply
            wrote on last edited by Marc-Olivier Chaubet
            #29
            Hi AWI,
            Yes my display is working, i can see the date and "Line 1 - First....."
            I think what i send is not correct....0_o
            This is from the serial monitor
            Should it be something like this
            read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:Line1=test
            this is the sketch.
             PROJECT: MySensors / LCD display for text from controller
             PROGRAMMER: AWI
             DATE: september 8, 2015/ last update: september 8, 2015
             FILE: AWI_LCD_49.ino
             LICENSE: Public domain
             Hardware: tbd ..MYS Ceech - ATmega328p board w/ NRF24l01
                and MySensors 1.5 ()
            Special:
                MySensors - Development (as of sept 2015)
            SUMMARY:
                display time & 2 lines of text from Controller Text sensors
            #include <MyMessage.h>
            #include <MySensor.h>                       // Mysensor network
            #include <Time.h>                           //http://playground.arduino.cc/Code/Time
            // uncomment if you are using the DEVELOPMENT version with V_TEXT & V_INFO defined (better to use development MyMessage.h)
            const byte V_TEXT = 47 ;                  // values taken from development edition MyMessage.h
            const byte S_INFO = 36 ;
            const byte nodeId = 49 ;                    // MySensors fixed node id
            const byte LCD1_CHILD = 8 ;                 // LCD line 1
            const byte LCD2_CHILD = 9 ;                 // LCD line 2
            char lastLCD1[21] = "Line1 - first   ";     // define & init before first receive
            char lastLCD2[21] = "Line2 - second  ";
            boolean timeReceived = false ;
            // timers for loop delays
            unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0;
            int display_no = 0 ;                        // current display
            // *** Definition and initialisation
            // define the MySensor network
            MyTransportNRF24 transport(9,10);           // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
            MySensor gw(transport);
            // Initialize messages for sensor network
            MyMessage textMsg(0, V_TEXT);
            LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
            // OPTIONAL: Custom characters for display - Units)
            byte heart[8] = { B00000, B01010, B11111, B11111, B01110, B00100, B00000, B00000};
            void setup(void){
                //Serial in Sensor network = 115200
                gw.begin(incomingMessage, nodeId);                  // this node is 49 fixed
                //Send the sensor node sketch version information to the gateway
                gw.sendSketchInfo("AWI_LCD text 49", "1.1");
                gw.present(LCD1_CHILD, S_INFO, "LCD_line1");        // new S_type 20150905 (not know by domoticz)
                gw.present(LCD2_CHILD, S_INFO, "LCD_line2");
                gw.send(textMsg.setSensor(LCD1_CHILD).set("-"));    // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                gw.send(textMsg.setSensor(LCD2_CHILD).set("-"));
                // Initializations
                gw.requestTime(receiveTime);                        // get the time from controller (handled by receiveTime)
                // ** LCD display **
                Wire.begin();                                       // I2C
                lcd.begin(16, 2);                                   // LCD 2 lines * 16 char.
                lcd.setBacklight(HIGH);
                lcd.createChar(1, heart);
                // lcd.write(byte(0)); // write units
            void loop(void){
                // timer for loop delays
                unsigned long now = millis();
                gw.process() ;
                // If no time has been received yet, request it every 10 second from controller
                // When time has been received, request update every hour
                if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                    (now-lastRequest > 3600000UL)){                 // request update every hour to keep in sync
                   // Request time from controller.
                   Serial.println("requesting time");
                   timeReceived = false;
                   lastRequest = now;
                // Change display and update sensors every 5 seconds (default = 5000)
                if (now-lastDisplay > 5000){
                    lastDisplay = now;
                    gw.request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                    gw.request(LCD2_CHILD, V_TEXT, 0);                ;// request new values from controller
                    // change display
                    display_no++;
                        if (display_no >= 2){ // wrap for number of different displays for second line
                        display_no = 0;
                // Update display every second
                if (now-lastUpdate > 1000) {
                    LCD_local_display();
                    lastUpdate = now;
                setTime(controllerTime);                            // time from controller
                timeReceived = true;
            // This is called when a message is received
                if (message.type==V_TEXT) {                         // Text messages only
                 Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                if (message.sensor == LCD1_CHILD ) {
                    snprintf(lastLCD1, sizeof(lastLCD1), "%16s", message.getString());  // load text into LCD string
                else if (message.sensor == LCD2_CHILD){
                    snprintf(lastLCD2, sizeof(lastLCD2), "%16s", message.getString());
            void LCD_local_display(void){
            // take car of LCD display information
                char buf[17]; // temp buffer for max 16 char display
                // start with location & time on first line
                snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
                lcd.print(buf);
                lcd.setCursor(0, 1);
                if (display_no == 0){
                  lcd.print(lastLCD1);                          // second line is text value from controller
                } else {                                        // display == 2
                  lcd.print(lastLCD2);
            Thxs
            AWIA 1 Reply Last reply
              Hi AWI,
              this is the sketch.
               PROGRAMMER: AWI
              Special:
              SUMMARY:
              void setup(void){
                  // Initializations
              void loop(void){
                  gw.process() ;
                     lastRequest = now;
                      lastDisplay = now;
                      // change display
                      display_no++;
                          display_no = 0;
                      lastUpdate = now;
                  lcd.print(buf);
              Thxs
              AWIA
              AWIA
              AWI
              #30
              @Marc-Olivier-Chaubet You should be receiving the TEXT value coming from the controller. Is node showing other information on serial?
                   Serial.print("Text Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
              In incomingmessage routing add a print statement to show which messages are coming in (see above).
                I've change this line with "!=" and it work. but i dont undestand why....?
                    if (message.type!=V_TEXT) {                         // Text messages only
                  AWIA
                  AWIA
                  AWI
                  @Marc-Olivier-Chaubet A closer look at what happens on you seria outputl:
                  0_1476200021647_upload-770a6b42-dfb9-43dc-b647-0957e02cc9b8
                  • on the first 2 lines there are 2 requests for values from your controller. The "t=47' indicates that the type is V_TEXT.
                  • on the the third line you receive a value with payload "test". however the 't=16' indicates that this is a V_TRIPPED value. (see Serial Protocol).
                  So there is something completely wrong. What is your controller and does it show the right types of sensors?
                  • Q Qu3Uk
                    @NiklasO
                    Here is it.
                    // LCD includes
                    // MYS includes
                    void before() {
                      lcd.begin ();
                      lcd.backlight();
                      text.trim();
                          text.remove(20);
                      // Clear the line
                      // Set Line
                      lcd.print(text);
                    user1306U
                    user1306U
                    user1306
                    @Qu3Uk
                    thank you very much for sharing your code.
                    sorry this might be simple but i'm not sure how do you send text to the display? How do you update V_VAR1 in domoticz?
                    thanks
                    • NiklasON
                      NiklasON
                      NiklasO
                      #34
                      This is my test code. Not optimized, just testing. I have just started to play with arduino (got my first ever this month) so I can't say I know what I am doing. ;) Made som changes in the code below, not tested yet. It compiles, guess that's good. ;)
                      I have commented out stuff related to line1 because that is always showing the time and date, in code, from GW/controller. Enable if you want to control all 4 lines from Domoticz.
                      Update display by using the domoticz api:
                      json.htm?type=command&param=udevice&idx=XXXX&nvalue=0&svalue=Banana
                      Replace XXXX with the IDX for each of the 3 lines. You'll see it when adding the 3 text devices in Domoticz. Then use the Event-system in Domoticz to add Lua-script to update the display as example in this thread.
                      //Credits: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
                      //Soft signing.
                      //#define MY_SIGNING_SOFT
                      #include <TimeLib.h>
                      //char lastLCD1[21] = "Line1"; //Line 1 always showing current time
                      char lastLCD2[21] = "Line2";
                      char lastLCD3[21] = "Line3";
                      char lastLCD4[21] = "Line4";
                      //20 whitespace characters used to clear your LCD line before printing to it.
                      //Change to fit your LCD. Don't forget to change number of chars in the writeScreen function if needed.
                      unsigned long lastUpdate = 0, lastRequest = 0, lastDisplay = 0;
                      //const byte LCD1_CHILD = 1;                          // Child ID for LCD line 1
                      const byte LCD2_CHILD = 2;                          // Child ID for LCD line 2
                      const byte LCD3_CHILD = 3;                          // Child ID for LCD line 3
                      const byte LCD4_CHILD = 4;                          // Child ID for LCD line 4
                      // Initialize display. Google the correct settings for your display.
                      // The follwoing setting should work for the recommended display in the MySensors "shop".
                      void before() {
                        Wire.begin();                                       // I2C.
                        lcd.begin(20, 4);                                   // LCD with 20 chars, 4 lines.
                        lcd.setBacklight(HIGH);                             // Make sure backlight is on.
                        writeScreen(0, "Waiting for GW...");                // Print initial text before contact with GW.
                      void setup(void)
                        Serial.begin(115200);                               // Start serial.
                        requestTime();                                      // Request time from controller.
                      void presentation()  {
                        sendSketchInfo("Domoticz LCD", "1.0");                    // Send the sketch version information to the gateway and Controller
                        //present(LCD1_CHILD, S_INFO, "LCD_line1");
                        //wait(500);
                        wait(500);
                        present(LCD3_CHILD, S_INFO, "LCD_line3");
                        wait(500);
                        present(LCD4_CHILD, S_INFO, "LCD_line4");
                        wait(500);
                        //send(textMsg.setSensor(LCD1_CHILD).set("-"));      // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                        send(textMsg.setSensor(LCD3_CHILD).set("-"));
                        send(textMsg.setSensor(LCD4_CHILD).set("-"));
                      void loop()     {
                        if ((!timeReceived && (now - lastRequest > 10 * 1000)) ||
                            (now - lastRequest > 3600000UL)) {              // request update from GW every hour to keep in sync
                          Serial.println("Requesting time...");
                          requestTime();
                          lastRequest = now;
                        // Update sensors every 5 seconds
                        if (now - lastDisplay > 5000) {
                          lastDisplay = now;
                          //request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                          request(LCD2_CHILD, V_TEXT, 0);                  // request new values from controller
                          request(LCD3_CHILD, V_TEXT, 0);                  // request new values from controller
                          request(LCD4_CHILD, V_TEXT, 0);                  // request new values from controller
                        // Update LCD time every second
                        if (now - lastUpdate > 1000) {
                          LCD_time();
                          lastUpdate = now;
                        if (message.type == V_TEXT) {                       // Text messages only
                          Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());     // Write some debug info
                          //if (message.sensor == LCD1_CHILD) {
                          //  writeScreen(0, message.data);
                      // Don't forget to change "if" to "else if" when controlling all 4 lines:
                          if (message.sensor == LCD2_CHILD) {
                          else if (message.sensor == LCD3_CHILD) {
                          else if (message.sensor == LCD4_CHILD) {
                        setTime(ts);
                      void LCD_time(void) {
                        if (timeReceived) {
                          lcd.print(year());
                          lcd.print("-");
                          printDigits(month());
                          lcd.print("-");
                          printDigits(day());
                          lcd.print("     ");
                          printDigits(hour());
                          lcd.print(":");
                          printDigits(minute());
                          writeScreen(0, "Waiting for time...");
                      void printDigits(int digits) {
                      //add leading 0 if digit = 0-9
                        if (digits < 10)
                          lcd.print('0');
                        lcd.print(digits);
                        if (text.length() > 19)
                          text.remove(20);
                        // Clear the line
                        // Set Line
                        lcd.print(text);
                      • user1306U user1306
                        @Qu3Uk
                        thanks
                        AWIA
                        AWIA
                        AWI
                        @user1306 V_VAR1 in Domoticz can not be updated or changed in Domotics (Blockly/ Lua/ Json, etc.). It's can only be used to store and retrieve values from MySensors. You should use V_TEXT as in the original example.
                        • user1306U
                          user1306U
                          user1306
                          thanks guy for the help,
                          what i'm trying to do, is send text to the display (16x2) using both lines (dont really need the time on top), and attach a 4 button keypad on it. then have these buttons sends commands (on.off) to Domoticz which will trigger Event and send that data/text back to the display.
                          if i manage to figure it out i'll post my code.
                          • AndurilA
                            AndurilA
                            Anduril
                            Is there a limitation in text length? I plan to use a bigger display and want to maybe send strings with 30+ chars. Is it impossible (maybe then split this into two strings) or is it internally seperated in 2 messages (as nrf-payload is 32 byte - 7 byte MySensors-header)?
                            • AndurilA Anduril
                              AWIA
                              AWIA
                              AWI
                              @Anduril The text length is limited to the maximum payload size. So I guess you need to do some tweaking ;)
                              sellierS 1 Reply Last reply
                              • AWIA AWI
                                sellierS
                                sellierS
                                sellier
                                Re: LCD Clock and Text sensor node with new V_TEXT
                                Hello ,
                                I have done the same exercise also with the LCD 4*20 and use the same program. It is great.
                                It works but only I have the first line with the date.
                                The lines 2,3,4 are empty.
                                In Domoticz my V_TEXT are created and filled in.
                                It seems that I can not read correctly the information LCD_line2, LCD_line3,LCD_line4
                                we can see that on the line READ , the text is V_TEXT but nothing is received.
                                Why ?
