  3. LCD Clock and Text sensor node with new V_TEXT
39 Posts 11 Posters 34.7k Views 21 Watching
  • user1306U user1306
    this is a great project thank you.
    just a quick question is there a way to be able to turn on and off the backlight with text received from domoticz?
    for example if i just send "1" then the back light goes on and "0" for off.
    thanks
    AWIA
    AWIA
    AWI
    @user1306 you can do anything with the text sent but be aware that this would imply you are making your own (non standard MySensors) protocol. V_TEXT is intended only for information.
    I am the 'misusing' it myself but only where there is no MySensors solution.
    user1306U 1 Reply Last reply
    • AWIA AWI
      user1306U
      user1306U
      user1306
      @AWI
      thank you for the info, i'm a bit new to arduino and my sensors, so i'm not really sure how to do that.
      if possible could you let me know what piece of code i need to be able to do that?
      thanks
      AWIA 1 Reply Last reply
        @AWI
        thanks
        AWIA
        AWIA
        AWI
        @user1306 This is a part from the routine where I read three values from a V_TEXT value (renamed to V_ORIENTATION) separated by a ";". (I think V_ORIENTATION would be a good addition for MySensors ;-) in addition to V_POSITION but I haven't suggested it officially yet)
        Also be aware that Domoticz only sends the V_TEXT after it has been requested. So you need to send a request(sensor_id, V_TEXT)first .
        #define V_ORIENTATION V_TEXT								// Own (not existing in MySensors protocol) type for orientation (payload = Pitch ; Roll ; Yaw in degrees)
        #define S_ORIENTATION S_INFO								// Yaw = 0 (north)to 360) ; Horizontal = 0 ;
        			if (message.type==V_ORIENTATION) {
        				char payload[12] ;								// temporary buffer
        				strcpy(payload, message.getString());			// read and copy payload
        				Yaw = atoi(strtok(payload, ";"));				// get variables from payload (; seperated int)
        				Pitch = atoi(strtok(NULL, ";"));
        				Roll = atoi(strtok(NULL, ";"));
        				attachServos(true) ;							// power up servo's
        				servoH.write(map(-constrain(Yaw, -90, 90),-90, 90, 0, 180));		// servo middle 90 deg == 0 deg Yaw
        				servoV.write(map(Pitch, -90, 90, 0, 180));
        • AWIA
          AWIA
          AWI
          On special request of @pepov attached a piece of LUA script for Domoticz. This demonstrates how to fill V_TEXT devices from other values so that thes can be displayed on the Text sensor node.
          This special example demonstrates how to fill V_TEXT with weather data from a virtual device connected to Weather Underground. Please search the Domoticz wiki for more information on this special service.
          -- script to read the virtual Weatherstation (Weather Underground) service and send it to "V_TEXT" MySensors devices
          -- Weather Underground values are in 'WUWeer' and 'WUWind'
          commandArray = {} ;
          --Weatherstation data:
          sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues['WUWeer']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") ;
          sWeatherTemp = tonumber(sWeatherTemp);
          sWeatherHumidity = tonumber(sWeatherHumidity);
          sWeatherUV = tonumber(sWeatherUV);
          sWeatherPressure = tonumber(sWeatherPressure);
          sWeatherUV2 = tonumber(sWeatherUV2);
          -- print to log
          print("Weather station: Temperature is " .. sWeatherTemp .. " ");
          print("Weather station: Humidity is " .. sWeatherHumidity .. " ");
          print("Weather station: UV is " .. sWeatherUV .. " ");
          print("Weather station: Pressure is " .. sWeatherPressure .. " ");
          print("Weather station: UV2 is " .. sWeatherUV2 .. " ");
          --Windmeter data:
          sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues['WUWind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") ;
          sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
          sWindDirection = (sWindDirection);
          sWindSpeed = tonumber(sWindSpeed);
          sWindGust = tonumber(sWindGust);
          sWindTemperature = tonumber(sWindTemperature);
          sWindFeel = tonumber(sWindFeel);
          print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
          print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
          print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
          print("Windmeter: Windgust is: " .. sWindGust .. " ");
          print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
          print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
          -- device numbers 725/ 873 and 872 are V_TEXT
          commandArray[1] = {['UpdateDevice'] = string.format ("725|0|out %4.1f\01 %2d\07 %4d\02\03  ", sWeatherTemp, sWeatherHumidity, sWeatherPressure)}
          commandArray[2] = {['UpdateDevice'] = string.format ("873|0|%2.1f:%3d:%4.1f", sWeatherTemp, sWeatherHumidity, sWeatherPressure)}
          commandArray[3] = {['UpdateDevice'] = string.format ("872|0|%3d:%4.1f:%4.1f:%4.1f:%4.1f", sWindDirectionDegrees, sWindSpeed/10 , sWindGust/10, sWindTemperature, sWindFeel)}
          return commandArray
          pepovP 1 Reply Last reply
          • AWIA AWI
            commandArray = {} ;
            -- print to log
            --Windmeter data:
            return commandArray
            pepovP
            pepovP
            pepov
            Wow Thanks AWI!!!!
            • NiklasON
              NiklasON
              NiklasO
              Does this work with MySensors 2.0? If someone has this running on 2.0, please share the code. :)
              Q 1 Reply Last reply
              • Marc-Olivier ChaubetM
                i try to send message but nothing change on LcdDisplay.
                I d'ont undestant what is wrong.
                Can you help me pls.
                send: 49-49-20-0 s=8,c=2,t=47,pt=0,l=0,sg=0,st=ok:
                send: 49-49-20-0 s=9,c=2,t=47,pt=0,l=0,sg=0,st=ok:
                read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:test
                send: 49-49-20-0 s=9,c=1,t=16,pt=0,l=4,sg=0,st=ok:test
                • NiklasON NiklasO
                  Q
                  Q
                  Qu3Uk
                  @NiklasO I have something similar running on MYS 2.0 and can paste the code. I'm using a 4x1 display and using V_VAR-1-4 to send each line over.
                  If that's useful to you I can post it.
                  NiklasON 1 Reply Last reply
                  • Q Qu3Uk
                    NiklasON
                    NiklasON
                    NiklasO
                    wrote on last edited by NiklasO
                    #26
                    Yes please. I ported to 2.0 late yesterday and it works ok. I have 4 lines, 20 chars.
                    • Marc-Olivier ChaubetM Marc-Olivier Chaubet
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #27
                      @Marc-Olivier-Chaubet Can you post a little more information (the sketch)?
                      The text seems to be arriving at the node. So first check if the information comes in on serial (Serial.print(....)).
                      And next: is your display working? just print something it in the local sketch.
                      • NiklasON NiklasO
                        Q
                        Q
                        Qu3Uk
                        @NiklasO
                        Here is it.
                        //#define MY_NODE_ID 200
                        #define MY_SENSOR_ID 1
                        #define MY_REPEATER_FEATURE
                        // LCD includes
                        // MYS includes
                        #define LCD_ON 1  // GPIO value to write to turn on attached relay
                        #define LCD_OFF 0 // GPIO value to write to turn off attached relay
                        LiquidCrystal_I2C lcd(0x3f, 20, 4); //0x3f is the LCD address.
                        String LINE_BLANK = "                    ";
                        void before() {
                          // Set off  LCD module
                          lcd.begin ();
                          lcd.backlight();
                          lcd.setCursor(0, 0); //
                          lcd.print("Ready!"); // We expect the controller to remove this from display.
                          sendSketchInfo("LCD Display", "1.0");
                          present(MY_SENSOR_ID, S_INFO);
                          // extra processing if required.
                            // Use V_STATUS to turn on/off the LCD display
                            // if supported by LCD.
                          // temp string, probably don't need this.
                          if (message.type == V_VAR1) {
                            writeScreen(0, message.data);
                          if (message.type == V_VAR2) {
                            writeScreen(1, message.data);
                          if (message.type == V_VAR3) {
                            writeScreen(2, message.data);
                          if (message.type == V_VAR4) {
                            writeScreen(3, message.data);
                        void writeScreen(int line, String text)
                          // Trim whitespace from incoming text.
                          text.trim();
                          // Remove anything over 20 char in text.
                          if(text.length() > 19)
                              text.remove(20);
                          // Clear the line
                          lcd.setCursor(0, line);
                          lcd.print(LINE_BLANK);
                          // Set Line
                          lcd.print(text);
                          wrote on last edited by Marc-Olivier Chaubet
                          #29
                          Hi AWI,
                          Yes my display is working, i can see the date and "Line 1 - First....."
                          I think what i send is not correct....0_o
                          This is from the serial monitor
                          Should it be something like this
                          read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:Line1=test
                          this is the sketch.
                           PROJECT: MySensors / LCD display for text from controller
                           PROGRAMMER: AWI
                           DATE: september 8, 2015/ last update: september 8, 2015
                           FILE: AWI_LCD_49.ino
                           LICENSE: Public domain
                           Hardware: tbd ..MYS Ceech - ATmega328p board w/ NRF24l01
                              and MySensors 1.5 ()
                          Special:
                              MySensors - Development (as of sept 2015)
                          SUMMARY:
                              display time & 2 lines of text from Controller Text sensors
                          #include <MyMessage.h>
                          #include <MySensor.h>                       // Mysensor network
                          #include <Time.h>                           //http://playground.arduino.cc/Code/Time
                          // uncomment if you are using the DEVELOPMENT version with V_TEXT & V_INFO defined (better to use development MyMessage.h)
                          const byte V_TEXT = 47 ;                  // values taken from development edition MyMessage.h
                          const byte S_INFO = 36 ;
                          const byte nodeId = 49 ;                    // MySensors fixed node id
                          const byte LCD1_CHILD = 8 ;                 // LCD line 1
                          const byte LCD2_CHILD = 9 ;                 // LCD line 2
                          char lastLCD1[21] = "Line1 - first   ";     // define & init before first receive
                          char lastLCD2[21] = "Line2 - second  ";
                          boolean timeReceived = false ;
                          // timers for loop delays
                          unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0;
                          int display_no = 0 ;                        // current display
                          // *** Definition and initialisation
                          // define the MySensor network
                          MyTransportNRF24 transport(9,10);           // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                          MySensor gw(transport);
                          // Initialize messages for sensor network
                          MyMessage textMsg(0, V_TEXT);
                          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                          // OPTIONAL: Custom characters for display - Units)
                          byte heart[8] = { B00000, B01010, B11111, B11111, B01110, B00100, B00000, B00000};
                          void setup(void){
                              //Serial in Sensor network = 115200
                              gw.begin(incomingMessage, nodeId);                  // this node is 49 fixed
                              //Send the sensor node sketch version information to the gateway
                              gw.sendSketchInfo("AWI_LCD text 49", "1.1");
                              gw.present(LCD1_CHILD, S_INFO, "LCD_line1");        // new S_type 20150905 (not know by domoticz)
                              gw.present(LCD2_CHILD, S_INFO, "LCD_line2");
                              gw.send(textMsg.setSensor(LCD1_CHILD).set("-"));    // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                              gw.send(textMsg.setSensor(LCD2_CHILD).set("-"));
                              // Initializations
                              gw.requestTime(receiveTime);                        // get the time from controller (handled by receiveTime)
                              // ** LCD display **
                              Wire.begin();                                       // I2C
                              lcd.begin(16, 2);                                   // LCD 2 lines * 16 char.
                              lcd.setBacklight(HIGH);
                              lcd.createChar(1, heart);
                              // lcd.write(byte(0)); // write units
                          void loop(void){
                              // timer for loop delays
                              unsigned long now = millis();
                              gw.process() ;
                              // If no time has been received yet, request it every 10 second from controller
                              // When time has been received, request update every hour
                              if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                                  (now-lastRequest > 3600000UL)){                 // request update every hour to keep in sync
                                 // Request time from controller.
                                 Serial.println("requesting time");
                                 timeReceived = false;
                                 lastRequest = now;
                              // Change display and update sensors every 5 seconds (default = 5000)
                              if (now-lastDisplay > 5000){
                                  lastDisplay = now;
                                  gw.request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                                  gw.request(LCD2_CHILD, V_TEXT, 0);                ;// request new values from controller
                                  // change display
                                  display_no++;
                                      if (display_no >= 2){ // wrap for number of different displays for second line
                                      display_no = 0;
                              // Update display every second
                              if (now-lastUpdate > 1000) {
                                  LCD_local_display();
                                  lastUpdate = now;
                              setTime(controllerTime);                            // time from controller
                              timeReceived = true;
                          // This is called when a message is received
                              if (message.type==V_TEXT) {                         // Text messages only
                               Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                              if (message.sensor == LCD1_CHILD ) {
                                  snprintf(lastLCD1, sizeof(lastLCD1), "%16s", message.getString());  // load text into LCD string
                              else if (message.sensor == LCD2_CHILD){
                                  snprintf(lastLCD2, sizeof(lastLCD2), "%16s", message.getString());
                          void LCD_local_display(void){
                          // take car of LCD display information
                              char buf[17]; // temp buffer for max 16 char display
                              // start with location & time on first line
                              snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
                              lcd.print(buf);
                              lcd.setCursor(0, 1);
                              if (display_no == 0){
                                lcd.print(lastLCD1);                          // second line is text value from controller
                              } else {                                        // display == 2
                                lcd.print(lastLCD2);
                          Thxs
                            Hi AWI,
                            this is the sketch.
                             PROGRAMMER: AWI
                            Special:
                            SUMMARY:
                            void setup(void){
                                // Initializations
                            void loop(void){
                                gw.process() ;
                                   lastRequest = now;
                                    lastDisplay = now;
                                    // change display
                                    display_no++;
                                        display_no = 0;
                                    lastUpdate = now;
                                lcd.print(buf);
                            Thxs
                            AWIA
                            AWIA
                            AWI
                            #30
                            @Marc-Olivier-Chaubet You should be receiving the TEXT value coming from the controller. Is node showing other information on serial?
                                 Serial.print("Text Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                            In incomingmessage routing add a print statement to show which messages are coming in (see above).
                              I've change this line with "!=" and it work. but i dont undestand why....?
                                  if (message.type!=V_TEXT) {                         // Text messages only
                                AWIA
                                AWIA
                                AWI
                                @Marc-Olivier-Chaubet A closer look at what happens on you seria outputl:
                                0_1476200021647_upload-770a6b42-dfb9-43dc-b647-0957e02cc9b8
                                • on the first 2 lines there are 2 requests for values from your controller. The "t=47' indicates that the type is V_TEXT.
                                • on the the third line you receive a value with payload "test". however the 't=16' indicates that this is a V_TRIPPED value. (see Serial Protocol).
                                So there is something completely wrong. What is your controller and does it show the right types of sensors?
                                • Q Qu3Uk
                                  @NiklasO
                                  Here is it.
                                  // LCD includes
                                  // MYS includes
                                  void before() {
                                    lcd.begin ();
                                    lcd.backlight();
                                    text.trim();
                                        text.remove(20);
                                    // Clear the line
                                    // Set Line
                                    lcd.print(text);
                                  user1306U
                                  user1306U
                                  user1306
                                  @Qu3Uk
                                  thank you very much for sharing your code.
                                  sorry this might be simple but i'm not sure how do you send text to the display? How do you update V_VAR1 in domoticz?
                                  thanks
                                  • NiklasON
                                    NiklasON
                                    NiklasO
                                    #34
                                    This is my test code. Not optimized, just testing. I have just started to play with arduino (got my first ever this month) so I can't say I know what I am doing. ;) Made som changes in the code below, not tested yet. It compiles, guess that's good. ;)
                                    I have commented out stuff related to line1 because that is always showing the time and date, in code, from GW/controller. Enable if you want to control all 4 lines from Domoticz.
                                    Update display by using the domoticz api:
                                    json.htm?type=command&param=udevice&idx=XXXX&nvalue=0&svalue=Banana
                                    Replace XXXX with the IDX for each of the 3 lines. You'll see it when adding the 3 text devices in Domoticz. Then use the Event-system in Domoticz to add Lua-script to update the display as example in this thread.
                                    //Credits: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
                                    //Soft signing.
                                    //#define MY_SIGNING_SOFT
                                    #include <TimeLib.h>
                                    //char lastLCD1[21] = "Line1"; //Line 1 always showing current time
                                    char lastLCD2[21] = "Line2";
                                    char lastLCD3[21] = "Line3";
                                    char lastLCD4[21] = "Line4";
                                    //20 whitespace characters used to clear your LCD line before printing to it.
                                    //Change to fit your LCD. Don't forget to change number of chars in the writeScreen function if needed.
                                    unsigned long lastUpdate = 0, lastRequest = 0, lastDisplay = 0;
                                    //const byte LCD1_CHILD = 1;                          // Child ID for LCD line 1
                                    const byte LCD2_CHILD = 2;                          // Child ID for LCD line 2
                                    const byte LCD3_CHILD = 3;                          // Child ID for LCD line 3
                                    const byte LCD4_CHILD = 4;                          // Child ID for LCD line 4
                                    // Initialize display. Google the correct settings for your display.
                                    // The follwoing setting should work for the recommended display in the MySensors "shop".
                                    void before() {
                                      Wire.begin();                                       // I2C.
                                      lcd.begin(20, 4);                                   // LCD with 20 chars, 4 lines.
                                      lcd.setBacklight(HIGH);                             // Make sure backlight is on.
                                      writeScreen(0, "Waiting for GW...");                // Print initial text before contact with GW.
                                    void setup(void)
                                      Serial.begin(115200);                               // Start serial.
                                      requestTime();                                      // Request time from controller.
                                    void presentation()  {
                                      sendSketchInfo("Domoticz LCD", "1.0");                    // Send the sketch version information to the gateway and Controller
                                      //present(LCD1_CHILD, S_INFO, "LCD_line1");
                                      //wait(500);
                                      wait(500);
                                      present(LCD3_CHILD, S_INFO, "LCD_line3");
                                      wait(500);
                                      present(LCD4_CHILD, S_INFO, "LCD_line4");
                                      wait(500);
                                      //send(textMsg.setSensor(LCD1_CHILD).set("-"));      // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                                      send(textMsg.setSensor(LCD3_CHILD).set("-"));
                                      send(textMsg.setSensor(LCD4_CHILD).set("-"));
                                    void loop()     {
                                      if ((!timeReceived && (now - lastRequest > 10 * 1000)) ||
                                          (now - lastRequest > 3600000UL)) {              // request update from GW every hour to keep in sync
                                        Serial.println("Requesting time...");
                                        requestTime();
                                        lastRequest = now;
                                      // Update sensors every 5 seconds
                                      if (now - lastDisplay > 5000) {
                                        lastDisplay = now;
                                        //request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                                        request(LCD2_CHILD, V_TEXT, 0);                  // request new values from controller
                                        request(LCD3_CHILD, V_TEXT, 0);                  // request new values from controller
                                        request(LCD4_CHILD, V_TEXT, 0);                  // request new values from controller
                                      // Update LCD time every second
                                      if (now - lastUpdate > 1000) {
                                        LCD_time();
                                        lastUpdate = now;
                                      if (message.type == V_TEXT) {                       // Text messages only
                                        Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());     // Write some debug info
                                        //if (message.sensor == LCD1_CHILD) {
                                        //  writeScreen(0, message.data);
                                    // Don't forget to change "if" to "else if" when controlling all 4 lines:
                                        if (message.sensor == LCD2_CHILD) {
                                        else if (message.sensor == LCD3_CHILD) {
                                        else if (message.sensor == LCD4_CHILD) {
                                      setTime(ts);
                                    void LCD_time(void) {
                                      if (timeReceived) {
                                        lcd.print(year());
                                        lcd.print("-");
                                        printDigits(month());
                                        lcd.print("-");
                                        printDigits(day());
                                        lcd.print("     ");
                                        printDigits(hour());
                                        lcd.print(":");
                                        printDigits(minute());
                                        writeScreen(0, "Waiting for time...");
                                    void printDigits(int digits) {
                                    //add leading 0 if digit = 0-9
                                      if (digits < 10)
                                        lcd.print('0');
                                      lcd.print(digits);
                                      if (text.length() > 19)
                                        text.remove(20);
                                      // Clear the line
                                      // Set Line
                                      lcd.print(text);
                                      @Qu3Uk
                                      thanks
                                      AWIA
                                      AWIA
                                      AWI
                                      @user1306 V_VAR1 in Domoticz can not be updated or changed in Domotics (Blockly/ Lua/ Json, etc.). It's can only be used to store and retrieve values from MySensors. You should use V_TEXT as in the original example.
                                      • user1306U
                                        user1306U
                                        user1306
                                        thanks guy for the help,
                                        what i'm trying to do, is send text to the display (16x2) using both lines (dont really need the time on top), and attach a 4 button keypad on it. then have these buttons sends commands (on.off) to Domoticz which will trigger Event and send that data/text back to the display.
                                        if i manage to figure it out i'll post my code.
                                        • AndurilA
                                          AndurilA
                                          Anduril
                                          Is there a limitation in text length? I plan to use a bigger display and want to maybe send strings with 30+ chars. Is it impossible (maybe then split this into two strings) or is it internally seperated in 2 messages (as nrf-payload is 32 byte - 7 byte MySensors-header)?
