  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
  • cattooC cattoo
    So does this work with 2.0?
    @cattoo yes if it is converted.
    • cattooC
      cattooC
      cattoo
      What needs to be added/edited so its converted?
      • cattooC cattoo
        @cattoo that is described in the instructions I linked to :)
        • cattooC
          cattooC
          cattoo
          Its driving me crazy! Could you not convert this mfalkvidd! Its better to have your sketch on the front instead of that one there is there now.
          • cattooC cattoo
            #151
            @cattoo I won't convert it in the near future. I have too many projects that are more fun and more useful. My current setup works great, upgrading everything to 2.0 would mean a lot of work and no gain.
            • Martin TellblomM
              Martin TellblomM
              Martin Tellblom
              After my other failed attempt I needed to try this.
              I have a 5V Mini using A4 and A5 and a fork YL-69 and I get these result:
              Direction: 1
              Moist: 171
              Direction: 0
              Moist: 23
              Direction: 1
              Moist: 172
              Direction: 0
              Moist: 0
              Direction: 1
              Moist: 164
              Direction: 0
              Moist: 0
              Direction: 1
              Moist: 156
              Direction: 0
              Moist: 0
              Direction: 1
              Moist: 144
              Direction: 0
              Moist: 0
              This is not the percentage value , its this value I print: moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
              Any Ideas?
              MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
              • Martin TellblomM Martin Tellblom
                Direction: 1
                Moist: 171
                Direction: 0
                Moist: 23
                Direction: 1
                Moist: 172
                Direction: 0
                Moist: 0
                Direction: 1
                Moist: 164
                Direction: 0
                Moist: 0
                Direction: 1
                Moist: 156
                Direction: 0
                Moist: 0
                Direction: 1
                Moist: 144
                Direction: 0
                Moist: 0
                Any Ideas?
                @Martin-Tellblom could you describe what an YL-69 is?
                How much time do you let the measurement settle after switching directions?
                Which of the code versions are you using? There have been many revisions in this thread and they all work slightly different.
                Martin TellblomM 1 Reply Last reply
                  Martin TellblomM
                  Martin TellblomM
                  Martin Tellblom
                  wrote on last edited by Martin Tellblom
                  #154
                  @mfalkvidd said:
                  me do you le
                  My "Fork" is stamped with YL-69. Looks exacly like the XD-28
                  It's your code from post 25 so I suppose 1000 (#define STABILIZATION_TIME 1000 )
                    @mfalkvidd said:
                    me do you le
                    @Martin-Tellblom Thanks. You did throw away the middle chip and only use the fork, right? (as described in post 41)
                      Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      #156
                      @mfalkvidd : Yes I did, and I have tried using A2&A3 and its the same
                        @Martin-Tellblom can you try another Arduino?
                        • Martin TellblomM
                          Martin TellblomM
                          Martin Tellblom
                          @mfalkvidd
                          Have tried both a 3.3V and a 5V both behave the same.
                          I check every 30 seconds now and after about 10 minutes the result is 0 on both directions.
                          I restart the arduino and then one direction shows a value and the other 0.
                          There is proberbly something with my forks :)
                          Did I mention that I upgraded the sketch to 2.0? Could that be a problem?
                            @mfalkvidd
                            They are (or at least should be) completely passive, so there is nothing that should be able to go wrong.
                            Could you post a photo of your connections?
                            If you disconnect the fork from the Arduino and measure the resistance between the two connectors using a multimeter (in both directions), what resistance do you get?
                            Not if you did it right :) I have no experience with 2.0 unfortunately.
                            Martin TellblomM 2 Replies Last reply
                              Martin TellblomM
                              Martin TellblomM
                              Martin Tellblom
                              @mfalkvidd
                              I at the office right now, measure them when I home
                                Martin TellblomM
                                Martin TellblomM
                                Martin Tellblom
                                Here is my setup. Using the Easy/Newbie board that @sundberg84 created with a 5V arduino mini pro 16Mhz. Using A4 and A5 to the sensor
                                Regarding the resistance when its out of the soil there is no connection at all. If I put it in the soil there a strange thing happening .
                                The resistance start around 10K and then slowly increase (no matter if I switch the direction) the longer I test the higher value.
                                If I switch the direction the resistance start from whre it just was and keep rising . If I let the senor pause for a while (5 minutes or so) it's back to around 10K.
                                Maybe I test it to often? Don't let the moisture get back to the soil?
                                • mfalkviddM
                                  Stange. The setup looks good. The soil in my plants doesn't behave like that.
                                  • Martin TellblomM
                                    Martin TellblomM
                                    Martin Tellblom
                                    #163
                                    It seems like @sundberg84 nailed it :)
                                    The battey metering I use with his PCB is this:
                                      analogReference(INTERNAL1V1);
                                      analogReference(INTERNAL);
                                    And that reflect on all analog channels and break the function..
                                    After I removed the battery sensing code it work great
                                    • NetRapN
                                      NetRapN
                                      NetRap
                                      You should check out this side (Use Google Side Translator):
                                      https://github.com/Zentris/erdfeuchtemessung/wiki
                                      Theres also the sensor from here:
                                      Giesomat
                                      • mfalkviddM
                                        So my Bonsai tree humidity node just celebrated 1 year on battery! :tada: :gift_heart:
                                        During the last year, the gateway has received 76,164 updates on humidity level (and an additional 13,996 updates on voltage level).
                                        The battery level has gone from 3.187V to 3.108V, which means an average drop of 0.0066V per month. Assuming I let it go down to 2.34V (limit for 8MHz according to the datasheet) and that the voltage drop is linear, I should get (3.187-2.34)/0.0066 = 128 months = ~10.7 years. There are several error sources in this calculation, but it looks like battery life will be quite good.
                                        Here are the voltage and humidity graphs for the last year
                                        N 1 Reply Last reply
                                          N
                                          N
                                          Nicklas Starkel
                                          wrote on last edited by Nicklas Starkel
                                          #166
                                          @mfalkvidd that is really awesome!
                                          Did you set any Brown Out Fuses?
                                          From what I gather the arduino pro mini will stop working at 2.8V and you have to set other fuses for it to reach the lower voltages.
                                          I did a quick test with one flowerpot and from what I see my power consumption will be around 0.2V per year. It's more than double of what you're getting. But still low enough as changing 2 AA over 1-2 years is OK in my book if I'm not changing the fuses :)
                                          EDIT: Actually, calculating with your numbers of updates I get around 0.6V consumption per year for my setup and that is far from your low power consumption.
                                          I think I will have to go through this thread once more to try to find why the difference is so big and what you have done. I see 2 potential culprits. One is the arduino mini pro (china clone without power LED and voltage regulator) or maybe it could be my mysensors 2.0 version vs your 1.6.
