  2. Bug Reports
  3. [SOLVED] Network adres (MY_RF24_BASE_RADIO_ID) not loaded to NRF
5 Posts 2 Posters 2.8k Views 2 Watching
  • olo_25O Offline
    olo_25O Offline
    olo_25
    wrote on last edited by olo_25
    When using Arduino IDE and
    #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
    adres transfered to NRF is 0x0000000000
    this gives high to full rate of ack - lost (st=fail)
    simple solution is to change definition
    Y 1 Reply Last reply
    • olo_25O olo_25
      Y Offline
      Y Offline
      @olo_25 In the transition of MySensors 1.5 to 2.0.0 the radio ID name changed from BASE_RADIO_ID to MY_RF24_BASE_RADIO_ID.
      in 1.5 it was defined as an uint64_t, in 2.0.0 it is an array of bytes.
      Perhaps you forgot to convert this when transitioning to 2.0.0?
      • olo_25O Offline
        olo_25O Offline
        olo_25
        In Arduino IDE library not exist BASE_RADIO_ID, but now I see, definition is equal to my
        • olo_25O olo_25
          Y Offline
          Y Offline
          @olo_25 So, issue solved? ;-)
          • olo_25O Offline
            olo_25O Offline
            olo_25
            Solved.
            Was solved at start :wink:
            This is only info for other, I not found info about change of definition when migrating
