  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • xliborX xlibor
    Hi all, i am new in mysensors, but i have problem with install this plugin to OpenHab2.0 i tried versions 2.0 and 2.0b4 but i couldn't see this plugin in OpenHab2, i tried with RPi B, RPi3 with Raspian Jessie, and with Windows 10. But all with the same result.
    I placed org.openhab.binding.mysensors-2.0.0.SNAPSHOT.jar into addons directory, but i can't se it in OpenHab.
    Can anyone help me?
    TimO
    @xlibor Did you follow the instructions on the wiki and installed serial transport first? Is there a log file entry? How did you install OH2? Debian Package or Zip File?
    xliborX 2 Replies Last reply
    • T TimO
      xliborX
      xliborX
      xlibor
      • T TimO
        xliborX
        xliborX
        xlibor
        wrote on last edited by xlibor
        #269
        @TimO Yes, i follow instruction on wiki and install serial transport sucesfully. I tried both types, first zip file and next package, but both with the same result :-(
        In log file is nothing about mysensors or any error.
        Now i downloaded again from github and now all works without any problem. But i don't know where was problem.
        • daxjonesD
          daxjonesD
          daxjones
          Hey All. Newbie alert here. I love the work you all do on here and this project is so exciting. I'm hooked after 2 weeks of 'fettling' and building sensors.
          I've hit a brick wall though. after struggling with openhab1 I decided to make the leap straight to openhab2. Although in early days of testing it seems immediately abit more user friendly.
          What I've done so far...
          RaspberryPi3 is acting as controller with openhab2 installed and running fine. bindings to TV and Nest thermostat all working lovely.
          Clone arduino Uno's with capacitors added for radio with NRF24 radio cards
          Created GatewayW5100 gateway using the mysensors library sketch for it and set static IP to 192.168.0.11 (Openhab2 is set to 192.168.0.10) and my router gives DHCP from 192.168.0.20 up
          created a temp and humidity sensor node and a node with a relay to turn a lamp on (both from mysensors library). Tested radio on all before moving ahead.
          Installed the mysensors binding on OH2
          Added a ethernet gateway
          disabled startup connection check as it kept failing to initialise and showed as offline
          Tried auto discovery of nodes... NOTHING
          Tried setting node ID manually on the arduinos.. Still NOTHING, even if i add a thing manually to OH2.
          I'm hoping i'm doing something stupid and its an easy fix.. Any pointers for a newbie??
          D.
          • daxjonesD daxjones
            D.
            TimO
            @daxjones
            Have you tried to reach your gateway with telnet?
            telnet 192.168.2.11 5003
            Does it respond? Do you see the messages from the node arriving?
            Have you enabled debug output of the binding like described in the wiki? What does the log say?
            FleischtorteF 1 Reply Last reply
            • T TimO
              @daxjones
              FleischtorteF
              FleischtorteF
              Fleischtorte
              Hi@TimO
              first, thanks for your awesome work :+1:
              On the weekend i switched from OH1 to OH2 and your binding is working just out of the box :)
              Im only missing the IR_Send and the V_TEXT sensor to integrate all of my sensors :(
              could you integrate them in your binding?
              • FleischtorteF Fleischtorte
                Hi@TimO
                TimO
                Thanks @Fleischtorte!
                There already was a request for IR and I've added one for V_TEXT.
                https://github.com/tobof/openhab2-addons/issues
                @andreacioni has done some serious refactoring of the code. After looking in the refactoring I'll add the missing sensors.
                • Meshx86M
                  Meshx86M
                  Meshx86
                  I have the following setup:
                  1. MQTT Gateway on Wemos D1 mini (ESP8266)
                  2. Node on Arduin pro mini
                  i can't get the openhab binding to distribute address to the nodes, in things in openhab there is no option for MQTT Gateway to add, what is the procedure ?
                  Q 1 Reply Last reply
                  • Meshx86M Meshx86
                    Q
                    Q
                    Qu3Uk
                    @Meshx86 the openhab binding doesnt support MQTT as far as I know.
                    If you are using the MQTT binding then you need another controller/method to provide the internal functions for my sensors. I use NodeRed workflow to listen for ID requests and it provides them.
                    Or static assign them in the node stretch.
                    • carlylerC
                      carlylerC
                      carlyler
                      @TimO: Thanks to you this weekend, while kids slept or napped, I managed to setup RPi gateway/controller with NRF24 and OH2.
                      Following the OH2 install instructions caused me some trouble, not sure why, but following your install instructions it came right up.
                      Thank you for the time and effort here.
                      • carlylerC
                        carlylerC
                        carlyler
                        Having a couple issues:
                        1. while adding 2nd node (tried power and temp/hum) OH2 would not assign node ID.
                        2. assigned node ID manually (ID=2) and OH2 recognized power node but will not respond to V_VAR1 request.
                        16:23:58.850 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;1;1;0;0;20.4
                        16:23:58.874 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.3
                        16:24:01.910 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:09.293 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
                        16:24:11.911 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:11.942 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                        16:24:19.736 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.7
                        16:24:21.912 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:26.987 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                        16:24:30.177 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
                        16:24:31.913 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:40.604 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
                        16:24:41.914 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:42.044 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                        16:24:51.916 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:24:57.102 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                        16:25:01.917 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:25:11.919 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:25:12.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                        16:25:21.921 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        16:25:22.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
                        Things:
                        Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {
                           humidity        hum01   [ nodeId="1", childId="0" ]
                           temperature     temp01  [ nodeId="1", childId="1" ]
                           power           power01 [ nodeId="2", childId="0" ]
                        Items:
                        Number hum01   "Humidity"              <humidity> { channel="mysensors:humidity:gateway:hum01:hum" }
                        Number temp01  "Temperature"           <temperature> { channel="mysensors:temperature:gateway:temp01:temp" }
                        Number temp01F "Temperature [%.1f °F]" <temperature>
                        DateTime Sensor01LastUpdate "Last seen [%1$ta %1$tR]" <clock>
                        DateTime Sensor02LastUpdate "Last seen [%1$ta %1$tR]" <clock>
                        Number watt01  "Current Demand [%.0f Watt]" { channel="mysensors:power:gateway:power01:watt" }
                        Number kwh01  "Daily Use [%.1f kWh]"        { channel="mysensors:power:gateway:power01:kwh" }
                        What am i doing wrong?
                        • carlylerC
                          carlylerC
                          carlyler
                          OK, I think I got past that, I reinstalled everything and cleaned up my MySensors libraries.There is a chance I was pulling from different version when compiling the different examples from different packages.
                          But, I noticed this exception at OH2 startup:
                          06:29:26.838 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                          06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 1, revertState: false
                          06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 0, revertState: false
                          06:29:26.932 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 2, chiledId: 0, revertState: false
                          06:29:26.951 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:hum01' changed from UNINITIALIZED to INITIALIZING
                          06:29:26.946 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                          06:29:26.956 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                          06:29:26.964 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:temp01' changed from UNINITIALIZED to INITIALIZING
                          06:29:26.969 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:power:gateway:power01' changed from UNINITIALIZED to INITIALIZING
                          06:29:26.993 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                          06:29:27.001 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/pts/3 [baudRate:115200]
                          06:29:27.032 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                          06:29:27.067 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
                          06:29:27.041 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:bridge-ser:gateway': java.lang.UnsupportedOperationException
                          java.util.concurrent.ExecutionException: java.lang.UnsupportedOperationException
                          	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
                          	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
                          	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                          	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                          	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                          	at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:755)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                          	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
                          	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
                          	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
                          	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
                          	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
                          	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
                          	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
                          Caused by: java.lang.UnsupportedOperationException
                          	at java.util.AbstractList.add(AbstractList.java:148)[:1.8.0_65]
                          	at java.util.AbstractList.add(AbstractList.java:108)[:1.8.0_65]
                          	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.loadCacheFile(MySensorsBridgeHandler.java:176)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                          	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:90)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                          	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:758)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                          	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                          	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                          	... 3 more
                          06:29:27.198 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/pts/3
                          06:29:27.232 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                          06:29:27.234 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                          06:29:29.428 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                          06:29:29.897 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                          06:29:30.262 [DEBUG] [rs.internal.protocol.MySensorsReader] - ;255;3;0;14;Gateway startup complete.
                          06:29:30.274 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "") on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                          06:29:30.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                          Things still seem to work, but do I have something wrong?
                          andreacioniA 1 Reply Last reply
                          • carlylerC carlyler
                            	... 3 more
                            andreacioniA
                            andreacioniA
                            andreacioni
                            Hi @carlyler :)
                            what version of JVM are you using? 1.7 or 1.8?
                            carlylerC 1 Reply Last reply
                            • andreacioniA andreacioni
                              Hi @carlyler :)
                              carlylerC
                              carlylerC
                              carlyler
                              @andreacioni after reading this thread I realized you have done a lot of work here as well, thank you.
                              I am running:
                              pi@raspberrypi:~ $ java -version
                              java version "1.8.0_65"
                              Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
                              Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
                              pi@raspberrypi:~ $
                              • H
                                H
                                hausinger
                                Hello community,
                                i have a small problem with openhab2 (on a orange pi with armbian - similar to raspberry) and mysensors Serial Gateway.
                                I installed openhab2 with the get methode and it works fine. I was able, to start it with openhab2.service (also automated) and openhab2 worked as it should. But if i want to connect the mysensors serial gateway to the orange pi with openhab2, openhab2 can't find my gateway. The log says "openhab is unable to connect to serial port, wrong serial port?"
                                But my serial port is ok.
                                If i stop openhab2.service and manual start openhab2, than all is fine, it can connect to serial gateway immediately and work fine. I don't know, why it can't work if openhab2 starts as service. Can you help me in this case?
                                Thank you.
                                And sorry for my english, it's not my first language
                                • H hausinger
                                  Hello community,
                                  Thank you.
                                  TimO
                                  @hausinger Sounds like a problem with the permissions. The openhab2 service is running as user and group openhab and this user needs permission to the serial port (dialout).
                                  sudo usermod -a -G dialout openhab
                                  • D
                                    Denke
                                    Hi all
                                    I have a problem when my raspberry pi and mysensors/openhab when i do a restart. The problems seems to be ralated to the serial gateway and that the openhab dont find it or has the wrong settings.
                                    Openhab starts when i make a reboot
                                    I checked the serial by typing
                                    stty -F /dev/ttyUSB0
                                    response was
                                    Seems here that the baudrate is wrong as my settings in the things file is
                                    What i did to make it work was just to change this to use baud 9600 and then back to baud = 115200
                                    after this it looked like
                                    And everything started to work nicely
                                    Does anyone now what the cause of this is and also how to fix it?
                                    RaspberryPi-Openhab
                                    • H
                                      H
                                      hausinger
                                      @ TimO thank you. That was the problem :)
                                      • FutureCowF
                                        FutureCowF
                                        FutureCow
                                        I have 2 simpel questions.
                                        1. What is the status of the PR for mysensors to get inside openhab native?
                                        2. What type of sensor do i need to use for a relay?
                                        • FutureCowF FutureCow
                                          TimO
                                          @FutureCow
                                          1. Sadly there is no progress at all: https://github.com/openhab/openhab2-addons/pull/1243 Till now nobody found the time to look into the PR.
                                          2. Use "Light" for a Relay. If you discover the device via PaperUI it will be represented as a "Light" (Switch).
                                          blaceyB T 2 Replies Last reply
