  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • T TimO
    @daxjones
    Have you tried to reach your gateway with telnet?
    telnet 192.168.2.11 5003
    Does it respond? Do you see the messages from the node arriving?
    Have you enabled debug output of the binding like described in the wiki? What does the log say?
    FleischtorteF
    FleischtorteF
    Fleischtorte
    Hi@TimO
    first, thanks for your awesome work :+1:
    On the weekend i switched from OH1 to OH2 and your binding is working just out of the box :)
    Im only missing the IR_Send and the V_TEXT sensor to integrate all of my sensors :(
    could you integrate them in your binding?
    • FleischtorteF Fleischtorte
      Hi@TimO
      TimO
      Thanks @Fleischtorte!
      There already was a request for IR and I've added one for V_TEXT.
      https://github.com/tobof/openhab2-addons/issues
      @andreacioni has done some serious refactoring of the code. After looking in the refactoring I'll add the missing sensors.
      • Meshx86M
        Meshx86M
        Meshx86
        I have the following setup:
        1. MQTT Gateway on Wemos D1 mini (ESP8266)
        2. Node on Arduin pro mini
        i can't get the openhab binding to distribute address to the nodes, in things in openhab there is no option for MQTT Gateway to add, what is the procedure ?
        Q 1 Reply Last reply
        • Meshx86M Meshx86
          Q
          Q
          Qu3Uk
          @Meshx86 the openhab binding doesnt support MQTT as far as I know.
          If you are using the MQTT binding then you need another controller/method to provide the internal functions for my sensors. I use NodeRed workflow to listen for ID requests and it provides them.
          Or static assign them in the node stretch.
          • carlylerC
            carlylerC
            carlyler
            @TimO: Thanks to you this weekend, while kids slept or napped, I managed to setup RPi gateway/controller with NRF24 and OH2.
            Following the OH2 install instructions caused me some trouble, not sure why, but following your install instructions it came right up.
            Thank you for the time and effort here.
            • carlylerC
              carlylerC
              carlyler
              Having a couple issues:
              1. while adding 2nd node (tried power and temp/hum) OH2 would not assign node ID.
              2. assigned node ID manually (ID=2) and OH2 recognized power node but will not respond to V_VAR1 request.
              16:23:58.850 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;1;1;0;0;20.4
              16:23:58.874 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.3
              16:24:01.910 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:09.293 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
              16:24:11.911 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:11.942 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
              16:24:19.736 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.7
              16:24:21.912 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:26.987 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
              16:24:30.177 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
              16:24:31.913 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:40.604 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
              16:24:41.914 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:42.044 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
              16:24:51.916 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:24:57.102 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
              16:25:01.917 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:25:11.919 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:25:12.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
              16:25:21.921 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
              16:25:22.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
              Things:
              Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {
                 humidity        hum01   [ nodeId="1", childId="0" ]
                 temperature     temp01  [ nodeId="1", childId="1" ]
                 power           power01 [ nodeId="2", childId="0" ]
              Items:
              Number hum01   "Humidity"              <humidity> { channel="mysensors:humidity:gateway:hum01:hum" }
              Number temp01  "Temperature"           <temperature> { channel="mysensors:temperature:gateway:temp01:temp" }
              Number temp01F "Temperature [%.1f °F]" <temperature>
              DateTime Sensor01LastUpdate "Last seen [%1$ta %1$tR]" <clock>
              DateTime Sensor02LastUpdate "Last seen [%1$ta %1$tR]" <clock>
              Number watt01  "Current Demand [%.0f Watt]" { channel="mysensors:power:gateway:power01:watt" }
              Number kwh01  "Daily Use [%.1f kWh]"        { channel="mysensors:power:gateway:power01:kwh" }
              What am i doing wrong?
              • carlylerC
                carlylerC
                carlyler
                OK, I think I got past that, I reinstalled everything and cleaned up my MySensors libraries.There is a chance I was pulling from different version when compiling the different examples from different packages.
                But, I noticed this exception at OH2 startup:
                06:29:26.838 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 1, revertState: false
                06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 0, revertState: false
                06:29:26.932 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 2, chiledId: 0, revertState: false
                06:29:26.951 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:hum01' changed from UNINITIALIZED to INITIALIZING
                06:29:26.946 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                06:29:26.956 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                06:29:26.964 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:temp01' changed from UNINITIALIZED to INITIALIZING
                06:29:26.969 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:power:gateway:power01' changed from UNINITIALIZED to INITIALIZING
                06:29:26.993 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                06:29:27.001 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/pts/3 [baudRate:115200]
                06:29:27.032 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                06:29:27.067 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
                06:29:27.041 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:bridge-ser:gateway': java.lang.UnsupportedOperationException
                java.util.concurrent.ExecutionException: java.lang.UnsupportedOperationException
                	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
                	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
                	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                	at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:755)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
                	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
                	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
                	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
                	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
                	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
                	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
                Caused by: java.lang.UnsupportedOperationException
                	at java.util.AbstractList.add(AbstractList.java:148)[:1.8.0_65]
                	at java.util.AbstractList.add(AbstractList.java:108)[:1.8.0_65]
                	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.loadCacheFile(MySensorsBridgeHandler.java:176)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:90)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:758)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                	... 3 more
                06:29:27.198 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/pts/3
                06:29:27.232 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                06:29:27.234 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                06:29:29.428 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                06:29:29.897 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                06:29:30.262 [DEBUG] [rs.internal.protocol.MySensorsReader] - ;255;3;0;14;Gateway startup complete.
                06:29:30.274 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "") on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                06:29:30.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                Things still seem to work, but do I have something wrong?
                andreacioniA 1 Reply Last reply
                • carlylerC carlyler
                  	... 3 more
                  andreacioniA
                  andreacioniA
                  andreacioni
                  Hi @carlyler :)
                  what version of JVM are you using? 1.7 or 1.8?
                  carlylerC 1 Reply Last reply
                  • andreacioniA andreacioni
                    Hi @carlyler :)
                    carlylerC
                    carlylerC
                    carlyler
                    @andreacioni after reading this thread I realized you have done a lot of work here as well, thank you.
                    I am running:
                    pi@raspberrypi:~ $ java -version
                    java version "1.8.0_65"
                    Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
                    Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
                    pi@raspberrypi:~ $
                    • H
                      H
                      hausinger
                      Hello community,
                      i have a small problem with openhab2 (on a orange pi with armbian - similar to raspberry) and mysensors Serial Gateway.
                      I installed openhab2 with the get methode and it works fine. I was able, to start it with openhab2.service (also automated) and openhab2 worked as it should. But if i want to connect the mysensors serial gateway to the orange pi with openhab2, openhab2 can't find my gateway. The log says "openhab is unable to connect to serial port, wrong serial port?"
                      But my serial port is ok.
                      If i stop openhab2.service and manual start openhab2, than all is fine, it can connect to serial gateway immediately and work fine. I don't know, why it can't work if openhab2 starts as service. Can you help me in this case?
                      Thank you.
                      And sorry for my english, it's not my first language
                      • H hausinger
                        Hello community,
                        Thank you.
                        TimO
                        @hausinger Sounds like a problem with the permissions. The openhab2 service is running as user and group openhab and this user needs permission to the serial port (dialout).
                        sudo usermod -a -G dialout openhab
                        • D
                          Denke
                          Hi all
                          I have a problem when my raspberry pi and mysensors/openhab when i do a restart. The problems seems to be ralated to the serial gateway and that the openhab dont find it or has the wrong settings.
                          Openhab starts when i make a reboot
                          I checked the serial by typing
                          stty -F /dev/ttyUSB0
                          response was
                          Seems here that the baudrate is wrong as my settings in the things file is
                          What i did to make it work was just to change this to use baud 9600 and then back to baud = 115200
                          after this it looked like
                          And everything started to work nicely
                          Does anyone now what the cause of this is and also how to fix it?
                          RaspberryPi-Openhab
                          • H
                            H
                            hausinger
                            @ TimO thank you. That was the problem :)
                            • FutureCowF
                              FutureCowF
                              FutureCow
                              I have 2 simpel questions.
                              1. What is the status of the PR for mysensors to get inside openhab native?
                              2. What type of sensor do i need to use for a relay?
                              • FutureCowF FutureCow
                                TimO
                                @FutureCow
                                1. Sadly there is no progress at all: https://github.com/openhab/openhab2-addons/pull/1243 Till now nobody found the time to look into the PR.
                                2. Use "Light" for a Relay. If you discover the device via PaperUI it will be represented as a "Light" (Switch).
                                blaceyB T 2 Replies Last reply
                                • T TimO
                                  @FutureCow
                                  blaceyB
                                  blaceyB
                                  blacey
                                  @TimO I took a quick look at your pull request (personal curiosity) and noticed that one of your committed files includes a merge conflict - you probably want to fix that before the OpenHab team accepts your PR.
                                  • T TimO
                                    @FutureCow
                                    TimO
                                    Hey @blacey, thank you for peeking in. :D
                                    I haven't touched the PR for a long time, but it will be necessary soon because there were a lot changes in the development branch. I will fix that too!
                                    blaceyB 1 Reply Last reply
                                    • T TimO
                                      blaceyB
                                      blaceyB
                                      blacey
                                      @TimO Nice! While I have been a longtime Vera user, I think my next move will be OpenHab. I sponsored the Pine64 project on KickStarter and have one sitting on my project desk ready for some prototyping. I think it is great that you are making MySensors a first-class OpenHab 2.0 citizen. Hopefully Kai or one of the OpenHab contributors will merge your binding into the distro.
                                      • undeeU
                                        undeeU
                                        undee
                                        @TimO It seems the binding does not support autoupdate="false" yet. Can you confirm this and do you consider adding this option? I could use the MQTT binding to get what I want (for example feedback of rollershutter position while moving based on the value sent by the sensor and not based on the command sent via the UI), but I don't want to move away from the MySensors binding.
                                        • ben999B
                                          ben999B
                                          ben999
                                          wrote on last edited by ben999
                                          #291
                                          Hi All
                                          Big thumb up to all those who made it possible, awsome job here
                                          Truely amazing for us diyers to have access to that technology so easily. Thanks a lot
                                          BUT! I have a problem with binding... in short :
                                          1- I installed openhab2 on RPi3 with a fresh SDCard
                                          2-Updated java (as per https://community.openhab.org/t/my-openhab-connectio-failed/12957/11)
                                          3- I followed tobof 's excellent step-by-step howto
                                          4- I installed mysGateway (RPi acting as controller AND gateway)
                                          5- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well
                                          mysGateway: Starting gateway...
                                          mysGateway: Protocol version - 2.0.1-beta
                                          mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                          mysGateway: TSF:LRT:OK
                                          mysGateway: TSM:INIT
                                          mysGateway: TSM:INIT:TSP OK
                                          mysGateway: TSM:INIT:GW MODE
                                          mysGateway: TSM:READY
                                          mysGateway: MCO:REG:NOT NEEDED
                                          mysGateway: MCO:BGN:STP
                                          mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                          mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                          mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          6- created a thing (text editor) for the bridge pi@raspberrypi:/usr/share/openhab2/conf/things $ nano home.things
                                          Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
                                          7- Following openhab2 "live" log with pi@raspberrypi:/usr/share/openhab2 $ sudo ./start_debug.sh
                                          05:37:32.536 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
                                          05:37:32.561 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
                                          05:37:32.789 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.MySensorsHandlerFactory, component.id=0, service.id=110, service.bundleid=10, service.scope=bundle} - org.openhab.binding.mysensors
                                          05:37:50.539 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
                                          05:37:58.611 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
                                          05:37:59.319 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
                                          05:37:59.664 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-ser:gateway' has been added.
                                          05:38:00.412 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=232, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
                                          05:38:00.435 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:bridge-ser, thing.id=mysensors:bridge-ser:gateway, service.id=233, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
                                          05:38:00.473 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                                          05:38:00.474 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors Bridge
                                          05:38:00.594 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MotionTest-mysensors:motion:1584d6773a3:armed' has been added.
                                          05:38:00.605 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MotionTest-mysensors:motion:1584d6773a3:tripped' has been added.
                                          RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyAMA0
                                          05:38:00.658 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                                          05:38:00.677 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
                                          05:38:05.333 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                          05:38:06.180 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                          05:38:08.009 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
                                          05:38:08.223 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                                          05:38:08.951 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                                          05:38:09.203 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                          05:38:11.343 [INFO ] [o.myopenhab.internal.MyOpenHABClient] - Connected to my.openHAB service (UUID = 7c0faa03-e826-473a-b1f7-8b685b487bb8, base URL = http://localhost:8080)
                                          Looks pretty to me...
                                          8- but then i try to register my sensor (arduino pro and 501PIR sensor) with paper UI
                                          No luck. Discovery window stays on forever!
                                          sudo usermod -a -G dialout openhab returns "unknown user" ...
                                          Any clue ?
                                          Thanks a lot for your help !
