  3. Azure IoT ?
Azure IoT ?
13 Posts 4 Posters 6.6k Views 6 Watching
  • Martin TellblomM Martin Tellblom
    Anyone tried to make a MySensors gateway for Azure IoT?
    TheoLT
    TheoLT
    TheoL
    @Martin-Tellblom Take a look at https://evothings.com/is-it-possible-to-secure-micro-controllers-used-within-iot/ article.
    • Martin TellblomM
      Martin TellblomM
      Martin Tellblom
      @TheoL said:
      ed a T
      I have the code to do it on a arduino, but I need to MySensors it :)
      Just wondered if anyone else already done this so I didn't had to do it
      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      TheoLT 1 Reply Last reply
        @TheoL said:
        ed a T
        TheoLT
        TheoLT
        TheoL
        @Martin-Tellblom I think you only need to change the MQTT wifi gateway. But I'm a bit worried about the amount of available memory...
        • Q
          Q
          Qu3Uk
          I'd be interested to know what you have planned with Azure IoT once you've got the data in to it? Not had time to investigate myself.
          I'd go with NodeRed in between a local MQTT server and Azure IoT as going direct to Azure puts a dependency on the internet connection.
          • Q Qu3Uk
            TheoLT
            TheoLT
            TheoL
            @Qu3Uk I went for the same solution when I tried to hook up MySensors to AWS. But wasn't able to get Node Red configures with Amazon's TLS certificate. Still curious how to get that going.
            I just wanted to prove that we can connect MySensors to the cloud. With a home brew Python script I was able to post my sensor values to Amazon's cloud. Why? Because it was fun and it can be done.
            • Q
              Q
              Qu3Uk
              Ha, I agree with this! Just curious about the fun after connecting it up.
              There was a Node Red update the other week BTW, version 0.15
              • Q Qu3Uk
                TheoLT
                TheoLT
                TheoL
                @Qu3Uk Great. @Yveaux had some nice add-ons for Node red. Do you have a link to that one for us @Yveaux?
                • TheoLT TheoL
                  @TheoL which ones are you referring to?
                  • YveauxY Yveaux
                    TheoLT
                    TheoLT
                    TheoL
                    @Yveaux The ones like the extended motion you showed during the Dutch meetup. I really liked that one.
                    • TheoLT TheoL
                      @TheoL eeeeehhhrrrmmm.... That's just basic node-red nodes linked together. No magic there :blush:
                      • YveauxY Yveaux
                        TheoLT
                        TheoLT
                        TheoL
                        @Yveaux Hmm I couldn't find them in my Node Red setup. Will have a look at that later on. Thank you.
