  3. 433mhz transmitter
433mhz transmitter
16 Posts 9 Posters 8.7k Views 9 Watching
  • M Offline
    M Offline
    Matt
    wrote on last edited by Matt
    Its kinda kludgy (of course- I made it!) but it works. As usual full of bits pinched from elsewhere....
    I am using this to control 4 effergy wall outlets. I already have mains switching ability but it's made by me and I am nervous about fire, so I figured this was a good compromise.
    I have some cheap 433 transmitters and receivers. Used the RCSwitch library to capture the codes. I have only got one switch functional at the moment but to add the rest is trivial. My coding Im sure is crap but it works.
    I have soldered a wee wire to the transmitter 12CM long and have no issues with range. I like the 'repeat command x times' function in the RCSwitch library, kinda makes not having feedback a non issue.
    #include <RCSwitch.h>
    #define NUMBER_OF_PLUGS 4 // Total number of attached plugs
    #define CODE_1On 1290271
    #define CODE_1Off 1290263
    #define CODE_2On 1290267
    #define CODE_2Off 1290259
    #define CODE_3On 1290269
    #define CODE_3Off 1290261
    #define CODE_4On 1290270
    #define CODE_4Off 1290262
    RCSwitch mySwitch = RCSwitch();
      mySwitch.enableTransmit(4);
      mySwitch.setRepeatTransmit(15);
      sendSketchInfo("433mhz switch", "1.0");
      for (int sensor=1 ; sensor<=NUMBER_OF_PLUGS;sensor++) {
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
      int incomingLightState =  message.getBool();
      int incomingOutlet = message.sensor;
      Serial.print("Outlet #: ");
      Serial.print("Command: ");
     if (incomingOutlet==1) {
     if (incomingLightState==1) {
        // Turn on  socket 1
        Serial.println("Turn on Socket 1");
     mySwitch.send(CODE_1On, 24); // These codes are unique to each outlet
     delay(50);
     if (incomingLightState==0)  {
        // Turn off socket 1
     Serial.println("Turn off Socket 1");
    mySwitch.send(CODE_1Off, 24);
    delay(50);
     if (incomingOutlet==2) {
        // Turn on  socket 2
        Serial.println("Turn on Socket 2");
    mySwitch.send(CODE_2On, 24);
     delay(50);
        // Turn off socket 2
     Serial.println("Turn off Socket 2");
    mySwitch.send(CODE_2Off, 24);
    delay(50);
     if (incomingOutlet==3) {
        // Turn on  socket 3
        Serial.println("Turn on Socket 3");
    mySwitch.send(CODE_3On, 24);
     delay(50);
        // Turn off socket 3
     Serial.println("Turn off Socket 3");
    mySwitch.send(CODE_3Off, 24);
    delay(50);
     if (incomingOutlet==4) {
        // Turn on  socket 4
        Serial.println("Turn on Socket 4");
     mySwitch.send(CODE_4On, 24);
     delay(50);
        // Turn off socket 4
     Serial.println("Turn off Socket 4");
    mySwitch.send(CODE_4Off, 24);
    delay(50);
     delay(50);
    Boots33B kchestK 2 Replies Last reply
    • M Matt
          // Turn on  socket 1
       delay(50);
      delay(50);
          // Turn on  socket 2
       delay(50);
      delay(50);
          // Turn on  socket 3
       delay(50);
      delay(50);
          // Turn on  socket 4
       delay(50);
      delay(50);
       delay(50);
      Boots33B Offline
      Boots33B Offline
      Boots33
      @Matt Great work... I may have to dust off some of my old Watts Clever sockets and give this a try :)
      • M Offline
        M Offline
        Matt
        Thanks Boots. One thing I noticed was that three out of five of the receivers I bought did not work. If fact one heated up real quick. So buy a few cos QC in China is pants.
        • thazlett144T Offline
          thazlett144
          Nice! I did something very similar! I used rcswitch and sent the codes directly to the controller. That way I could use the codes received as scene toggles in domoticz. I had another sketch doing the TX part though. I have since retired that set up in favour of rflink for controlling my 433MHz stuff.
          • TON RIJNAARDT Offline
            TON RIJNAARD
            Can some one give me a electric schematic for this sketch , or a place where i can find it.
            • M Offline
              M Offline
              Matt
              Hi Ton
              First of all I got a bunch (five) of these
              Im glad I got five because four of the transmitters did not work.
              If you have the effergy plugs these codes will work otherwise you need to sniff them out as per this
              instructable. Note I am using pin 4 for the transmitter, not 12 (the line mySwitch.enableTransmit(4); in code)
              The NRF24L01 is wired up as per the instructions on this site.
              Hope it all makes sense.
              • D Offline
                Just a note for those in the US. The 433 MHz stuff is for European use. Though it would probably work in the US, it is technically not legal according to FCC rules. Here is a version of the transmitters legal for use in the US. This should be a drop in replacement for the 433MHz version, but double check the pins if you do purchase these.
                • M Matt
                      // Turn on  socket 1
                   delay(50);
                  delay(50);
                      // Turn on  socket 2
                   delay(50);
                  delay(50);
                      // Turn on  socket 3
                   delay(50);
                  delay(50);
                      // Turn on  socket 4
                   delay(50);
                  delay(50);
                   delay(50);
                  kchestK Offline
                  kchestK Offline
                  kchest
                  @Matt I used your code as a basis to control some 433Mhz outlets from Aldi (in Germany). The system is their "Easy Home" brand, made by Globaltronics. The model designation is GT-9000. It needed a few tweeks from your code. In case anyone else has, or will get, this package, here is the code (pay attention to the "void setup" section):
                  #define CODE_1On "110001010000001101110000"
                  #define CODE_1Off "110011011100000100010000"
                  #define CODE_2On "110001010000001101110100"
                  #define CODE_2Off "110011011100000100010100"
                  #define CODE_3On "110001010000001101111100"
                  #define CODE_3Off "110011011100000100011100"
                  #define CODE_4On "110001010000001101110010"
                  #define CODE_4Off "110011011100000100010010"
                    mySwitch.setRepeatTransmit(3);
                    mySwitch.setPulseLength(510);
                    mySwitch.setProtocol(5);
                      // Turn on  socket 1
                   mySwitch.send(CODE_1On); // These codes are unique to each outlet
                   delay(50);
                  mySwitch.send(CODE_1Off);
                  delay(50);
                      // Turn on  socket 2
                  mySwitch.send(CODE_2On);
                   delay(50);
                  mySwitch.send(CODE_2Off);
                  delay(50);
                      // Turn on  socket 3
                  mySwitch.send(CODE_3On);
                   delay(50);
                  mySwitch.send(CODE_3Off);
                  delay(50);
                      // Turn on  socket 4
                   mySwitch.send(CODE_4On);
                   delay(50);
                  mySwitch.send(CODE_4Off);
                  delay(50);
                   delay(50);
                  • kchestK kchest
                        // Turn on  socket 1
                     delay(50);
                    delay(50);
                        // Turn on  socket 2
                     delay(50);
                    delay(50);
                        // Turn on  socket 3
                     delay(50);
                    delay(50);
                        // Turn on  socket 4
                     delay(50);
                    delay(50);
                     delay(50);
                    T Offline
                    T Offline
                    TheoL
                    @kchest Great. I have some of those aldi one's laying around doing nothing. Because I couldn't control them with my RFElink. I'll give your sketch a try.
                    kchestK 1 Reply Last reply
                    • T TheoL
                      kchestK Offline
                      kchestK Offline
                      kchest
                      @TheoL A couple of things to note:
                      I hooked up the 433Mhz transmitter to pin 4.
                      The device didn't show up under the MySensor section of the Hardware tab. However all 4 plugs appeared in the Devices list. Strange but it works.
                      TommiT 1 Reply Last reply
                      • kchestK kchest
                        TommiT Offline
                        TommiT Offline
                        Tommi
                        @kchest
                        I tried to switch the 433MHZ outlets from the "Intertechno / Brennenstuhl", but unfortunately does not work. I have changed the "pulse length" and the "protocol":
                        MySwitch.setPulseLength (320);
                        MySwitch.setProtocol (1);
                        Do you have any experience with these outlets?
                        • TommiT Tommi
                          @kchest
                          T Offline
                          T Offline
                          TimO
                          @Tommi I've outlets from Intertechno (IT-1500) running fine for over a year now.
                          The outlets have to learn the code, so shortly after pluggin in, when the led on the outlet blinks, send an ON from your MySensors node.
                          Here is my sketch (its a combination of DHT22, 12V LED/PWM Switch and 433 MHz node):
                          #define MY_DEFAULT_RX_LED_PIN 7
                          #define MY_DEFAULT_TX_LED_PIN 6
                          #define MY_DEFAULT_ERR_LED_PIN 4
                          #define MY_NODE_ID 106
                          #include "RCSwitch.h"
                          #define CHILD_ID_HUM 0
                          #define CHILD_ID_TEMP 1
                          #define CHILD_ID_PWM_LIGHT 3
                          #define CHILD_ID_433_1 4
                          #define CHILD_ID_433_2 5
                          #define CHILD_ID_433_3 6
                          #define CHILD_ID_433_4 7
                          #define CHILD_ID_433_5 8
                          #define CHILD_ID_433_6 9
                          #define HUMIDITY_SENSOR_DIGITAL_PIN 8
                          #define PWM_LIGHT_PIN 5
                          unsigned long NEXT_CHECK = 0;
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          boolean metric = true;
                          MyMessage msgPWM(CHILD_ID_PWM_LIGHT, V_STATUS);
                            pinMode(PWM_LIGHT_PIN, OUTPUT);
                            digitalWrite(PWM_LIGHT_PIN, LOW);
                            mySwitch.enableTransmit(A0);
                            sendSketchInfo("GuestCombiSensor", "2.0");
                            present(CHILD_ID_HUM, S_HUM);
                            present(CHILD_ID_PWM_LIGHT, S_LIGHT);
                            present(CHILD_ID_433_1, S_LIGHT);
                            present(CHILD_ID_433_2, S_LIGHT);
                            present(CHILD_ID_433_3, S_LIGHT);
                            present(CHILD_ID_433_4, S_LIGHT);
                            present(CHILD_ID_433_5, S_LIGHT);
                            present(CHILD_ID_433_6, S_LIGHT);
                           readDHT();
                           wait(SLEEP_TIME);
                          void readDHT() {
                            if (isnan(temperature)) {
                              lastTemp = temperature;
                              if (!metric) {
                              Serial.print("T: ");
                            if (isnan(humidity)) {
                                lastHum = humidity;
                                Serial.print("H: ");
                                Serial.println(humidity);
                          void changeSwitchStatus(char familyCode, int group, int device, bool status, int retries) {
                            for(int i = 0; i < retries; i++) {
                              if(status) {
                                mySwitch.switchOn(familyCode, group, device);
                                mySwitch.switchOff(familyCode, group, device);
                              wait(50);
                               if(message.sensor==CHILD_ID_PWM_LIGHT) {
                                  if(message.getBool())
                                    digitalWrite(PWM_LIGHT_PIN, HIGH);
                               } else if(message.sensor==CHILD_ID_433_1) {
                                  changeSwitchStatus('a', 1, 1, message.getBool(), 3);
                               } else if(message.sensor==CHILD_ID_433_2) {
                                  changeSwitchStatus('a', 1, 2, message.getBool(), 3);
                               } else if(message.sensor==CHILD_ID_433_3) {
                                  changeSwitchStatus('a', 1, 3, message.getBool(), 3);
                               } else if(message.sensor==CHILD_ID_433_4) {
                                  changeSwitchStatus('a', 2, 1, message.getBool(), 3);
                               } else if(message.sensor==CHILD_ID_433_5) {
                                  changeSwitchStatus('a', 2, 2, message.getBool(), 3);
                               } else if(message.sensor==CHILD_ID_433_6) {
                                  changeSwitchStatus('a', 2, 3, message.getBool(), 3);
                          I'm pretty amazed on how well this setup works. My wife and I use it daily and I've a scheduled task that switches on an outlet daily. Works like a charm.
                          Only limitation: If you send commands too fast, for example switch on outlet 1 & 2 at the same time the outlets get confused. :-) Often outlet 3 gets switched on too in that case. Maybe it has something to do with the 3 retries I'm using.
                          • T TimO
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                             readDHT();
                             wait(SLEEP_TIME);
                            void readDHT() {
                                if (!metric) {
                                  lastHum = humidity;
                                if(status) {
                                wait(50);
                            TommiT Offline
                            TommiT Offline
                            Tommi
                            @TimO
                            Many thanks for your response !
                            I have only the 433MHZ transmitter connected without DHT22 and LEDs, but it does not work unfortunately, I do not know what I doing wrong !?
                            Shortly after the plug in, while the LED still flashes I do in FHEM "set MYSENSOR_xy status1 on" but without success.
                            • T Offline
                              T Offline
                              TimO
                              Did you verify that the message is received by the node?
                              I'm not familiar with FHEM, please note, that the first outlet uses child ID 4.
                              What's the debug output of the node?
                              • TommiT Offline
                                TommiT Offline
                                Tommi
                                • TommiT Tommi
                                  TommiT Offline
                                  TommiT Offline
                                  Tommi
                                  12.1k
