  3. Basic project setup from start to finish
17 Posts 4 Posters 6.2k Views 4 Watching
  • toddsantoroT
    toddsantoroT
    toddsantoro
    Here is what my Arduino folder looks like: https://www.dropbox.com/s/hfsg3d1xkcoydqq/Screenshot 2016-10-21 16.36.51.png?dl=0
    • toddsantoroT
      toddsantoroT
      toddsantoro
      Should I create another folder in there called sketches? Here is my sketch copy and pasted from the example on this page: https://www.mysensors.org/build/motion
       * Version 1.0 - Henrik Ekblad
      // Enable debug prints
      // #define MY_DEBUG
      // Initialize motion message
      void presentation()  {
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
      • toddsantoroT toddsantoro
        @toddsantoro something in the Arduino IDE is referencing libraries/TAS_motion_sensor. Do you have any idea what it could be? As AWI said, nothing should expect TAS_motion_sensor to be in the libraries folder.
        toddsantoroT 1 Reply Last reply
          // #define MY_DEBUG
          @toddsantoro where did you paste the example sketch? What is the file name and in which folder is that file? (use Sketch->Show sketch folder (ctrk/cmd+K) to locate it)
            toddsantoroT
            toddsantoroT
            toddsantoro
            @mfalkvidd I removed everything I have done and started new so that is why you do not see that in the library's folder. I would like to know the exact steps no matter how trivial they are to setting up the sensors project. I am a web programmer and that may be my issue because I know how I would set things up but that does not mean thaty are correct in this situation.
              @toddsantoro the instructions are available at https://www.mysensors.org/about/arduino
              After installing the library you can open the examples from File->Examples->MySensors. There is no need to copy-paste from the build page (but that should work as well).
                toddsantoroT
                toddsantoroT
                toddsantoro
                @mfalkvidd OK. I will give it a try. Thanks for your help and patience. I hope to automate my whole 417 sqft home and then help others to do the same.
                  toddsantoroT
                  toddsantoroT
                  toddsantoro
                  @toddsantoro Actually I have read that and I am still in the dark. From the Arduino GUI I go FILE > NEW. COMMAND + S and save it where? It defaults to the Arduino folder on my machine with just Libraries directory in it. Do I create a SKETCHES folder and save the project there? I just don't know what to do???
                    @toddsantoro save it in the suggested directory, next to (not inside) the libraries folder.
                    toddsantoro170T 1 Reply Last reply
                      toddsantoro170T
                      toddsantoro170T
                      toddsantoro170
                      @mfalkvidd ok... what goes in the file? Copy paste from the example of do I somehow use the motion sensor library? I want to get a basic, best practices work flow going. Again thanks for your help.
                      • toddsantoro170T toddsantoro170
                        @toddsantoro170 using the example file without modification is usually the best way to start.
