  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • mrwombleM
    mrwombleM
    mrwomble
    Hi there, I'm new to Mysensors and I thought I'd start with a simple DS Temp sensor. However, I'm getting compile errors when I try compile it. Can someone please point me in the right direction?
    Arduino: 1.6.11 (Windows 7), Board: "Arduino Nano, ATmega328"
    WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'
    In file included from C:\Users\Admin\Documents\Arduino\Projects\MS Temp sensor node\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
    C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
    C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
         int16_t millisToWaitForConversion(uint8_t);
    DallasTemperatureSensor:85: error: within this context
    Multiple libraries were found for "DallasTemperature.h"
     Used: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature
     Not used: C:\Users\Admin\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
    exit status 1
    within this context
    S 1 Reply Last reply
    • mrwombleM
      mrwombleM
      mrwomble
      Ah, never mind! Managed to resolve it after all. For the benefit of others who may hit the same issue: the code depends on a very particular version of the DallasTemperature library, the versions downloaded via the Arduino IDE don't work and give the errors above. I had to download the library from the examples on github here: https://github.com/mysensors/MySensorsArduinoExamples
      remisR 1 Reply Last reply
      • mrwombleM mrwomble
        remisR
        remisR
        remis
        @mrwomble
        Hello mrwomble.
        Could you detail the file you have use to compile OK ? Do we need to use the full library? I plan to use local file with
        #include "filename.h"
        instead of
        #include <filename.h>
        • Patrik SöderströmP
          Patrik SöderströmP
          Patrik Söderström
          I have trouble with this on a NodeMCU 0.9.
          #error "Please define I/O register types here"
          Anyone who can help?
          • Patrik SöderströmP Patrik Söderström
            @Patrik-Söderström could you give us some more context about the problem?
            Which line does the error occur on? Does the error message say anything more? (we are not magicians :-) )
            Have you modified the example sketch in any way? if so, what changes?
              Patrik SöderströmP
              Patrik Söderström
              wrote on last edited by Patrik Söderström
              I use the following code, I have added the GW support for ESP board.
               * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
               * http://www.mysensors.org/build/temp
              //#define MY_RADIO_NRF24
              #define MY_BAUD_RATE 9600
              #define MY_GATEWAY_ESP8266
              #define MY_ESP8266_SSID "TP54C10"
              #define MY_ESP8266_PASSWORD "blarretp54c10"
              #define MY_PORT 5003
              #include <ESP8266WiFi.h>
              #include <OneWire.h>
              int numSensors=0;
              bool receivedConfig = false;
              bool metric = true;
              MyMessage msg(0,V_TEMP);
              void before()
                sensors.begin();
                   present(i, S_TEMP);
                sleep(conversionTime);
                  float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  #if COMPARE_TEMP == 1
                sleep(SLEEP_TIME);
              the exakt error I get in Arduino IDE is
              In file included from C:\Users\xxxxx\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:22:0,
                               from Z:\MySensors\NodeMCU-Water meter\NodeMCU-Water_meter\NodeMCU-Water_meter.ino:51:
              C:\Users\xxxxxx\Documents\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
              exit status 1
              Error compiling for board NodeMCU 0.9 (ESP-12 Module).```
                int numSensors=0;
                bool metric = true;
                void before()
                  sensors.begin();
                     present(i, S_TEMP);
                  sleep(SLEEP_TIME);
                exit status 1
                @Patrik-Söderström according to http://www.esp8266.com/viewtopic.php?f=12&t=9430 you need a newer version of the onewire library.
                • toddsantoroT
                  toddsantoroT
                  toddsantoro
                  Can anyone tell me what these errors say?
                  DallasTemperature.cpp:433: error: no 'int16_t DallasTemperature::calculateTemperature(const uint8_t*, uint8_t*)' member function declared in class 'DallasTemperature'
                  int16_t DallasTemperature::calculateTemperature(const uint8_t* deviceAddress, uint8_t* scratchPad){
                  sketch/DallasTemperature.cpp: In member function 'int16_t DallasTemperature::getTemp(const uint8_t*)':
                  DallasTemperature.cpp:484: error: 'calculateTemperature' was not declared in this scope
                  if (isConnected(deviceAddress, scratchPad)) return calculateTemperature(deviceAddress, scratchPad);
                  sketch/DallasTemperature.cpp: In member function 'bool DallasTemperature::hasAlarm(const uint8_t*)':
                  DallasTemperature.cpp:764: error: 'calculateTemperature' was not declared in this scope
                  char temp = calculateTemperature(deviceAddress, scratchPad) >> 7;
                  exit status 1
                  • remisR remis
                    @mrwomble
                    Hello mrwomble.
                    instead of
                    remisR
                    remisR
                    remis
                    @remis
                    I confirm that i can suppress the compilation error but nothing append on serial port...
                    Could somebody write here the typical serial port output with debug available?
                    This example is not working. What is the good solution to use this temperature sensor ?
                    thanks
                    • A
                      Alex B Goode
                      Why don't we use an internal pull-up resistor available within an arduino board? Why additional external one?
                      pinMode(pin, INPUT); // set pin to input
                      digitalWrite(pin, HIGH); // turn on pullup resistors
                      • A Alex B Goode
                        @Alex-B-Goode the datasheet says "The 1-Wire bus requires an external pullup resistor of approximately 5kΩ"
                        The internal pull-up of most Arduinos are 20-50kΩ
                        So my guess is that the reason is that the person who created the instructions read the datasheet and chose to follow its recommendation. But accounding to http://electronics.stackexchange.com/a/62096/107155 the exact size might not be important, so it might be possible to use the internal pull up. Try it and let us know if it works.
                        • toddsantoroT
                          toddsantoroT
                          toddsantoro
                          Does this example compile for anyone??? I get this error:
                          In file included from /Users/Documents/Arduino/tas_temp/tas_temp.ino:37:0:
                          /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h: In function 'void loop()':
                          /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                          tas_temp:85: error: within this context
                          exit status 1
                          within this context
                          • toddsantoroT toddsantoro
                            exit status 1
                            within this context
                            @toddsantoro see post 2 and 3 in this thread or read the instructions on the build page, just under the "Example" heading.
                            mrwombleM toddsantoroT 2 Replies Last reply
                              mrwombleM
                              mrwombleM
                              mrwomble
                              ^ What he said 😁
                                toddsantoroT
                                toddsantoroT
                                toddsantoro
                                wrote on last edited by toddsantoro
                                @mfalkvidd OK. I have it compiling and uploaded to the nano. My config file looks like this now:
                                sensor 6:
                                  -platform: onewire
                                    names:
                                      some_id: outside
                                      mount_dir: "/mnt/1wire"
                                I get an error when I restart HASS on the Pi.
                                ERROR (Thread-6) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it's defined.
                                I guess my question is do I need to define the mount_dir variable and if so is the one I have correct? And if it is correct do I need to create that directory on my Pi?
                                I also do not get any output in the Arduino Serial Monitor window. Not sure if I even should...
                                Thanks in advance for any help...
                                  sensor 6:
                                    -platform: onewire
                                      names:
                                        some_id: outside
                                  @toddsantoro I am not familiar with homeassistant so I have no clue unfortunately.
                                  About debug output on the serial monitor: Debug needs to be enabled first. See instructions at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and https://www.mysensors.org/build/debug
                                  Debug output is often essential when troubleshooting.
                                  toddsantoroT 1 Reply Last reply
                                    toddsantoroT
                                    toddsantoroT
                                    toddsantoro
                                    @mfalkvidd Thank you!!! I get this output in the serial monitor
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSP:ASSIGNID:OK (ID=2)
                                    TSM:FPAR
                                    TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                    TSM:FPAR
                                    TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    TSP:MSG:PAR OK (ID=0, dist=1)
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:CHKID:OK (ID=2)
                                    TSM:UPL
                                    TSP:PING:SEND (dest=0)
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    TSP:MSG:PONG RECV (hops=1)
                                    TSP:CHKUPL:OK
                                    TSM:UPL:OK
                                    TSM:READY
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                    TSP:MSG:READ 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:I
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                    Request registration...
                                    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                    TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    Node registration=1
                                    Init complete, id=2, parent=0, distance=1, registration=1
                                    Does this look OK? If so I will ask my previous question on the Home Assistant forum. You have been a great help and once I get one of these things down I will be able to help others:)
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=2)
                                      TSM:UPL
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      Node registration=1
                                      @toddsantoro yes that looks good.
                                      The "st=ok:xyz" means message xyz was acknowledged by the destination node (in your case by the gateway)
                                        stingone
                                        No compile error but i cant see anything on the serial monitor. also the temp sensor burend out with a 4k7 resistor :S
                                        • S stingone
                                          remisR
                                          remisR
                                          remis
                                          @stingone
                                          Hi. The same issue for me . I solve it with : 38400 bauds configuration serial port ( instead of 115200 default value)
                                          and i lowering the RF power output with low_pa enable: it confirms that I have some issues with power suppply.
                                          good luck
