  3. BME280 How to use it outdoors
36 Posts 9 Posters 36.3k Views 10 Watching
  • karl261K
    karl261K
    karl261
    Why are all my photos upside down? That's weird. They display right on the tablet, but on the PC in FireFox they are upside down...
    • karl261K
      karl261K
      karl261
      By the way: This is the sketch I use. It is made for a 1 MHz Atmega328p. If anyone has some code suggestions... :-)
      I use a board that looks like this:
      by m26872, 20151109
      modified for BME280 by karl261 using Sparkfun library
      // MIN, LOW, HIGH, MAX
      #define MY_PARENT_NODE_ID 99
      #define MY_NODE_ID 6
      #define MY_BAUD_RATE 9600
      #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
      #include <RunningAverage.h>
      #include <SparkFunBME280.h>
      //#define DEBUG   // local debug
      #ifdef DEBUG
      // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_PRES 2
      #define SLEEP_TIME 15000 // 15s for DEBUG
      //#define SLEEP_TIME 300000   // 5 min
      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
      #define VMIN 1900
      #define VMAX 3300
      #define PRES_TRANSMIT_THRESHOLD 1.0
      #define AVERAGES 2
      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
      int measureCount = 0;
      float lastTemperature = -100;
      float lastPressure = -100;
      int lastHumidity = -100;
      //SI7021 humiditySensor;
      BME280 mySensor;
      // MyMessage to controler
      MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
        sendSketchInfo("OUTSIDE P&T&H", "1.2");
        present(CHILD_ID_PRES, S_BARO);
        present(CHILD_ID_HUM, S_HUM);
        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
        DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
        DEBUG_PRINT("Voltage: ");
        DEBUG_PRINT(readVcc());
        DEBUG_PRINTLN(" mV");
        delay(500);
        DEBUG_PRINTLN(" *C");
        mySensor.settings.commInterface = I2C_MODE;
        mySensor.settings.I2CAddress = 0x77;
        //runMode can be:
        //  0, Sleep mode
        //  1 or 2, Forced mode
        //  3, Normal mode
        mySensor.settings.runMode = 1;
        mySensor.settings.filter = 0;
        mySensor.settings.tempOverSample = 1;
        mySensor.settings.pressOverSample = 1;
        mySensor.settings.humidOverSample = 1;
        if (!mySensor.begin())
          Serial.println("BME init failed!");
          while (1);
        else Serial.println("BME init success!");
        raHum.clear();
        measureCount ++;
        batteryReportCounter ++;
        bool forceTransmit = false;
        if (measureCount > FORCE_TRANSMIT_CYCLE) {
          forceTransmit = true;
        mySensor.begin();
        // Read and print internal temp
        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
        // Check battery
        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
          long batteryVolt = readVcc();
          DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
          uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
          DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
          batteryReportCounter = 0;
        sleep(SLEEP_TIME);
      //if(isTransportOK()){
      //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
      //  else {
      //    wait(5000); // transport is not operational, allow the transport layer to fix this
      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
      long readVcc() {
        result = 1178053L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
        //Node 6 = 1178053L
      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
        unsigned int wADC;
        double t;
        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
        ADCSRA |= _BV(ADEN);  // enable the ADC
        delay(20);            // wait for voltages to become stable.
        ADCSRA |= _BV(ADSC);  // Start the ADC
        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
        return (t);   // The returned temperature in degrees Celcius.
       * Parameters
        bool tx = force;
        float temperature = mySensor.readTempC();
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
          send(msgTemp.set(temperature,1));
          measureCount = 0;
          DEBUG_PRINTLN("T sent!");
        int humidity = mySensor.readFloatHumidity();
        raHum.addValue(humidity);
        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
          send(msgHum.set(humidity));
          lastHumidity = humidity;
          measureCount = 0;
          DEBUG_PRINTLN("H sent!");
        float pressure = mySensor.readFloatPressure()/100.0;
        DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
        float diffPress = abs(lastPressure - pressure);
        DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
        if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
          send(msgPres.set(pressure,1));
          lastPressure = pressure;
          measureCount = 0;
          DEBUG_PRINTLN("P sent!");
      • karl261K
        karl261K
        karl261
        Well, I guess then I will change the BME280 to a new one and see how it goes. Let's see how long it lasts. If it is made for weather monitoring, it should withstand normal weather conditions if not exposed to rain???
        • karl261K
          karl261K
          karl261
          wrote on last edited by karl261
          Ok, I changed the BME280. Now it is better.
          I like this sensor, I have right now 3 of them running next to each other:
          T    20.8        21.2       21.1
          H    60%         60%        60%
          P    1015.3      1015.0     1014.9
          Isn't that great? Now let's see how long the outdoor sensor lasts. I don't know what else to improve...
          R 1 Reply Last reply
          • karl261K karl261
            T    20.8        21.2       21.1
            H    60%         60%        60%
            R
            R
            r-nox
            @karl261 hopefully a longer time.
            • karl261K
              karl261K
              karl261
              It does not look that it was much longer time. But instead like the sensor before, the current one is now showing values between 0-22% humidity. T seems to be fine. That is SO disappointing. It seems that these things are not suitable for outdoor use. Lasted only a month...
              Buuuuh.
              • R
                R
                r-nox
                Seems short lived...
                • Nca78N
                  :( Sounds bad :(
                  Next step for you is to try with a SHT21 with the protective film it might get a better chance than the BME280...
                  • karl261K
                    karl261K
                    karl261
                    @r-nox Somehow, doesn't it? A bit too short for my taste. It should not see any rain, I wonder what is killing it. Or, how I can protect it even better.
                    @Nca78 I had a SI7021 with protective foil before, but it was not very accurate. Actually it was quite far off, that's why I started to look for something more accurate.
                    When I look around online there seems to be some connection/confusion with the SI7021 and SHT21. But I did not really understand it. Does anybody know more about it?
                    EDIT: Hm, seems to be two different sensors, but the board is always the same. So I would need to check to really get a SHT21 and with a protective cover...
                    EDIT2: I do not seem to find any SHT21 with protective cover...
                    • R
                      R
                      r-nox
                      Are you over working it? Is that even possible?
                      karl261K 1 Reply Last reply
                      • R r-nox
                        karl261K
                        karl261K
                        karl261
                        @r-nox You mean too many readings per time unit?
                        • R
                          R
                          r-nox
                          That's my line of thought.
                          • R r-nox
                            karl261K
                            karl261K
                            karl261
                            @r-nox Hm, it is reading every 15 seconds at the moment. Do you think this is too much?
                            The current sensor is not completely broken, it seems. Sometimes it is showing "normal" values. I brought it into the house to test it, and in the house it seems to show normal values. I will know more tomorrow morning.
                            According to its specs it is supposed to be good for weather monitoring. But then, it seems it does not like "weather" too much.
                            I also found it strange that in the past 30 days the maximum humidity it read was 87 %. And for sure there were plenty of nights here with 100 %. But ok, I could live with that. But it has started to show far too low values for humidity, down to 0 %. I'll leave it in the house for 1-2 days and then see how it behaves outside.
                            • R
                              R
                              r-nox
                              I don't know the specs for reading it off hand. Perhaps your housing is holding humidity. I plan to add a fan to mine. Spin the fan for a few moments before reading to cycle the air.
                              • karl261K
                                karl261K
                                karl261
                                So, this story also continues. After having these problems, I brought the sensor into the house and left it running for the past several weeks in the living room. Actually it is working fine. No more problems.
                                Now, for Christmas, I have brought it back outside to the birdhouse. And it is still working fine, even at -10 °C. Let's see how long it will last this time.
                                What I also noticed is that now I have a second of these in the greenhouse where the humidity is definitely from time to time 100%. At 4°C. But both outdoor sensors somehow never reach 100%, but stop somewhere between 85-90%. It seems they are not made to detect 100% humidity.
                                • karl261K
                                  karl261K
                                  karl261
                                  Now after 2-3 month more outside the sensor seems to be finally dead. No reaction anymore. Also the 2nd one in the greenhouse does not reply anymore. I'll have to check. The one in the living room is fine.
                                  It seems that at least the ones I bought are not really lasting long outdoors.
                                  parachutesjP 1 Reply Last reply
                                  • R
                                    R
                                    r-nox
                                    Time to try something else.
                                    • ferroF
                                      ferroF
                                      ferro
                                      What about to use PTFE (teflon) tape to protect the sensor board, see this project. It seems, characteristics of the material (PTFE) enables it to use it for this purpose, it is mentioned also link text here
                                      • karl261K
                                        karl261K
                                        karl261
                                        #29
                                        Interesting idea, the ptfe tape. I will try it with the next sensor!
                                        So, only the outdoor sensors fail. It is now more than one that failed.
                                        I have one in the living room -- perfect.
                                        And, very strange: I have one in the green house. Huge T differences, sometimes very hot, and often 100% humidity. Actually conditions should be worse for this sensor compared to the outdoor sensor. But: it is just fine.
                                        Weird.
                                        • D
                                          DavidZH
                                          @karl261 Do you happen to live near te sea? Because salty air wreaks havoc on anything sooner or later. Tiny electronics rather sooner...
                                          I have a BME280 outside and that's been running for over a year now. It's pretty well protected though, but it catches a few hours of direct sunlight per day.
