  3. How do I setup Raspberry Pi 2 with NRF24L01 as MySensor 2.0 Gateway with MyController as controller
mycontroller.orggpioraspberry pi 2rbp2nrf24l01
19 Posts 3 Posters 8.7k Views 3 Watching
  • alexsh1A alexsh1
    @Christian-Simonsen said:
    @alexsh1 said:
    FPAR: FAIL = Find Parent Fail. The sensor is looking for a parent, but cannot find it. There can be several reasons for this:
    1. Try to add larger capacitors to both radios on GW and the sensor.
    2. Please use a default sketch on the sensor, no signing etc.
    3. Double check if the channel is the same. You are using channel 0 on RPi. What about the sensor? Did you change it from a default 76?
    4. Did you upload both sketches using MySensors 2.0?
    5. Please check the power feed on both GW and the sensor.
    Hi thanks for the support. Hope you are able to elaborate a bit on your points.
      I'm using a 4.7 uF Capacitator on both the NRF24L01 on the Raspberry Pi, and on the NRF24L01 on the Arduino. Do you think I still need a bigger capacitor?
    Yes, try a larger ones. I added 100uF. You may try different transceivers.
    1. ** Please use a default sketch on the sensor, no signing etc.**
    Can you share a default sketch to use?
    **All default sketches are here:
    https://github.com/mysensors/MySensors/tree/development/examples
    Take any sketch.**
    I have tried the below sketch from this page https://www.mysensors.org/download/sensor_api_20#sensor-nodes
    But the sketch do not compile due to non defined NODE_ID. I tried to updated the code by changing NODE_ID to MY_NODE_ID and added a line to #DEFINE MY_NODE_ID 1
    Is this correct? See the updated code that I've used below
    #define MY_NODE_ID 1
    #define MY_PARENT_NODE_ID 0
    MyMessage msg(MY_NODE_ID, V_TRIPPED);
        present(MY_NODE_ID, S_DOOR);
    With this code I still get an error (this is the Arduino Uno sensor node)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    1. Did you upload both sketches using MySensors 2.0?
      Not sure how you upload the sketch to the RPI 2 using MySenors 2.0. However I have atleast tried to follow this tutorial. https://www.mysensors.org/build/raspberry
    The actual steps I did are repeated below.
    cd MySensors
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24
    Can you please make sure you add the following to the above:
    --my-rf24-channel=76
    when compiling the code
    sudo make all
    sudo make install
    sudo systemctl enable mysgateway.service
    1. Please check the power feed on both GW and the sensor.
      How do you do this?
    With a voltmeter. I am sorry, but this is rather DIY when i comes to troubleshooting.
    At least you'd know that the voltage is here. If you are using an amplified transceiver, you have to be extra cautious with power. What radios are you using? Post photos
    alexsh1A
    alexsh1A
    alexsh1
    This is not a default sketch, this is just a template to explain how it works. It won't compile (requires NODE_ID definition etc).
    Try this sketch:
    #define CHILD_ID_LIGHT 0
    int lastLightLevel;
    void presentation()  {
      sendSketchInfo("Light Sensor", "1.0");
      int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      sleep(SLEEP_TIME);
    • alexsh1A
      alexsh1A
      alexsh1
      @Christian-Simonsen Additionally, you may need to use CleerEEPROM sketch (in Arduino, examples - MySensors) on your sensor to make sure it is clean BEFORE proceeding with a new sketch.
      • Christian SimonsenC
        Christian SimonsenC
        Christian Simonsen
        wrote on last edited by Christian Simonsen
        @alexsh1
        Thanks for all the tips.
        I've now installed a new 100 uF (16V) Capacitor in parallell with the current 4.7 uF (50V) capacitor on both the units, I also double checked the writing just to be sure. It all looks good. See images below.
        **After adding the capacitor, I uninstalled and cleaned the setting on the Raspberry Pi. **
        Sudo make uninstall
        pi@raspberrypi:~/MySensors $ sudo make uninstall
        Stopping daemon mysgateway (ignore errors)
        removing files
        rm /etc/systemd/system/mysgateway.service /usr/local/bin/mysGateway
        Sudo make clean
        pi@raspberrypi:~/MySensors $ sudo make clean
        [Cleaning]
        rm -rf build drivers/Linux/log.o drivers/Linux/noniso.o drivers/Linux/SoftEeprom.o drivers/Linux/EthernetClient.o drivers/Linux/SerialPort.o drivers/Linux/Stream.o drivers/Linux/Print.o drivers/Linux/IPAddress.o drivers/Linux/compatibility.o drivers/Linux/EthernetServer.o examples_linux/mysGateway.o drivers/RPi/piHiPri.o drivers/RPi/bcm2835.o drivers/RPi/rpi_util.o drivers/RPi/Wire.o drivers/RPi/SPI.o examples_linux/mysGateway drivers/Linux/log.d drivers/Linux/noniso.d drivers/Linux/SoftEeprom.d drivers/Linux/EthernetClient.d drivers/Linux/SerialPort.d drivers/Linux/Stream.d drivers/Linux/Print.d drivers/Linux/IPAddress.d drivers/Linux/compatibility.d drivers/Linux/EthernetServer.d examples_linux/mysGateway.d drivers/RPi/piHiPri.d drivers/RPi/bcm2835.d drivers/RPi/rpi_util.d drivers/RPi/Wire.d drivers/RPi/SPI.d
        **After uninstalling, reset the configuration, and installed and started the gateway. **
        pi@raspberrypi:~/MySensors $ ./configure --my-debug=enable --my-gateway=serial --my-serial-is-pty --my-serial-pty=ttyMySensorsGateway --my-transport=nrf24 --my-rf24-channel=76
        [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
        [OK] init system detected: systemd
        [OK] Finished.
        Make all
        pi@raspberrypi:~/MySensors $ sudo make all
        cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
        cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/piHiPri.o drivers/RPi/piHiPri.c
        cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/bcm2835.o drivers/RPi/bcm2835.c
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/rpi_util.o drivers/RPi/rpi_util.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/Wire.o drivers/RPi/Wire.cpp
        g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/SPI.o drivers/RPi/SPI.cpp
        g++ -pthread  -o examples_linux/mysGateway drivers/Linux/log.o drivers/Linux/noniso.o drivers/Linux/Print.o drivers/Linux/EthernetClient.o drivers/Linux/SerialPort.o drivers/Linux/Stream.o drivers/Linux/IPAddress.o drivers/Linux/compatibility.o drivers/Linux/SoftEeprom.o drivers/Linux/EthernetServer.o examples_linux/mysGateway.o drivers/RPi/piHiPri.o drivers/RPi/bcm2835.o drivers/RPi/rpi_util.o drivers/RPi/Wire.o drivers/RPi/SPI.o
        Sudo make install
        pi@raspberrypi:~/MySensors $ sudo make install
        Installing examples_linux/mysGateway to /usr/local/bin
        install -m0644 initscripts/mysgateway.systemd /etc/systemd/system/mysgateway.service
        systemctl daemon-reload
        MySensors gateway has been installed, to add to the boot run:
        To start the gateway run:
          sudo systemctl start mysgateway.service
        start the gateway
        pi@raspberrypi:~/MySensors $ sudo systemctl start mysgateway.service
        Start the debug on the gateway:
        pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
        mysGateway: Starting gateway...
        mysGateway: Protocol version - 2.0.1-beta
        mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
        mysGateway: TSF:LRT:OK
        mysGateway: TSM:INIT
        mysGateway: TSM:INIT:TSP OK
        mysGateway: TSM:INIT:GW MODE
        mysGateway: TSM:READY
        mysGateway: MCO:REG:NOT NEEDED
        mysGateway: MCO:BGN:STP
        mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
        mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
        mysGateway: !TSF:MSG:LEN,0!=7
        Now, the gateway on the Raspberry Pi 2 seem ok and up and running. Moving over to the sensor node, the Arduino Uno with NRF24L01+.
        Uploaded and ran the Clear_EPROM sketch
        * This sketch clears radioId, relayId and routing info in EEPROM
        #include <EEPROM.h>
          for (int i=0;i<512;i++) {
            EEPROM.write(i, 0xff);
          Serial.println("EEPROM cleared");
          // Nothing to do here...
        After this I uploaded your recommended default sketch. However I added "#define MY_RF24_CHANNEL 76"
        int lastLightLevel;
          sleep(SLEEP_TIME);
        The result, enoyingly is the same it seems based on the output from the Serial Monitor from the Arduino Uno.
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        Frustrating... Can it be other modules, libraries than what I've not installed on the Raspberry Pi that is the reason for the error?
        • alexsh1A
          alexsh1A
          alexsh1
          @Christian-Simonsen ok, you have an amplified version of nrf24l01+. It does require more power and could be a problem. How are feeding it from Raspberry please?
          Can you try a normal nrf24l01+ on Raspberry? Just like the one you have on a sensor and report back?
          Christian SimonsenC 1 Reply Last reply
          • alexsh1A alexsh1
            Christian SimonsenC
            Christian SimonsenC
            Christian Simonsen
            @alexsh1
            Again thanks for all the help, very much appreciated.
            I started last evening putting together a few more NRF24L01 sensors such as the one on the Node. I will also setup a new extra Arduino Gateways, so I also can test communication between two Arduinos, before testing the same with the Raspberry Pi. Ill report back later tonight when I know the results.
            • alexsh1A
              alexsh1A
              alexsh1
              @Christian-Simonsen I bet the problem is with your GW radio
              • alexsh1A alexsh1
                Christian SimonsenC
                Christian SimonsenC
                Christian Simonsen
                @alexsh1
                You are 100 % correct :+1: :)
                I changed the NRF24L01 module with the antenna, with a standard NRF24L01+ module. And it works like a charm.
                Here are the Serial Monitor code from the Arduino (Sensor node). I don't currently understand what all the code says, but it seems like they are communicating.
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:FPAR (PPAR FOUND)
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=1)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Light Sensor
                TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
                Request registration...
                !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=fail:2
                !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=fail:2
                !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=fail:2
                !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                Init complete, id=1, parent=0, distance=1, registration=1
                50
                !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:50
                56
                !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:56
                !TSM:UPL FAIL, STATP
                58
                !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:58
                58
                58
                And from the Raspberry Pi
                mysGateway: !TSF:MSG:LEN,8!=7
                mysGateway: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                mysGateway: TSF:MSG:BC
                mysGateway: TSF:MSG:FPAR REQ,ID=1
                mysGateway: TSF:PNG:SEND,TO=0
                mysGateway: TSF:CKU:OK
                mysGateway: TSF:MSG:GWL OK
                mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                mysGateway: TSF:MSG:PINGED,ID=1,HP=1
                mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                mysGateway: TSF:MSG:READ,0-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  Christian SimonsenC
                  Christian Simonsen
                  I have connection, however the communication seem to fail after a while. Seems to get worse and worse. I'm currently sending a msg every 30 seconds from the node. See code below.
                  Gateway on the Raspberry Pi:
                  mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:50
                  mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:57
                  mysGateway: !TSF:MSG:LEN,0!=9
                  mysGateway: !TSF:MSG:LEN,9!=7
                  mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:56
                  And the code from the Arduino Uno Node
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=1)
                  TSM:UPL
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  50
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:50
                  55
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:55
                  57
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:57
                  57
                  56
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:56
                  56
                  57
                  58
                  TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:58
                  57
                  58
                  56
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:56
                  55
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=fail:55
                  55
                  55
                  59
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=fail:59
                  58
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=fail:58
                  56
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:56
                  58
                  !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:58
                  !TSM:UPL FAIL, SNP
                  TSM:FPAR
                  56
                  !TSP:SEND:TNR```
                    Christian SimonsenC
                    Christian Simonsen
                    My sensors are located about 3 meters apart with nothing in between. To mitigate the packet loss I've increased by the Gateway to RF24_PA_HIGH and the Arduino to RF24_PA_MAX. I tested MAX on the Gateway aswell, but it didn't seem to handle this setting.
                    Note I've changed the code of the Node - it now sends a number per msg, and it increases by 1 for each message. This way I found it easier to track which msg that succeeded and which didn't.
                    First it looked ok, but the msg started to fail after some time (note: I have 3 seconds between each message now)
                    When I start the Gateway by using "sudo ./examples_linux/mysGateway -d" it starts fine, and connects with the Arduino which I restart at the same time as I type the code above in terminal to start the Gateway on the Raspberry Pi.
                    After the setup it seems like most of the first 13 messages go through successfully. Then the next 10 messages fail (atleast looks like it on the GW debug info). Then there is another good period from 23-40, but with a few lost. Then the rest fail, and the sensor also starts reporting the messages as failed. After this I have to restart the Sensor node to be able to regain communication.
                    Do anyone know what is wrong... ?
                    The Raspberry Pi Gateway:
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:1
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:2
                    mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                    mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                    mysGateway: !TSF:MSG:LEN,0!=8
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:3
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:4
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:6
                    mysGateway: !TSF:MSG:LEN,17!=7
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:8
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:9
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:10
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:11
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:13
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:23
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:25
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:28
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:30
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:31
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:33
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:34
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:37
                    mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:40
                    And the Arduino sensor node:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Node registration=1
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:0
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:1
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:2
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:3
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:4
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:6
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:7
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:8
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:9
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:10
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:11
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:12
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:13
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:14
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:15
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:16
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:17
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:18
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:19
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:20
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:21
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:22
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:23
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:24
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:25
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:26
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:27
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:28
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:29
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:30
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:31
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:32
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:33
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:34
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:35
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:36
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:37
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:38
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:39
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:40
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:41
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:42
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:43
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:44
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=fail:45
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=fail:46
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=fail:47
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:48
                    !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:49
                    !TSM:UPL FAIL, SNP
                    TSM:FPAR
                    !TSP:SEND:TNR
                    !TSP:SEND:TNR
                    !TSP:SEND:TNR
                    !TSP:SEND:TNR
                      Christian SimonsenC
                      Christian Simonsen
                      HI,
                      I've been doing some testing. I have two Gateways
                      1. Raspberry Pi 2 with a NRF24L01+ module connected to the GPIO pins
                      2. Arduino Nano with a NRF24L01+ module connected via a breadboard to my MacBook Pro
                      The sensor node is an Arduino Uno with a NRF24L01+ module. This sensor is sending out a higher number for each packet (eg. 1, 2, 3, 4)
                      Between the Raspberry Pi 2 gateway is have a lot of data loss as shown in earlier posts even with just 3 meters a part. However using the Arduino Nano as the gateway I can walk across the apartment with loosing anything (10+ meters away).
                      I've switched the NRF24L01 modules around and the result is the same.
                      I have now two possible reasons:
                      1. Something is wrong related to the Raspberry Pi 2 - The code, libraries, power to the NRF24L01 etc.
                      2. The Raspberry Pi is next to my ASUS RT-AC87U wireless router... maybe it is interfering (I don't think it is this, as I didn't have any packet loss with the Arduino Nano when I held it next to the router)
                      I therefore think it is related to point 1. The Raspberry Pi 2. But don't know what it could be...
                      Any ideas?
                      alexsh1A 1 Reply Last reply
                      • Christian SimonsenC Christian Simonsen
                        HI,
                        Any ideas?
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Christian-Simonsen I have been testing RPi 3 with nrf24l01+ for a month or so - it works just fine.
                        Your problem (TSM:MSG:LEN) is more related to a communication error between the transceiver and RPi/Arduino. Firstly, try adding the following
                        #define MY_RF24_SANITY_CHECK
                        The way I have it setup on my RPi is that I feed nrf24l01+ via 5V pin through AMS1117 3.3
                        Remember that 3.3v is limited in terms of current (hence your problem with PA version).
                        I recommend using one of these boards designed by @GertSanders
                        What transceivers do you have nrf24l01 or nrf2401+?
                        In relation to the data rate use the lower RF24_250KBPS (by default).
                        Another issue is RF24_PA_LEVEL_GW and RF24_PA_LEVEL
                        See - https://forum.mysensors.org/topic/4034/my-first-gateway
                        Remember if you have modules too close and set the PA leave high, the modules will be screaming to each other.
                        Finally, appreciate your GW on Mac works fine as supposed to your RPi GW. There can be a few reasons for this. Just try to eliminate issues one by one. You have to do a lot of readings on this forum and some DIY trial and error.
                        • alexsh1A alexsh1
                          Christian SimonsenC
                          Christian SimonsenC
                          Christian Simonsen
                          @alexsh1
                          Hi Alex,
                          I tested the Sanity check on the the Arduino sensor node, and status came back OK. However I could get this to work on the Raspberry Pi, seems like this function is not yet supported. At least I couldn't find any info on it using the "./configuration -h".
                          I don't have a AMS1117 available so I can test that.
                          I connected my Arduino Nano and NRF24L01+ to the Raspberry Pi via USB, that would really well. So I might just use this solution instead as I see little benefit of connecting the NRF24L01 directly to the GPIO pins on the Raspberry Pi.
                          Next step is to start building some battery powered sensors that I can use, and get MyController setup properly.
