  3. How do I setup Raspberry Pi 2 with NRF24L01 as MySensor 2.0 Gateway with MyController as controller
mycontroller.orggpioraspberry pi 2rbp2nrf24l01
19 Posts 3 Posters 8.7k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Additionally, you try to run a default sketch with
    #define MY_NODE_ID 1
    Also you may add the following to the above:
    #define MY_PARENT_NODE_ID 0
    Please see this https://forum.mysensors.org/topic/3648/node-will-not-connect-unless-define-my_parent_node_id
    • alexsh1A alexsh1
      FPAR: FAIL = Find Parent Fail. The sensor is looking for a parent, but cannot find it. There can be several reasons for this:
      1. Try to add larger capacitors to both radios on GW and the sensor.
      2. Please use a default sketch on the sensor, no signing etc.
      3. Double check if the channel is the same. You are using channel 0 on RPi. What about the sensor? Did you change it from a default 76?
      4. Did you upload both sketches using MySensors 2.0?
      5. Please check the power feed on both GW and the sensor.
      Christian SimonsenC
      Christian SimonsenC
      Christian Simonsen
      Hi thanks for the support. Hope you are able to elaborate a bit on your points.
        I'm using a 4.7 uF Capacitator on both the NRF24L01 on the Raspberry Pi, and on the NRF24L01 on the Arduino. Do you think I still need a bigger capacitor?
      2. ** Please use a default sketch on the sensor, no signing etc.**
      Can you share a default sketch to use?
      I have tried the below sketch from this page https://www.mysensors.org/download/sensor_api_20#sensor-nodes
      But the sketch do not compile due to non defined NODE_ID. I tried to updated the code by changing NODE_ID to MY_NODE_ID and added a line to #DEFINE MY_NODE_ID 1
      Is this correct? See the updated code that I've used below
      MyMessage msg(MY_NODE_ID, V_TRIPPED);
          present(MY_NODE_ID, S_DOOR);
      With this code I still get an error (this is the Arduino Uno sensor node)
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=1)
      TSM:FPAR
      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      1. Did you upload both sketches using MySensors 2.0?
        Not sure how you upload the sketch to the RPI 2 using MySenors 2.0. However I have atleast tried to follow this tutorial. https://www.mysensors.org/build/raspberry
      The actual steps I did are repeated below.
      cd MySensors
      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24
      sudo make all
      sudo make install
      sudo systemctl enable mysgateway.service
      1. Please check the power feed on both GW and the sensor.
        How do you do this?
      alexsh1A 1 Reply Last reply
      • Christian SimonsenC Christian Simonsen
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        cd MySensors
        sudo make all
        sudo make install
          How do you do this?
        alexsh1A
        alexsh1A
        alexsh1
        Yes, try a larger ones. I added 100uF. You may try different transceivers.
        1. ** Please use a default sketch on the sensor, no signing etc.**
        **All default sketches are here:
        https://github.com/mysensors/MySensors/tree/development/examples
        Take any sketch.**
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        cd MySensors
        Can you please make sure you add the following to the above:
        --my-rf24-channel=76
        when compiling the code
        sudo make all
        sudo make install
          How do you do this?
        With a voltmeter. I am sorry, but this is rather DIY when i comes to troubleshooting.
        At least you'd know that the voltage is here. If you are using an amplified transceiver, you have to be extra cautious with power. What radios are you using? Post photos
        • alexsh1A alexsh1
          Take any sketch.**
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          cd MySensors
          sudo make all
          sudo make install
            How do you do this?
          alexsh1A
          alexsh1A
          alexsh1
          This is not a default sketch, this is just a template to explain how it works. It won't compile (requires NODE_ID definition etc).
          Try this sketch:
          #define CHILD_ID_LIGHT 0
          int lastLightLevel;
          void presentation()  {
            sendSketchInfo("Light Sensor", "1.0");
            int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
            Serial.println(lightLevel);
                send(msg.set(lightLevel));
                lastLightLevel = lightLevel;
            sleep(SLEEP_TIME);
          • alexsh1A
            alexsh1A
            alexsh1
            @Christian-Simonsen Additionally, you may need to use CleerEEPROM sketch (in Arduino, examples - MySensors) on your sensor to make sure it is clean BEFORE proceeding with a new sketch.
              Christian SimonsenC
              Christian Simonsen
              wrote on last edited by Christian Simonsen
              @alexsh1
              Thanks for all the tips.
              I've now installed a new 100 uF (16V) Capacitor in parallell with the current 4.7 uF (50V) capacitor on both the units, I also double checked the writing just to be sure. It all looks good. See images below.
              **After adding the capacitor, I uninstalled and cleaned the setting on the Raspberry Pi. **
              Sudo make uninstall
              pi@raspberrypi:~/MySensors $ sudo make uninstall
              Stopping daemon mysgateway (ignore errors)
              removing files
              rm /etc/systemd/system/mysgateway.service /usr/local/bin/mysGateway
              Sudo make clean
              pi@raspberrypi:~/MySensors $ sudo make clean
              [Cleaning]
              rm -rf build drivers/Linux/log.o drivers/Linux/noniso.o drivers/Linux/SoftEeprom.o drivers/Linux/EthernetClient.o drivers/Linux/SerialPort.o drivers/Linux/Stream.o drivers/Linux/Print.o drivers/Linux/IPAddress.o drivers/Linux/compatibility.o drivers/Linux/EthernetServer.o examples_linux/mysGateway.o drivers/RPi/piHiPri.o drivers/RPi/bcm2835.o drivers/RPi/rpi_util.o drivers/RPi/Wire.o drivers/RPi/SPI.o examples_linux/mysGateway drivers/Linux/log.d drivers/Linux/noniso.d drivers/Linux/SoftEeprom.d drivers/Linux/EthernetClient.d drivers/Linux/SerialPort.d drivers/Linux/Stream.d drivers/Linux/Print.d drivers/Linux/IPAddress.d drivers/Linux/compatibility.d drivers/Linux/EthernetServer.d examples_linux/mysGateway.d drivers/RPi/piHiPri.d drivers/RPi/bcm2835.d drivers/RPi/rpi_util.d drivers/RPi/Wire.d drivers/RPi/SPI.d
              **After uninstalling, reset the configuration, and installed and started the gateway. **
              pi@raspberrypi:~/MySensors $ ./configure --my-debug=enable --my-gateway=serial --my-serial-is-pty --my-serial-pty=ttyMySensorsGateway --my-transport=nrf24 --my-rf24-channel=76
              [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
              [OK] init system detected: systemd
              [OK] Finished.
              Make all
              pi@raspberrypi:~/MySensors $ sudo make all
              cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
              cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/piHiPri.o drivers/RPi/piHiPri.c
              cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/bcm2835.o drivers/RPi/bcm2835.c
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/rpi_util.o drivers/RPi/rpi_util.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/Wire.o drivers/RPi/Wire.cpp
              g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_RF24_CHANNEL=76 -DMY_LINUX_SERIAL_PTY=\"ttyMySensorsGateway\" -DMY_IS_SERIAL_PTY  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/RPi/SPI.o drivers/RPi/SPI.cpp
              g++ -pthread  -o examples_linux/mysGateway drivers/Linux/log.o drivers/Linux/noniso.o drivers/Linux/Print.o drivers/Linux/EthernetClient.o drivers/Linux/SerialPort.o drivers/Linux/Stream.o drivers/Linux/IPAddress.o drivers/Linux/compatibility.o drivers/Linux/SoftEeprom.o drivers/Linux/EthernetServer.o examples_linux/mysGateway.o drivers/RPi/piHiPri.o drivers/RPi/bcm2835.o drivers/RPi/rpi_util.o drivers/RPi/Wire.o drivers/RPi/SPI.o
              Sudo make install
              pi@raspberrypi:~/MySensors $ sudo make install
              Installing examples_linux/mysGateway to /usr/local/bin
              install -m0644 initscripts/mysgateway.systemd /etc/systemd/system/mysgateway.service
              systemctl daemon-reload
              MySensors gateway has been installed, to add to the boot run:
              To start the gateway run:
                sudo systemctl start mysgateway.service
              start the gateway
              pi@raspberrypi:~/MySensors $ sudo systemctl start mysgateway.service
              Start the debug on the gateway:
              pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
              mysGateway: Starting gateway...
              mysGateway: Protocol version - 2.0.1-beta
              mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
              mysGateway: TSF:LRT:OK
              mysGateway: TSM:INIT
              mysGateway: TSM:INIT:TSP OK
              mysGateway: TSM:INIT:GW MODE
              mysGateway: TSM:READY
              mysGateway: MCO:REG:NOT NEEDED
              mysGateway: MCO:BGN:STP
              mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
              mysGateway: !TSF:MSG:LEN,0!=7
              Now, the gateway on the Raspberry Pi 2 seem ok and up and running. Moving over to the sensor node, the Arduino Uno with NRF24L01+.
              Uploaded and ran the Clear_EPROM sketch
              * This sketch clears radioId, relayId and routing info in EEPROM
              #include <EEPROM.h>
                for (int i=0;i<512;i++) {
                  EEPROM.write(i, 0xff);
                Serial.println("EEPROM cleared");
                // Nothing to do here...
              After this I uploaded your recommended default sketch. However I added "#define MY_RF24_CHANNEL 76"
              int lastLightLevel;
                sleep(SLEEP_TIME);
              The result, enoyingly is the same it seems based on the output from the Serial Monitor from the Arduino Uno.
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              Frustrating... Can it be other modules, libraries than what I've not installed on the Raspberry Pi that is the reason for the error?
              • alexsh1A
                alexsh1A
                alexsh1
                @Christian-Simonsen ok, you have an amplified version of nrf24l01+. It does require more power and could be a problem. How are feeding it from Raspberry please?
                Can you try a normal nrf24l01+ on Raspberry? Just like the one you have on a sensor and report back?
                Christian SimonsenC 1 Reply Last reply
                • alexsh1A alexsh1
                  Christian SimonsenC
                  Christian SimonsenC
                  Christian Simonsen
                  @alexsh1
                  Again thanks for all the help, very much appreciated.
                  I started last evening putting together a few more NRF24L01 sensors such as the one on the Node. I will also setup a new extra Arduino Gateways, so I also can test communication between two Arduinos, before testing the same with the Raspberry Pi. Ill report back later tonight when I know the results.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @Christian-Simonsen I bet the problem is with your GW radio
                    • alexsh1A alexsh1
                      Christian SimonsenC
                      Christian SimonsenC
                      Christian Simonsen
                      @alexsh1
                      You are 100 % correct :+1: :)
                      I changed the NRF24L01 module with the antenna, with a standard NRF24L01+ module. And it works like a charm.
                      Here are the Serial Monitor code from the Arduino (Sensor node). I don't currently understand what all the code says, but it seems like they are communicating.
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      TSP:MSG:FPAR (PPAR FOUND)
                      TSP:MSG:PAR OK (ID=0, dist=1)
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=1)
                      TSM:UPL
                      TSP:PING:SEND (dest=0)
                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                      TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      TSP:MSG:PONG RECV (hops=1)
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                      TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Light Sensor
                      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                      TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
                      Request registration...
                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=fail:2
                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=fail:2
                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=fail:2
                      !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                      Init complete, id=1, parent=0, distance=1, registration=1
                      50
                      !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:50
                      56
                      !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:56
                      !TSM:UPL FAIL, STATP
                      58
                      !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:58
                      58
                      58
                      And from the Raspberry Pi
                      mysGateway: !TSF:MSG:LEN,8!=7
                      mysGateway: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      mysGateway: TSF:MSG:BC
                      mysGateway: TSF:MSG:FPAR REQ,ID=1
                      mysGateway: TSF:PNG:SEND,TO=0
                      mysGateway: TSF:CKU:OK
                      mysGateway: TSF:MSG:GWL OK
                      mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      mysGateway: TSF:MSG:PINGED,ID=1,HP=1
                      mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      mysGateway: TSF:MSG:READ,0-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        Christian SimonsenC
                        Christian Simonsen
                        I have connection, however the communication seem to fail after a while. Seems to get worse and worse. I'm currently sending a msg every 30 seconds from the node. See code below.
                        Gateway on the Raspberry Pi:
                        mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:50
                        mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:57
                        mysGateway: !TSF:MSG:LEN,0!=9
                        mysGateway: !TSF:MSG:LEN,9!=7
                        mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:56
                        And the code from the Arduino Uno Node
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=1)
                        TSM:UPL
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                        TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        Node registration=1
                        50
                        TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:50
                        55
                        TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:55
                        57
                        TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:57
                        57
                        56
                        TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:56
                        56
                        57
                        58
                        TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:58
                        57
                        58
                        56
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:56
                        55
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=fail:55
                        55
                        55
                        59
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=fail:59
                        58
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=fail:58
                        56
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:56
                        58
                        !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:58
                        !TSM:UPL FAIL, SNP
                        TSM:FPAR
                        56
                        !TSP:SEND:TNR```
                          Christian SimonsenC
                          Christian Simonsen
                          My sensors are located about 3 meters apart with nothing in between. To mitigate the packet loss I've increased by the Gateway to RF24_PA_HIGH and the Arduino to RF24_PA_MAX. I tested MAX on the Gateway aswell, but it didn't seem to handle this setting.
                          Note I've changed the code of the Node - it now sends a number per msg, and it increases by 1 for each message. This way I found it easier to track which msg that succeeded and which didn't.
                          First it looked ok, but the msg started to fail after some time (note: I have 3 seconds between each message now)
                          When I start the Gateway by using "sudo ./examples_linux/mysGateway -d" it starts fine, and connects with the Arduino which I restart at the same time as I type the code above in terminal to start the Gateway on the Raspberry Pi.
                          After the setup it seems like most of the first 13 messages go through successfully. Then the next 10 messages fail (atleast looks like it on the GW debug info). Then there is another good period from 23-40, but with a few lost. Then the rest fail, and the sensor also starts reporting the messages as failed. After this I have to restart the Sensor node to be able to regain communication.
                          Do anyone know what is wrong... ?
                          The Raspberry Pi Gateway:
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:1
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:2
                          mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                          mysGateway: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          mysGateway: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          mysGateway: !TSF:MSG:LEN,0!=8
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:3
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:4
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:6
                          mysGateway: !TSF:MSG:LEN,17!=7
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:8
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:9
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:10
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:11
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:13
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:23
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:25
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:28
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:30
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:31
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:33
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:34
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:37
                          mysGateway: TSF:MSG:READ,1-1-0,s=0,c=1,t=23,pt=2,l=2,sg=0:40
                          And the Arduino sensor node:
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=1)
                          TSM:UPL
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          Node registration=1
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:0
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:1
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:2
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:3
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:4
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:6
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:7
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:8
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:9
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:10
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:11
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:12
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:13
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:14
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:15
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:16
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:17
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:18
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:19
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:20
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:21
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:22
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:23
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:24
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:25
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:26
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:27
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:28
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:29
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:30
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:31
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:32
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:33
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:34
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:35
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:36
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:37
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:38
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:39
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:40
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:41
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:42
                          TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:43
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=fail:44
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=fail:45
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=fail:46
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=fail:47
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=fail:48
                          !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=fail:49
                          !TSM:UPL FAIL, SNP
                          TSM:FPAR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                          !TSP:SEND:TNR
                            Christian SimonsenC
                            Christian Simonsen
                            HI,
                            I've been doing some testing. I have two Gateways
                            1. Raspberry Pi 2 with a NRF24L01+ module connected to the GPIO pins
                            2. Arduino Nano with a NRF24L01+ module connected via a breadboard to my MacBook Pro
                            The sensor node is an Arduino Uno with a NRF24L01+ module. This sensor is sending out a higher number for each packet (eg. 1, 2, 3, 4)
                            Between the Raspberry Pi 2 gateway is have a lot of data loss as shown in earlier posts even with just 3 meters a part. However using the Arduino Nano as the gateway I can walk across the apartment with loosing anything (10+ meters away).
                            I've switched the NRF24L01 modules around and the result is the same.
                            I have now two possible reasons:
                            1. Something is wrong related to the Raspberry Pi 2 - The code, libraries, power to the NRF24L01 etc.
                            2. The Raspberry Pi is next to my ASUS RT-AC87U wireless router... maybe it is interfering (I don't think it is this, as I didn't have any packet loss with the Arduino Nano when I held it next to the router)
                            I therefore think it is related to point 1. The Raspberry Pi 2. But don't know what it could be...
                            Any ideas?
                              HI,
                              Any ideas?
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @Christian-Simonsen I have been testing RPi 3 with nrf24l01+ for a month or so - it works just fine.
                              Your problem (TSM:MSG:LEN) is more related to a communication error between the transceiver and RPi/Arduino. Firstly, try adding the following
                              #define MY_RF24_SANITY_CHECK
                              The way I have it setup on my RPi is that I feed nrf24l01+ via 5V pin through AMS1117 3.3
                              Remember that 3.3v is limited in terms of current (hence your problem with PA version).
                              I recommend using one of these boards designed by @GertSanders
                              What transceivers do you have nrf24l01 or nrf2401+?
                              In relation to the data rate use the lower RF24_250KBPS (by default).
                              Another issue is RF24_PA_LEVEL_GW and RF24_PA_LEVEL
                              See - https://forum.mysensors.org/topic/4034/my-first-gateway
                              Remember if you have modules too close and set the PA leave high, the modules will be screaming to each other.
                              Finally, appreciate your GW on Mac works fine as supposed to your RPi GW. There can be a few reasons for this. Just try to eliminate issues one by one. You have to do a lot of readings on this forum and some DIY trial and error.
                              • alexsh1A alexsh1
                                Christian SimonsenC
                                Christian SimonsenC
                                Christian Simonsen
                                @alexsh1
                                Hi Alex,
                                I tested the Sanity check on the the Arduino sensor node, and status came back OK. However I could get this to work on the Raspberry Pi, seems like this function is not yet supported. At least I couldn't find any info on it using the "./configuration -h".
                                I don't have a AMS1117 available so I can test that.
                                I connected my Arduino Nano and NRF24L01+ to the Raspberry Pi via USB, that would really well. So I might just use this solution instead as I see little benefit of connecting the NRF24L01 directly to the GPIO pins on the Raspberry Pi.
                                Next step is to start building some battery powered sensors that I can use, and get MyController setup properly.
