  3. Motion Sensor debounce
10 Posts 3 Posters 5.0k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I am not sure how this can be done.
    Basically, I have a Panasonic PIR on Moteino with RFM69W working just fine. The problem is that it is spamming GW with messages.
    I need to introduce a delay - if PIR triggered, no more messages to GW for 30 secs or so. My issue is that the node is sleeping:
    sleep(digitalPinToInterrupt(MOTION_INPUT_PIN), CHANGE, SLEEP_TIME)
    and millis() are not working during sleeping.
    My question is this: How do I introduce a delay, say 30 sec, in order not to spam my GW/Controller with "Security Lighting" (this is how it is recognised in Domoticz). Such delay must work with the sleep function above.
    Appreciate if you could share your ideas
    Regards
    Alex
    • alexsh1A alexsh1
      Regards
      Alex
      @alexsh1 how about adding
      sleep(30*1000)
      just before
      perhaps with an if statement that only invokes sleep(30*1000) if the sensor was triggered.
      An alternative could be to add an if-statement that only sends a message if the value was changed from last time.
      Edit: added *1000 to convert the seconds to milliseconds
      alexsh1A 1 Reply Last reply
        sleep(30*1000)
        just before
        alexsh1A
        alexsh1A
        alexsh1
        @mfalkvidd, you mean
        define DEBOUNCE 30000 //
        sleep(DEBOUNCE);
        This just delays it ANYWAY regardless whether the PIR was triggered or not.
        When it comes to "if", during one trigger, my PIR is changing the status from 0 to 1 and back to 0. Unfortunately, I cannot count millis() when sleeping. How can use count 30 secs from the last even when the PIR was triggered please? Very much appreciate your suggestion.
        • alexsh1A alexsh1
          sleep(DEBOUNCE);
          @alexsh1 hard to say without knowing what else your node does. If it does nothing, the sleep 30000 will be enough. You could connect a RTC, but that might also affect what else the node does.
            alexsh1A
            alexsh1A
            alexsh1
            @mfalkvidd The node is a PIR + reporting baro+temp+hum (BME280) every 5 minutes as well as battery voltage.
            • alexsh1A alexsh1
              @alexsh1 save the return value from your existing sleep into a variable. Add an if statement that does sleep(30000) only if your node was waken up by interrupt.
              Documentation for the return value is available at https://www.mysensors.org/download/sensor_api_20#sleeping
                alexsh1A
                alexsh1A
                alexsh1
                @mfalkvidd That's got be the last nail in the coffin - thanks for your help!
                • alexsh1A
                  alexsh1A
                  alexsh1
                  I think the final product would be looking like this:
                  #define DUPLICATE_INTERVAL 30000
                  if (sleep(digitalPinToInterrupt(MOTION_INPUT_PIN), CHANGE, SLEEP_TIME)) {
                        motionDetected = true;
                        motionTrips++;
                        sleep(DUPLICATE_INTERVAL);
                  Testing now
                  • alexsh1A alexsh1
                          motionTrips++;
                    Testing now
                    @alexsh1 I think you need to test för >= 0. The If statement will return true for anything non-zero so the current test will fail. Except that, the code looks great.
                    ileneken3I 1 Reply Last reply
                      ileneken3I
                      ileneken3I
                      ileneken3
                      @mfalkvidd
                      This worked well for me, for a vibration sensor:
                      if (sleep(digitalPinToInterrupt(MOTION_INPUT_PIN), CHANGE, SLEEP_TIME) != -1) {
                      // Interrupt occurred, do whatever is needed and then
                      // clear any "floating" interrupts before going on.
                      while (sleep(digitalPinToInterrupt(MOTION_INPUT_PIN),CHANGE,1000) != -1 ) {
                      Serial.println("Clearing interrupts");
                      12.5k
