  3. RelayActuator message not going threw
17 Posts 3 Posters 5.5k Views 1 Watching
  • frenchoF frencho
    @tekka thanks for the analysis !
    I have tryied two different GW : one was with gertsanders arduino module, one with a arduino pro mini 3.3V/8Mhz ATM328
    they are connected with FTDI to the computer / domotic box
    the speed is set to 115200 baud
    here is the GW sketch
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    tekkaT
    tekkaT
    tekka
    @frencho Hmm, sketch looks fine - what surprises me are the two GW init messages:
    03/11/2016 21:12:33 RX  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
    03/11/2016 21:12:33 RX  0;255;3;0;9;TSM:INIT
    03/11/2016 21:12:33 RX  0;255;3;0;9;TSM:INIT:TSP OK
    03/11/2016 21:12:33 RX  0;255;3;0;9;TSM:INIT:GW MODE
    03/11/2016 21:12:33 RX  0;255;3;0;9;TSM:READY
    03/11/2016 21:12:33 RX  0;255;3;0;14;Gateway startup complete.
    03/11/2016 21:12:50 RX  0;255;3;0;9;!TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
    03/11/2016 21:12:50 RX  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
    03/11/2016 21:12:50 RX  0;255;3;0;9;TSM:INIT
    03/11/2016 21:12:50 RX  0;255;3;0;9;TSM:INIT:TSP OK
    03/11/2016 21:12:50 RX  0;255;3;0;9;TSM:INIT:GW MODE
    03/11/2016 21:12:50 RX  0;255;3;0;9;TSM:READY
    03/11/2016 21:12:50 RX  0;255;3;0;14;Gateway startup complete.
    You should try with a different FTDI adapter or power your GW with a good power supply.
    frenchoF 1 Reply Last reply
    • tekkaT tekka
      frenchoF
      frenchoF
      frencho
      @tekka thanks again. Which two init message are unusual ?
      I just tried an other FDTI adapter nothing changed.
      The gateway is power via the FDTI/USB !! this thing is driving me crazy !
      I'll try also tonight to power GW with 2 AA bat, and read Serial only with the FDTI
      I think I'm going to buy a moteino, I hope it will solve my problems.
      Your second life begins when you understand you only have one !
      tekkaT 1 Reply Last reply
      • frenchoF frencho
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @frencho
        These two, of particular interest is the second init message...
        ...as it appears right after
        What Arduino IDE version and AVR board def version are you using?
        • tekkaT tekka
          @frencho
          frenchoF
          frenchoF
          frencho
          @tekka arduino 1.6.11 and AVRISP mkII
          It looks like the Tx serial from PC to GW is not working ! when I send a command, I see the Tx from FDTI blinking, ...
          I posted other msg on the forum previously, beacause I can't get ride of the fail debug below
          I'll try today to program the gateway from my Mac
          • frenchoF frencho
            tekkaT
            tekkaT
            tekka
            @frencho regarding the NACK: this has been addressed here: https://github.com/mysensors/MySensors/pull/630
            • tekkaT tekka
              frenchoF
              frenchoF
              frencho
              @tekka I recompiled everything with the latest Dev Branch, the init problem of the GW is solved.
              On GW Side :
              06/11/2016 14:56:51	INFO	Connected to COM10
              06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
              06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT
              06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:TSP OK
              06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:GW MODE
              06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:READY
              06/11/2016 14:56:52	RX	0;255;3;0;14;Gateway startup complete.
              06/11/2016 14:56:52	DEBUG	Update child id=255, type=ARDUINO_RELAY
              06/11/2016 14:56:52	RX	0;255;0;0;18;2.0.1-beta
              06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:REG:NOT NEEDED
              06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:STP
              06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:READ,65-65-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:BC
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=65
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:PNG:SEND,TO=0
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:CKU:OK
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:GWL OK
              06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:PINGED,ID=65,HP=1
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=0,t=18,pt=0,l=10,sg=0:2.0.1-beta
              06/11/2016 14:57:27	NODE	New node discovered, node id=65
              06/11/2016 14:57:27	CHILD	New child discovered, node id=65, child id=internal
              06/11/2016 14:57:27	DEBUG	Update child id=255, type=ARDUINO_RELAY
              06/11/2016 14:57:27	RX	65;255;0;0;18;2.0.1-beta
              06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              06/11/2016 14:57:27	TX	65;255;3;0;6;M
              06/11/2016 14:57:27	RX	65;255;3;0;6;0
              06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
              06/11/2016 14:57:29	RX	65;255;3;0;11;Relay
              06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
              06/11/2016 14:57:29	RX	65;255;3;0;12;1.0
              06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
              06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=1
              06/11/2016 14:57:29	DEBUG	Update child id=1, type=LIGHT
              06/11/2016 14:57:29	RX	65;1;0;0;3;
              06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
              06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=2
              06/11/2016 14:57:29	DEBUG	Update child id=2, type=LIGHT
              06/11/2016 14:57:29	RX	65;2;0;0;3;
              06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
              06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=3
              06/11/2016 14:57:30	DEBUG	Update child id=3, type=LIGHT
              06/11/2016 14:57:30	RX	65;3;0;0;3;
              06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
              06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=4
              06/11/2016 14:57:30	DEBUG	Update child id=4, type=LIGHT
              06/11/2016 14:57:30	RX	65;4;0;0;3;
              06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              06/11/2016 14:59:38	TX	65;1;1;0;2;
              06/11/2016 14:59:43	TX	65;1;1;0;2;1
              06/11/2016 14:59:48	TX	65;1;1;1;2;1
              on node side :
              0 MCO:BGN:INIT REPEATER,CP=RRNRA--,VER=2.0.1-beta
              4 MCO:BGN:BFR
              6 TSM:INIT
              8 TSM:INIT:TSP OK
              10 TSF:SID:OK,ID=65
              12 TSM:FPAR
              145 TSF:MSG:SEND,65-65-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              493 TSF:MSG:READ,0-0-65,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              497 TSF:MSG:FPAR OK,ID=0,D=1
              2152 TSM:FPAR:OK
              2152 TSM:ID
              2154 TSM:ID:OK
              2156 TSM:UPL
              2164 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2183 TSF:MSG:READ,0-0-65,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2189 TSF:MSG:PONG RECV,HP=1
              2191 TSM:UPL:OK
              2193 TSM:READY
              2203 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2326 TSF:MSG:READ,0-0-65,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2385 TSF:MSG:SEND,65-65-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
              2402 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4419 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
              4433 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4450 TSF:MSG:SEND,65-65-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4464 TSF:MSG:SEND,65-65-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4481 TSF:MSG:SEND,65-65-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4495 TSF:MSG:SEND,65-65-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4501 MCO:REG:REQ
              4511 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4569 TSF:MSG:READ,0-0-65,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4575 MCO:PIM:NODE REG=1
              4579 MCO:BGN:STP
              4581 MCO:BGN:INIT OK,ID=65,PAR=0,DIS=1,REG=1
              The other problem is still here, nothing happen when I try to change state of relay.
              I tryed to send the the only Tx message sent during communication between GW and Node
              and nothing
              I also noticed every now and then that the Node is forwarding some broadcast message from GW :
              477822 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
              477831 TSF:MSG:BC
              478488 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
              478496 TSF:MSG:FWD BC MSG
              478629 TSF:MSG:SEND,0-65-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              It's got to be a problem bewteen PC/Rasp and GW ... maybe my FDTI ... but I have 2 different !
              • frenchoF frencho
                On GW Side :
                on node side :
                4 MCO:BGN:BFR
                6 TSM:INIT
                8 TSM:INIT:TSP OK
                10 TSF:SID:OK,ID=65
                12 TSM:FPAR
                2152 TSM:FPAR:OK
                2152 TSM:ID
                2154 TSM:ID:OK
                2156 TSM:UPL
                2191 TSM:UPL:OK
                2193 TSM:READY
                4501 MCO:REG:REQ
                4579 MCO:BGN:STP
                and nothing
                477831 TSF:MSG:BC
                frenchoF
                frenchoF
                frencho
                @tekka I have tried the FDTI with a dummy sketch. I confirm that the RX/TX is working as I change the value of a variable via serial port.
                Multiple speed have been tested, from 9600 to 115200.
                Looking at the failure tree, I see no other branch to cut down !
                Serial com is working
                the GW and node seems fine (regarding log)
                So why the GW doesn't react when it gets serial messages ?
                • frenchoF frencho
                  tekkaT
                  tekkaT
                  tekka
                  @frencho Hmm, something seems to disturb the serial traffic. What happens if you use the Arduino serial monitor (change line ending to NR & CR) and enter:
                  65;0;3;0;13;0
                  (this is a reboot command)
                  Also, what version of MYSController are you on?
                  frenchoF 2 Replies Last reply
                  • tekkaT tekka
                    65;0;3;0;13;0
                    frenchoF
                    frenchoF
                    frencho
                    @tekka tried what you asked, and some more stuff, still nothing happening
                    the reboot command send doesn't do anything, the MYSController version is 0.1.2.282
                    • tekkaT tekka
                      65;0;3;0;13;0
                      frenchoF
                      frenchoF
                      frencho
                      @tekka could it come from something i setup wrong in the Myconfig.h ?
                      • frenchoF frencho
                        tekkaT
                        tekkaT
                        tekka
                        @frencho Depends, what did you change in MyConfig.h? Also, try using the latest version of MYSController (1.0.0beta, >=3314)
                        • tekkaT tekka
                          F
                          F
                          frenchclem
                          @tekka unbelievable !!! I tried with NRF24 and arduino nano, it's working like a charm !!!
                          If I use the same sketch, on a pro mini using one of my ftdi as serial interface the Tx don't go threw anymore !!!
                          Ftdi use a 1047 chip
                          Arduino nano use a CH340 for which I had to install a Chinese driver for it !?!? !!!!
                          12.5k
