  3. RelayActuator message not going threw
17 Posts 3 Posters 5.5k Views 1 Watching
  • frenchoF frencho
    @tekka thanks again. Which two init message are unusual ?
    I just tried an other FDTI adapter nothing changed.
    The gateway is power via the FDTI/USB !! this thing is driving me crazy !
    I'll try also tonight to power GW with 2 AA bat, and read Serial only with the FDTI
    I think I'm going to buy a moteino, I hope it will solve my problems.
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    @frencho
    These two, of particular interest is the second init message...
    03/11/2016 21:12:33 RX  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
    03/11/2016 21:12:50 RX  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
    ...as it appears right after
    03/11/2016 21:12:50 RX  0;255;3;0;9;!TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
    What Arduino IDE version and AVR board def version are you using?
    frenchoF 1 Reply Last reply
    • tekkaT tekka
      @frencho
      frenchoF
      frenchoF
      frencho
      @tekka arduino 1.6.11 and AVRISP mkII
      It looks like the Tx serial from PC to GW is not working ! when I send a command, I see the Tx from FDTI blinking, ...
      I posted other msg on the forum previously, beacause I can't get ride of the fail debug below
      I'll try today to program the gateway from my Mac
      Your second life begins when you understand you only have one !
      tekkaT 1 Reply Last reply
      • frenchoF frencho
        tekkaT
        tekkaT
        tekka
        @frencho regarding the NACK: this has been addressed here: https://github.com/mysensors/MySensors/pull/630
        • tekkaT tekka
          frenchoF
          frenchoF
          frencho
          @tekka I recompiled everything with the latest Dev Branch, the init problem of the GW is solved.
          On GW Side :
          06/11/2016 14:56:51	INFO	Connected to COM10
          06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta
          06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT
          06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:TSP OK
          06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:INIT:GW MODE
          06/11/2016 14:56:52	RX	0;255;3;0;9;TSM:READY
          06/11/2016 14:56:52	RX	0;255;3;0;14;Gateway startup complete.
          06/11/2016 14:56:52	DEBUG	Update child id=255, type=ARDUINO_RELAY
          06/11/2016 14:56:52	RX	0;255;0;0;18;2.0.1-beta
          06/11/2016 14:56:52	RX	0;255;3;0;9;MCO:REG:NOT NEEDED
          06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:STP
          06/11/2016 14:56:53	RX	0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:READ,65-65-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:BC
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=65
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:PNG:SEND,TO=0
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:CKU:OK
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:GWL OK
          06/11/2016 14:57:25	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:PINGED,ID=65,HP=1
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=0,t=18,pt=0,l=10,sg=0:2.0.1-beta
          06/11/2016 14:57:27	NODE	New node discovered, node id=65
          06/11/2016 14:57:27	CHILD	New child discovered, node id=65, child id=internal
          06/11/2016 14:57:27	DEBUG	Update child id=255, type=ARDUINO_RELAY
          06/11/2016 14:57:27	RX	65;255;0;0;18;2.0.1-beta
          06/11/2016 14:57:27	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          06/11/2016 14:57:27	TX	65;255;3;0;6;M
          06/11/2016 14:57:27	RX	65;255;3;0;6;0
          06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
          06/11/2016 14:57:29	RX	65;255;3;0;11;Relay
          06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          06/11/2016 14:57:29	RX	65;255;3;0;12;1.0
          06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
          06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=1
          06/11/2016 14:57:29	DEBUG	Update child id=1, type=LIGHT
          06/11/2016 14:57:29	RX	65;1;0;0;3;
          06/11/2016 14:57:29	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=2,c=0,t=3,pt=0,l=0,sg=0:
          06/11/2016 14:57:29	CHILD	New child discovered, node id=65, child id=2
          06/11/2016 14:57:29	DEBUG	Update child id=2, type=LIGHT
          06/11/2016 14:57:29	RX	65;2;0;0;3;
          06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
          06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=3
          06/11/2016 14:57:30	DEBUG	Update child id=3, type=LIGHT
          06/11/2016 14:57:30	RX	65;3;0;0;3;
          06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=4,c=0,t=3,pt=0,l=0,sg=0:
          06/11/2016 14:57:30	CHILD	New child discovered, node id=65, child id=4
          06/11/2016 14:57:30	DEBUG	Update child id=4, type=LIGHT
          06/11/2016 14:57:30	RX	65;4;0;0;3;
          06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:READ,65-65-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          06/11/2016 14:57:30	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-65-65,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          06/11/2016 14:59:38	TX	65;1;1;0;2;
          06/11/2016 14:59:43	TX	65;1;1;0;2;1
          06/11/2016 14:59:48	TX	65;1;1;1;2;1
          on node side :
          0 MCO:BGN:INIT REPEATER,CP=RRNRA--,VER=2.0.1-beta
          4 MCO:BGN:BFR
          6 TSM:INIT
          8 TSM:INIT:TSP OK
          10 TSF:SID:OK,ID=65
          12 TSM:FPAR
          145 TSF:MSG:SEND,65-65-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          493 TSF:MSG:READ,0-0-65,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          497 TSF:MSG:FPAR OK,ID=0,D=1
          2152 TSM:FPAR:OK
          2152 TSM:ID
          2154 TSM:ID:OK
          2156 TSM:UPL
          2164 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2183 TSF:MSG:READ,0-0-65,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2189 TSF:MSG:PONG RECV,HP=1
          2191 TSM:UPL:OK
          2193 TSM:READY
          2203 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          2326 TSF:MSG:READ,0-0-65,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          2385 TSF:MSG:SEND,65-65-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
          2402 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          4419 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
          4433 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
          4450 TSF:MSG:SEND,65-65-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          4464 TSF:MSG:SEND,65-65-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          4481 TSF:MSG:SEND,65-65-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          4495 TSF:MSG:SEND,65-65-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          4501 MCO:REG:REQ
          4511 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          4569 TSF:MSG:READ,0-0-65,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          4575 MCO:PIM:NODE REG=1
          4579 MCO:BGN:STP
          4581 MCO:BGN:INIT OK,ID=65,PAR=0,DIS=1,REG=1
          The other problem is still here, nothing happen when I try to change state of relay.
          I tryed to send the the only Tx message sent during communication between GW and Node
          and nothing
          I also noticed every now and then that the Node is forwarding some broadcast message from GW :
          477822 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
          477831 TSF:MSG:BC
          478488 TSF:MSG:SEND,65-65-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
          478496 TSF:MSG:FWD BC MSG
          478629 TSF:MSG:SEND,0-65-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          It's got to be a problem bewteen PC/Rasp and GW ... maybe my FDTI ... but I have 2 different !
          • frenchoF frencho
            On GW Side :
            on node side :
            4 MCO:BGN:BFR
            6 TSM:INIT
            8 TSM:INIT:TSP OK
            10 TSF:SID:OK,ID=65
            12 TSM:FPAR
            2152 TSM:FPAR:OK
            2152 TSM:ID
            2154 TSM:ID:OK
            2156 TSM:UPL
            2191 TSM:UPL:OK
            2193 TSM:READY
            4501 MCO:REG:REQ
            4579 MCO:BGN:STP
            and nothing
            477831 TSF:MSG:BC
            frenchoF
            frenchoF
            frencho
            @tekka I have tried the FDTI with a dummy sketch. I confirm that the RX/TX is working as I change the value of a variable via serial port.
            Multiple speed have been tested, from 9600 to 115200.
            Looking at the failure tree, I see no other branch to cut down !
            Serial com is working
            the GW and node seems fine (regarding log)
            So why the GW doesn't react when it gets serial messages ?
            • frenchoF frencho
              tekkaT
              tekkaT
              tekka
              @frencho Hmm, something seems to disturb the serial traffic. What happens if you use the Arduino serial monitor (change line ending to NR & CR) and enter:
              65;0;3;0;13;0
              (this is a reboot command)
              Also, what version of MYSController are you on?
              frenchoF 2 Replies Last reply
              • tekkaT tekka
                65;0;3;0;13;0
                frenchoF
                frenchoF
                frencho
                @tekka tried what you asked, and some more stuff, still nothing happening
                the reboot command send doesn't do anything, the MYSController version is 0.1.2.282
                • tekkaT tekka
                  65;0;3;0;13;0
                  frenchoF
                  frenchoF
                  frencho
                  @tekka could it come from something i setup wrong in the Myconfig.h ?
                  • frenchoF frencho
                    tekkaT
                    tekkaT
                    tekka
                    @frencho Depends, what did you change in MyConfig.h? Also, try using the latest version of MYSController (1.0.0beta, >=3314)
                    • tekkaT tekka
                      F
                      F
                      frenchclem
                      @tekka unbelievable !!! I tried with NRF24 and arduino nano, it's working like a charm !!!
                      If I use the same sketch, on a pro mini using one of my ftdi as serial interface the Tx don't go threw anymore !!!
                      Ftdi use a 1047 chip
                      Arduino nano use a CH340 for which I had to install a Chinese driver for it !?!? !!!!
                      12.5k
