  3. Boiler control from MAX! Cube to Drayton Boiler via Raspberry Pi/Vera/Mysensors.
113 Posts 22 Posters 81.6k Views 24 Watching
  • mfalkviddM
    Here is how to open a private chat. Click the persons name at the top of a post. Then click the blue three-dot menu.
      Stuart Middleton
      Ah, sql syntax (according to a website I found) uses double single-quote to escape a single quote when used in a table.
        stephenmhall
        Ok after faffing about for ages I ended up just moving your replace quote code into the database file, keeps it out of the way and seems to work ok if I simulate a room with a quote in it and without.
        It is happy saving names with a quote in to the DB it is just searching after that needs it doubled. Something else learned.
          Stuart Middleton
          Cool, thanks. I'll grab it so the version I'm running is in sync.
            stephenmhall
            wrote on last edited by stephenmhall
            #57
            For @simrob problem.
            I think the problem is in the database, and my code of course, With the way I developed it over time I think I added features later that cause a problem with a fresh install because It asks for the room names before it creates them. Where my database already had room names populated before I got to that point.
            Could you install "DB Browser for SQLite" and have a look at the heating.db file that was created. Under brows data there should be a rooms table like mine.
            "4" "Living Room" "1051D6"
            "5" "Dining-Extension" "106FD5"
            "2" "Bathroom" "1051DA"
            "3" "Bedroom 1" "116B63"
            "1" "Bedroom 2" "1163A5"
            If it is empty possibly just adding one record with the correct name and a random GroupID might be enough to get it past the point where it fails so it can fully populate the table. Also I think you must be using an older version as your line numbers don't quite match what I have. Try downloading the vera Virtual Thermostats branch and see if that helps, not saying it will but that will become the main branch when I sync it up.
            I will look at getting in installed again on a blank Pi so I can test and fix this properly. But hopefully putting a line of data in the DB rooms table will get you past the problem.
              stephenmhall
              I have now changed the folder layout on github to make installing easier, also updated some of the files to hopefully stop the error on first run.
              I tried on a blank Raspberry and it all seemed to work ok.
              Give the README instructions a once over and see how it goes.
              • T
                twisted
                After many delays and other items got in the way I finally have almost sully working system. I do have one issue I am struggling with and that is that I can't seem to turn the boiler off once the temperatures have been met.
                Also is there any way some of the configuration page could be clarified as there are a number of options I am a little unsure about.
                  stephenmhall
                  @twisted I have added a text file to explain the variables. As for not turning the heating off, not sure, remember that normally the Max system will gradually close the valves on the radiators as the temp goes over the requested temp, you will normally get a half degree or so higher. if it never shuts off I don't understand that it just sends the same vera command with a 1 or a 0.
                  link to variables file on Git.
                  • T
                    twisted
                    wrote on last edited by twisted
                    #61
                    Just saw the explanation txt appear, thank you so much, it means I can double check what I set was correct.
                    Funnily I noticed as it just appeared when I was searching the code to work out a couple of bits.
                    • René VerbeekR
                      René VerbeekR
                      René Verbeek
                      Is the Max Boiler Controller from eq-3 not an option to do this more easily? It was introduced by eq-3 for the British market, but is now not available anymore. Google for BC-TS-Sw2-WM to get the manual from eq-3. Maybe we should push eq-3 to reintroduce this product again.
                        stephenmhall
                        Never seen that before, reading the instructions it looks like it switches the boiler on using a daily timer function like the room heating and and a thermostat temperature, possibly if it switches on if any of the rooms are cold that would work. Not saying mine is better but it monitors the valves and gives you heat on demand when any of the radiators call for it.
                        • T
                          twisted
                          I have to say using Vera and the boiler switch attached to that is a great solution, if I could just get past one problem. I wonder if anyone else is experiencing this, but I find the time taken for the valves to respond to the temperature changes is a little slow. Lets say I set the required temperature to 19c most rooms jump to 20/21 before the valves close enough to actually prevent further heating to the room.
                          My thoughts at the moment are to see if I can somehow directly communicate with the valves or maybe set offsets for each temp on the valves so they read a couple of degrees high.
                          Anyone have any thoughts?
                            stephenmhall
                            What I do is only supply heat if valve is open more than 80% or more than 2 valves open 60% so heat shuts off at about 21.9 if you are looking for 22, then the residual heat in the radiator takes temp to about 22.2 before the room starts to slowly cool over the next hour or so down to 21.7 when the valve opens up enough to bring the heat back on.
                              Stuart Middleton
                              twisted, unfortunately you can't directly communicate with the valves. AFAIK the way the work is that they initiate communication with the cube every 2(?) minutes and not the other way around. The cube just listens for the data and then sends data back to the valve. This is to conserve battery so the valve doesn't need to be active all the time. I'm sure stephenmhall will correct me if I'm wrong :)
                                stephenmhall
                                As far as Cube to valves and valves to cube comms, I think it must be bi-directional as if you change anything on the cube app it happens pretty much instantly. How the cube and valves communicate could be magic for all I know :) they are on the 868Mhz band but what the protocol is I don't know.
                                I recently read about a company in Germany called busware.de that makes a Raspberry interface card that has firmware that speaks MAX protocol, I have sent them an email looking to confirm this but not heard anything back yet. If I could cut the Cube out of my system I would be very happy as it is the least reliable part, it seems to factory reset itself every couple of months.
                                  Stuart Middleton
                                  wrote on last edited by Stuart Middleton
                                  #68
                                  Ah, well, I think the cube tells you it happens instantly but queues the requests up and waits to be contacted by a valve. I think that's what the memory slot parameters are for when you get the cube data. It fills them up with outgoing data ready for when the device makes contact. I'm not 100% sure about this but when researching it a while ago (I was going to go down the 868Mhz radio route before I found your project) I'm sure I read that's how it worked. I'll see if I can find the article.
                                  • T
                                    twisted
                                    I'm having a small issue, and I can't see why. I had to reload and now every time I try to load it I get the following before it terminates. This is from fresh install.
                                    File "main.py", line 204, in <module>
                                    Main()
                                    File "main.py", line 96, in init
                                    self.doLoop()
                                    File "main.py", line 111, in doLoop
                                    buttonCheckHeat("main")
                                    File "/home/pi/PiHeating/heatinggpio.py", line 173, in buttonCheckHeat
                                    MaxInterface().checkHeat(0)
                                    File "/home/pi/PiHeating/max.py", line 56, in checkHeat
                                    self.switchHeat()
                                    File "/home/pi/PiHeating/max.py", line 486, in switchHeat
                                    roomTemps = CreateUIPage().createRooms()
                                    File "/home/pi/PiHeating/webui.py", line 224, in createRooms
                                    actualTemp, roomOpen, roomMode)
                                    UnboundLocalError: local variable 'roomOpen' referenced before assignment
                                      Stuart Middleton
                                      That error suggests you don't have a settings file?
                                        Stuart Middleton
                                        @stephenmhall - I'm getting a lot of issues that seem to plague the MAX system (not your excellent software of course :) ) where the cube forgets the valves randomly or updating timings don't get sent to the valves. I also hate that the realtime temp isn't reported.
                                        With this said, I was wondering if you (or anyone else) had seen the BlueTooth version of the valves that they sell. And if so, has anyone taken a peek at the messages to see if the temp is reported? I'd rather control the whole thing via BT than go via the dodgy cube! :)
                                        • Maciej JablonskiM
                                          Maciej JablonskiM
                                          Maciej Jablonski
                                          wrote on last edited by Maciej Jablonski
                                          #72
                                          Looks eq-3 at least have plans for eq-3 MAX! compatible boiler/hot water controller, the manual is already there, just cannot see the product anywhere.
                                          http://www.eq-3.de/Downloads/eq3/downloads_produktkatalog/max/bda/en/BC-TS-Sw2-WM_UM_E_eQ-3_160420.pdf
                                          betzaalB 1 Reply Last reply
