  3. OpenHAB
  4. Can't get OpenHAB2 to see my MQTT messages
openhab2mqttmosquittoopenhab
5 Posts 4 Posters 14.8k Views 7 Watching
  • micahM
    micahM
    micah
    wrote on last edited by micah
    So, I thought I finally had everything setup properly, but alas something is still not working.
    Overview
    • MySensors.org 2.0 (downloaded about 3 days ago)
    • OpenHAB 2 (installed yesterday)
    • Raspberry Pi (Rasbian 1.9, updated)
    • Mosquitto (whatever the current version is)
    Devices
    • Sensor with a temperature and humidity sensor
    • I'm using the GatewayW5100MQTTClient on an Arduino Uno with a W5100 shield
    • Raspberry Pi 2 B, which is handling the MQTT broker and OpenHAB
    Status
    • Uno+Sensors+Radio is working properly
    • Gateway+Radio+Ethernet is working properly
    • Mosquitto is working properly
    • openHAB 2 is setup, but it doesn't display the sensor results
    As you can see my Arduino side of things is working properly, here is a sample of the messages I receive on my Raspberry Pi when I type mosquitto_sub -v -t 'mygateway1-out/#'
    mygateway1-out/2/1/1/0/0 19.8
    mygateway1-out/2/0/1/0/1 21.2
    I'm hoping someone can help me troubleshoot the following code snippets to figure out what's wrong, I'm pretty sure the issue in between OpenHAB 2 and Mosquitto.
    So here goes.
    OpenHAB: Sitemap
    sitemap belmont label="Main Menu"{
    	Frame {
    		Group item=gSF label="Attic" icon="secondfloor"
    		Group item=gFF label="First Floor" icon="firstfloor"
    		Group item=gGF label="Ground Floor" icon="groundfloor"
    		Group item=gC label="Basement" icon="cellar"
    		Group item=Garden icon="garden"
    	Frame label="Basement Monitor" {
    		Text item=BasementMonitor_Temp01
    		Text item=BasementMonitor_Hum01
    OpenHAB: Items
    Group All
    // Sensor Types
    Group gTemperature (All) // Contains all temperature sensors
    Group gHumidity (All) // Contains all humidity sensors
    // Floor Mappings
    Group gSF           "Attic"   		<secondfloor>
    Group gFF           "First Floor"   <firstfloor>
    Group gGF           "Ground Floor"  <groundfloor>
    Group gC            "Basement"      <cellar>
    Group Garden        "Garden"        <garden>
    // Room Mappings
    Group SF_Play       "Play Room"     <corridor>      (gSF)
    Group SF_Office		"Office"   		<office>     	(gSF)
    Group GF_Living     "Living Room"   <video>     	(gGF)
    Group GF_Dining     "Dining Room"   <video>     	(gGF)
    Group GF_Kitchen    "Kitchen"       <kitchen>   	(gGF)
    Group GF_Corridor   "Corridor"      <corridor>  	(gGF)
    Group FF_Bath       "Bathroom"      <bath>      	(gFF)
    Group FF_Kate       "Kate's Room"   <girl1>    		(gFF)
    Group FF_Jake       "Jake's Room"   <boy1>      	(gFF)
    Group FF_Bed        "Master Bedroom"   	<bedroom>   (gFF)
    Group FF_Corridor   "Corridor"      <corridor>  	(gFF)
    Group gC_Furnace    "Furnace Room"  <corridor>     	(gC)
    Number  BasementMonitor_Temp01  "Temperature [%.1f °C]"  		<temperature>   (gC_Furnace, gTemperature)   {mqtt="<[MyMQTT-2:mygateway1-out/2/1/1/0/0:state:default]"}
    Number  BasementMonitor_Hum01   "Humidity [%.1f %%]"     		<temperature>   (gC_Furnace, gHumidity)      {mqtt="<[MyMQTT-2:mygateway1-out/2/0/1/0/1:state:default]"}
    OpenHAB: mqtt.cfg
    openhab.url=tcp://localhost:1883
    openhab.clientId=MyMQTT-2
    OpenHAB: mqtt-persistance.cfg
    broker=openhab
    OpenHAB: mqtt-eventbus.cfg
    broker=openhab
    stateSubscribeTopic=MyMQTT-2/stateUpdates/${item}/state
    commandSubscribeTopic=MyMQTT-2/commandUpdates/${item}/command
    Help
    What am I doing wrong?
    • micahM
      micahM
      micah
      VICTORY!!!!
      Apparently I just needed to bang my head against the keyboard and randomly try combinations until it worked.
      So to hopefully help other people I'll post how I got it to work.
      OpenHAB: Items
      Number  BasementMonitor_Temp01  "Temperature [%.1f °C]"  		<temperature>   (gC_Furnace, gTemperature)   {mqtt="<[mysensors:mygateway1-out/2/1/1/0/0:state:default]"}
      Number  BasementMonitor_Hum01   "Humidity [%.1f %%]"     		<temperature>   (gC_Furnace, gHumidity)      {mqtt="<[mysensors:mygateway1-out/2/0/1/0/1:state:default]"}
      OpenHAB: mqtt.cfg
      mysensors.url=tcp://localhost:1883
      mysensors.clientId=openHAB
      broker=mysensors
      broker=mysensors
      stateSubscribeTopic=MyMQTT/stateUpdates/${item}/state
      commandSubscribeTopic=MyMQTT/commandUpdates/${item}/command
      Arduino: GatewayW5100MQTTClient
      So to summarize here are the key parts (I think):
      • Broker = mysensors
      • clientId = openHAB
      • pattern for items = {mqtt="<[mysensors:mygateway1-out/2/0/1/0/1:state:default]"}
      I'm still not sure if the second and third line in the mqtt-eventbus.cfg is correct. I don't have MyMQTT anywhere else, so I think I may try different combinations to see what works.
      D 1 Reply Last reply
      • laihozL
        laihozL
        laihoz
        Hi! Can you post your arduino sketches as well??
        Thanks!
        • Q
          Q
          Qu3Uk
          This helped me out a lot, thanks!
          • micahM micah
            VICTORY!!!!
            OpenHAB: Items
            OpenHAB: mqtt.cfg
            broker=mysensors
            broker=mysensors
            D
            D
            dakipro
            @micah said in Can't get OpenHAB2 to see my MQTT messages:
            MyMQTT should be replaced with brokername (mysensors in this example). openhab will then publish the event to the mqtt broker on its topics (useful if you use f.eks. node-red for openhab rules)
