  3. Get Temperature from other nodes(through VERA).
7 Posts 2 Posters 3.3k Views 2 Watching
  • C Offline
    C Offline
    clio75
    wrote on last edited by clio75
    I'm have started to plan a irrigation controller(Thanx @petewill).
    But I need to get the temperature from my sensors to my controller. I have not been able to do this :(
    My plan was to read this out from my vera controller, but cant find any way to do this.
    Does anyone have a advice or idea to do this ?
    I'm using the V2.0.0, of library.
    I have tried to use the
    request(tempNode_ID, V_TEMP) But no replay from VERA.
    To store/update the "setTemp" I'm using the V_VAR1 on the and this is returned from VEAR.
    So Is this possible or not ?
    Thanx
    K 1 Reply Last reply
    • C clio75
      Thanx
      K Offline
      K Offline
      korttoma
      Hi @clio75
      Here is an example of the lua I use when sending V_VAR1 to a MySensors Node:
      16 is the id of the device from where I get the temperature value.
      24 is the id of the MySensors plugin main device
      11;3 is the altid of the MySensors node device to witch I'm sending the value.
      local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 16)
      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=temp}, 24)
      Here is an example of the receive code in the node itself:
        if (message.type == V_VAR1)
          OutdoorTemp = String(message.data);
          //Serial.print("OutdoorTemp recieved:");
          //Serial.println(OutdoorTemp);
      • Tomas
      • C Offline
        C Offline
        clio75
        hi @korttoma
        Thanx for your suggestion, But I was not able to figure out where to insert this LUA code.
        Thanx
        • C clio75
          hi @korttoma
          Thanx
          K Offline
          K Offline
          korttoma
          @clio75 you could add it as an action in a scene under "Also, execute the following Luup code:".
          The way I use it is to send weather information to a small display node so I have a PLEG condition running every 10min to update the information. So I have the lua code as an action for the PLEG condition.
          • Tomas
          C 1 Reply Last reply
          • K korttoma
            C Offline
            C Offline
            clio75
            @korttoma
            Thanx, I will Try again this afternoon :)
            • C clio75
              @korttoma
              C Offline
              C Offline
              clio75
              @korttoma
              Thanx this is working perfect.
              • C Offline
                C Offline
                clio75
                Hi @korttoma,
                Just an other question,
                II'm also using PLEG.
                Is there a way to compeer the last value against the new value and only IF these values are different we sending a this new value.
                some thing like :
                local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 35)
                local oldTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","VAR_1", 14)
                if temp != oldTemp then
                luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="14;2", variableId="VAR_1", value=temp}, 3)
                end
                Thanx
