  3. Humidity Sketch causes Vera App to crash
15 Posts 4 Posters 6.3k Views 4 Watching
    Strange. You could also try converting it to a string before sending.
      You did remove the number-of-decimal argument?
      msgHum.set(humidity, 1) -> msgHum.set(humidity)
      B 1 Reply Last reply
        B
        B
        Bradley A
        @hek Ah Hah! That did the trick. I had only changed the variable to an int but had not removed the decimal argument. Works perfectly now! Thanks @hek !!
        • jeylitesJ
          jeylitesJ
          jeylites
          I have the same issue. Will work on the fix when I get back.
          • jeylitesJ jeylites
            B
            B
            Bradley A
            The fix is pretty simple, as @hek said the DHT sensors arent extremely accurate anyway (DHT11 is +/- 5% accurate), just change msgHum.set(humidity,1) to msgHum.set(humidity) in the sensor sketch to drop the decimal all together. Worked perfect for me and has been running flawless since yesterday now
            jeylitesJ 1 Reply Last reply
            • B Bradley A
              jeylitesJ
              jeylitesJ
              jeylites
              wrote on last edited by jeylites
              @Bradley-A
              @hek
              The fix seem pretty easy to follow. But when I exclude the "1" and recompile, I get a bunch of error messages.
              HumiditySensor.ino: In function 'void loop()':
              HumiditySensor.ino:56:34: error: call of overloaded 'set(float&)' is ambiguous
              HumiditySensor.ino:56:34: note: candidates are:
              In file included from /Users/Jey/Documents/Arduino/libraries/MySensors/MySensor.h:17:0,
                               from HumiditySensor.ino:2:
              /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:161:13: note: MyMessage& MyMessage::set(uint8_t)
                MyMessage& set(uint8_t value);
              /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:163:13: note: MyMessage& MyMessage::set(long unsigned int)
                MyMessage& set(unsigned long value);
              /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:164:13: note: MyMessage& MyMessage::set(long int)
                MyMessage& set(long value);
              /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:165:13: note: MyMessage& MyMessage::set(unsigned int)
                MyMessage& set(unsigned int value);
              /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:166:13: note: MyMessage& MyMessage::set(int)
                MyMessage& set(int value);
              Error compiling.```
                You must cast the value to int.
                gw.send(msg.set((int)xx));
                • jeylitesJ
                  jeylitesJ
                  jeylites
                  @hek
                  I'm not following that part ... is it like this
                  gw.send(msgHum.set((int)humidity));
                    The compile can't find a method matching the argument you're calling the overloaded method "set" with.
                    It looks at the type of the argument (float in your case).
                    So you can either change "humidity" to be a int when you declare it or cast it to an int.
                    • ThomasDrT
                      ThomasDrT
                      ThomasDr
                      i see this is a old posting, but i have the same problem. But i found an error.
                      I use
                      send(summsg.set(sum));
                      but this work:
                      send(summsg.set(sum,5));
                      regards
                      ThomasD
                      12.5k
