Humidity Sketch causes Vera App to crash
@hek Just a quick update. Changed the float to an int on the sensor during my lunch break. No luck. Vera still recieves it with a decimal. Confirmed with the serial console that the sensor is indeed sending it as a int now though. Perhaps the Arduino gateway is coverting it back to a float before sending it? Will do some more digging after work again
You did remove the number-of-decimal argument?
msgHum.set(humidity, 1) -> msgHum.set(humidity)
@jeylites said:
I have the same issue. Will work on the fix when I get back.
The fix is pretty simple, as @hek said the DHT sensors arent extremely accurate anyway (DHT11 is +/- 5% accurate), just change msgHum.set(humidity,1) to msgHum.set(humidity) in the sensor sketch to drop the decimal all together. Worked perfect for me and has been running flawless since yesterday now
The fix seem pretty easy to follow. But when I exclude the "1" and recompile, I get a bunch of error messages.
Build options changed, rebuilding all HumiditySensor.ino: In function 'void loop()': HumiditySensor.ino:56:34: error: call of overloaded 'set(float&)' is ambiguous HumiditySensor.ino:56:34: note: candidates are: In file included from /Users/Jey/Documents/Arduino/libraries/MySensors/MySensor.h:17:0, from HumiditySensor.ino:2: /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:161:13: note: MyMessage& MyMessage::set(uint8_t) MyMessage& set(uint8_t value); ^ /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:163:13: note: MyMessage& MyMessage::set(long unsigned int) MyMessage& set(unsigned long value); ^ /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:164:13: note: MyMessage& MyMessage::set(long int) MyMessage& set(long value); ^ /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:165:13: note: MyMessage& MyMessage::set(unsigned int) MyMessage& set(unsigned int value); ^ /Users/Jey/Documents/Arduino/libraries/MySensors/MyMessage.h:166:13: note: MyMessage& MyMessage::set(int) MyMessage& set(int value); ^ Error compiling.``` -
