  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
  • scalzS scalz
    lol
    yep you were right, where's waldo/wally but where i live we say Charlie :)
    #43
    @scalz
    Sacrébleu. I just now tried sending your gerber files to OSH PARK, but it complains, " I can't find a board outline file." A fab will need a complete set of files to get anything done.
      In any event, the "stripped" BQ25504 board that I received yesterday looks rather disheveled:
      @scalz
      Do you see any Wally's in it?
        #45
        ahah :)
        If it can help you, here it is : https://oshpark.com/shared_projects/XRsFBtzu
        This is because i've generated the gerbers with an other fabhouse CAM.
        In mine, GML is the dimension layer if i remember right.
        You can also open the gerbers in a viewer like Gerbv etc..
        For oshpark, i have modified it a little bit because of slightly different DRC.
        • scalzS scalz
          ahah :)
          @scalz
          Thanks. I just now ordered it.
          Interestingly, if you look at Ti's eval board for the bq25504, they do in fact connect the top and bottom ground planes, and the thermal pad on the BQ25504 is connected to the entire bottom ground plane, not just another small thermal pad:
          https://www.ti.com/seclit/df/tidu094/tidu094.pdf
            cool.
            Well, perhaps it's ok. I followed datasheet guidelines..no matter the powerpad is connected on top.
            Perhaps, you may need the schematic to know where parts are placed ;)
            You'll need to set your resistors of course.
            If really needed, no problem i can upload all the files..
            • scalzS scalz
              cool.
              @scalz
              You should upload it to https://www.openhardware.io/ I'm sure a lot of people would find it very helpful.
              • scalzS scalz
                cool.
                @scalz
                Out of curiosity, why did you choose such a large inductor? I notice that the "stripped" BQ25504 pcb (photo above) did the same thing. Are there advantages to the larger size?
                  @scalz
                  #50
                  @NeverDie said:
                  @scalz
                  Nevermind. I see now from your schematic that you're using the coilcraft inductor from Table 1 of the DS.
                    Interestingly, looking at the Tindie board now, it's clear based on its inductor's dimensions that the Tindie board is not using one of the Table 1 recommended inductors. Perhaps that explains why the Tindie board appears to be sucking wind at the lower voltages.
                      #52
                      Coilcraft doesn't seem very available in the US, but Wurth has a similar one that's still on the DS table list that's probably a good substitute: http://www.digikey.com/product-detail/en/wurth-electronics-inc/744031220/732-1012-1-ND/1639073
                      Also, I'll have to update my board to use a larger inductor. I had blithely assumed, based on the Tindie board, that an 0805 would be sufficient, but now that I'm digging into it probably not.
                        I take it back. The Wurth component I just referenced has a rather complex looking land pattern.
                        Fortunately, the last remaining component on the Table 1 recommended list is a Wurth that has a much easier land pattern: http://www.digikey.com/product-detail/en/wurth-electronics-inc/744025220/732-2619-1-ND/2445718
                          #54
                          yep from guidelines.
                          but also because it's better to use shielded inductors for multiple reasons like EMI..and also good inductors and parts give better perf, efficiency etc.. lot of docs on this.
                          That said, the footprint i use is also compatible with the 0805 advised in datasheet if i remember. it's possible to use both ref for the same footprint i've not the datasheet in front of me right now but width shoud be ok.
                          • scalzS scalz
                            It seems as though TI's evaluation board ignores the design recommendations given in the datasheet, in particular: "...it is highly recommended that no ground planes be poured near the voltage setting resistors or the sample and hold capacitor." In the case of the TI's evaluation board, virtually the entire bottom layer is a ground plane. I don't know what to make of that.
                            Anyhow, I ordered the Wurth inductors. I also ordered a 3x3 QFN-16 solder stencil as some fallback insurance, as the BQ25504 looks like it will be very challenging to solder.
                              Also, the layout guidelines say, " It is best to use vias and bottom traces for connecting the inductor to its respective pins instead of the capacitors." Yet, the recommended layout doesn't do that.
                                #57
                                Part of what's strange is the Recommended Layout (Figure 34 in the datasheet) shows pin 12 belonging to a different ground plane than pin 13. Yet, the schematic shows pins 12 and 13 wired directly together.
                                @scalz
                                Just where are the two different ground planes supposed to connect together? Or is one supposed to float relative to the other?
                                  ok i'll put on my git&openhardware asap.
                                  about the planes, you're right. I've a little doubt. on most designs, it's directly to gnd. i understand about the layout guidelines. but the datasheet picture layout is a bit confusing, if it's internally connected or not..i'll check a bit later.
                                  good point ;)
                                  • scalzS scalz
                                    good point ;)
                                    @scalz
                                    Section 11.1 says, "When laying out the non-power ground return paths (e.g. from resistors and CREF), it is recommended to use short traces as well, separated from the power ground traces and connected to AVSS pin 12. This avoids ground shift problems, which can occur due to superimposition of power ground current and control ground current. The PowerPad should not be used as a power ground return path."
                                    I think that's why in the Recommended Layout (Figure 34), pins 12 and 13 are not connected directly together. However, on your board, they are directly connected, probably because of the schematic.
                                    What do they mean by "The PowerPad"? Do they mean the thermal pad beneath the chip? Maybe that's another reason why pin 12 is not connected to the thermal pad in the Recommended Layout.
                                    I don't know what the right answer is. I'm just trying to make sense of what seem like inconsistencies in the datasheet.
                                      I suppose if worse came to worst, we could try answering the question empirically by using a test setup similar to this:
                                      In this instance I partitioned the data ground from the power ground, and the two are not connected. However, via the header pins, a jumper could be connected between the two grounds. The experiment would be to try it both ways--connected vs. unconnected--and see which performs better.
                                        #61
                                        The through holes on the stripped BQ25504 PCB (above)from Osh Park have too small a diameter to fit header pins into. In fact, it would require a very narrow gauge wire (narrower than what I have) to fit into it. So, unfortunately, I have doubts as to whether I will be able to test it, let alone use it.
                                        This is all rather disappointing. :confounded: So far nothing about the BQ25504 has been easy.
                                          Not that it proves anything, but using KiCAD to look at the BQstripped PCB, I notice that the PCB designer chose to connect pins 12 and 13 both directly to each other and directly to the thermal pad.
                                          blaceyB 1 Reply Last reply
