  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
    #33
    Here's what I'm going with for now:
    As you can see, this one uses only one ground plane. Board size is 22mmx18mm. It uses 0603 and 0805 discrete parts, which for me makes it easier to hand solder. The only tricky part to hand solder will be the BQ25504 itself, but there's nothing I can do about that.
      sorry for delay..
      i have a pad on bottom but it's not grounded on the bottom side. the power pad is grounded only on top. i don't remember but you should have a layout guideline included with the circuit footprint, for explaining.
      i also use 0603/0805.
        #35
        I guess my oval pads reverted to the default pattern when I re-synced with the schematic. So, fixing that again, here's what I'm going with:
        There's a bit more clean-up I should probably do, but I need to learn a bit more about Diptrace before I can do it. Meanwhile, I sent Version 6 to the fab, since fabbing is the critical path.
        • scalzS scalz
          sorry for delay..
          In that case, if you want to post your fab files, I can post mine. Then we can have a healthy competition to see whether they work the same or whether one works better than the other.
            #37
            oh, no competition... or let me win please :laughing: I'm joking. that said i'm not sure, but I think i see Wally on your board ;)
            I'm back in an hour for sharing. i need to assemble few boards for myself :)
            • scalzS scalz
              #38
              LOL. You probably need better ventilation when you're soldering. The fumes are getting to you. :laughing:
              NeverDieN scalzS 2 Replies Last reply
                #39
                Interestingly, in today's mail I received the "BQ25504 Stripped" PCB
                https://oshpark.com/shared_projects/CYdxpE9S
                that I ordered on November 16. That's about twice faster than their normal turnaround speed when I send them new fab files. The board itself is noticeably smaller than the Tindie board.
                  #40
                  :laughing: no fumes tonight, reflow oven working for me :)
                  Wally is in your GND pour, in each of your board I think.
                  I mean you should not have any gnd around some settings resistors and capa.
                  Check carefully the section 11.1 Layout Guidelines in datasheet.
                  This is why on the reference layout you see Top GND only on half board. Or then it may happen less performance depending of mutliple factors.
                  It's also explained how to route the GND.
                  That said, in case it can help, here is my gerbers https://www.dropbox.com/s/tugdbc3cfrlmdu7/bq25504_gerbers.rar?dl=0
                  Enjoy
                  • scalzS scalz
                    Enjoy
                    #41
                    @scalz
                    What is "Wally"? I haven't heard that term before, and it's not in the datasheet either. I thought you were jokingly making an obscure reference to Waldo, as in "Where's Waldo?" That's why I had thought the fumes must have gotten to you. I realize now that Wally must instead be a French electrical term of some kind.
                      lol
                      yep you were right, where's waldo/wally but where i live we say Charlie :)
                      • scalzS scalz
                        lol
                        #43
                        @scalz
                        Sacrébleu. I just now tried sending your gerber files to OSH PARK, but it complains, " I can't find a board outline file." A fab will need a complete set of files to get anything done.
                          In any event, the "stripped" BQ25504 board that I received yesterday looks rather disheveled:
                          @scalz
                          Do you see any Wally's in it?
                            #45
                            ahah :)
                            If it can help you, here it is : https://oshpark.com/shared_projects/XRsFBtzu
                            This is because i've generated the gerbers with an other fabhouse CAM.
                            In mine, GML is the dimension layer if i remember right.
                            You can also open the gerbers in a viewer like Gerbv etc..
                            For oshpark, i have modified it a little bit because of slightly different DRC.
                            • scalzS scalz
                              ahah :)
                              @scalz
                              Thanks. I just now ordered it.
                              Interestingly, if you look at Ti's eval board for the bq25504, they do in fact connect the top and bottom ground planes, and the thermal pad on the BQ25504 is connected to the entire bottom ground plane, not just another small thermal pad:
                              https://www.ti.com/seclit/df/tidu094/tidu094.pdf
                                cool.
                                Well, perhaps it's ok. I followed datasheet guidelines..no matter the powerpad is connected on top.
                                Perhaps, you may need the schematic to know where parts are placed ;)
                                You'll need to set your resistors of course.
                                If really needed, no problem i can upload all the files..
                                • scalzS scalz
                                  cool.
                                  @scalz
                                  You should upload it to https://www.openhardware.io/ I'm sure a lot of people would find it very helpful.
                                  • scalzS scalz
                                    cool.
                                    @scalz
                                    Out of curiosity, why did you choose such a large inductor? I notice that the "stripped" BQ25504 pcb (photo above) did the same thing. Are there advantages to the larger size?
                                      @scalz
                                      #50
                                      @NeverDie said:
                                      @scalz
                                      Nevermind. I see now from your schematic that you're using the coilcraft inductor from Table 1 of the DS.
                                        Interestingly, looking at the Tindie board now, it's clear based on its inductor's dimensions that the Tindie board is not using one of the Table 1 recommended inductors. Perhaps that explains why the Tindie board appears to be sucking wind at the lower voltages.
                                          #52
                                          Coilcraft doesn't seem very available in the US, but Wurth has a similar one that's still on the DS table list that's probably a good substitute: http://www.digikey.com/product-detail/en/wurth-electronics-inc/744031220/732-1012-1-ND/1639073
                                          Also, I'll have to update my board to use a larger inductor. I had blithely assumed, based on the Tindie board, that an 0805 would be sufficient, but now that I'm digging into it probably not.
