  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P
    pentti12P
    pentti12
    Before I set up full logging environment, I wonder why I cannot get connection when I enter following command on the terminal window of OH2 server (Pine64):
    telnet localhost 5003
    unable to connect to remote host
    jogantJ 1 Reply Last reply
    • JicJ
      JicJ
      Jic
      I didn't see in your node log an ip assignament. Are your sketch configured to Ethernet Gateway?
      I think you should use some parameters:
      #define MY_IP_ADDRESS 192,168,178,87
      #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
      #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
      I am not sure how to use Ethernet Gateway, perhaps this example help you
      https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
      • pentti12P
        pentti12P
        pentti12
        I am not using the MQTT gateway, I am using standard GatewayW5100.ino, which has correct IP-settings:
        #define MY_IP_ADDRESS 192,168,1,201 // If this is disabled, DHCP is used to retrieve address
        #define MY_PORT 5003
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 185
        // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
        And MySensors Ethernet Gateway is detected by Advanced IP Scanner and I can ping it and so on..
        JicJ 1 Reply Last reply
        • pentti12P pentti12
          jogantJ
          jogantJ
          jogant
          @pentti12
          the gateway is the server. You should succeed with telnet <ip_of_mysensors_gw> 5003
            JicJ
            JicJ
            Jic
            @pentti12
            Can you start manually your gateway with -d option to see the log?
            You should see there if your gateway its receiving messages. If you are receiving message then, the problem should be in the OH2
            • JicJ Jic
              @pentti12
              jogantJ
              jogantJ
              jogant
              @Jic
              what do you mean with "start gateway manually -d option"? My gateway is a standalone device, ethernet connector on one side, nrf24 on the other, arduino in the middle connecting the other two parts.
              • pentti12P
                pentti12P
                pentti12
                Wait a minute! I think that from the original GatewayW5100 sketch there were missing the IP Gateway and subnet addresses!
                So I will recompile sketch and test again.
                  jogantJ
                  jogantJ
                  jogant
                  wrote on last edited by jogant
                  #49
                  @pentti12
                  slowly my image gets complete. Online/Offline status is resolved by OH2 binding via polling during initialization. Value updates are sent spontaneous by the gateway via callback, afair. So the gateway needs to know the address and mask of the controller to send values.
                  • pentti12P
                    pentti12P
                    pentti12
                    No help after new sketch loaded into GatewayW5100. OH2 log informs the same result:
                    14:49:09.484 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                    I will take a break - to be continued on next day...
                      jogantJ
                      jogantJ
                      jogant
                      @pentti12
                      "connection skipped" message occurs frequently, usually every 10 seconds. That is normal and ok. But you should see messages from the gateway everytime the sensor nodes send updates, except the value is the same as before.
                      • pentti12P
                        pentti12P
                        pentti12
                        I connected my laptop into Ethernet Gateway. Here is a sample of monitoring listing:
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.4
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.9
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.5
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.0
                        0;255;3;0;9;TSP:SANCHK:OK
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.8
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.8
                        So I think that this is OK, when I have only one sensor node alive.
                        But still, how I shall modify my Arduino Gateway sketch in order to get OH2 server show temperature and humidity values?
                          JicJ
                          JicJ
                          Jic
                          @pentti12
                          Could be permission problem?
                          Can you connect your gateway on rpi and execute
                          ls -l /dev/tty*
                          I think you are using a ethernet gateway skecth, normaly it's should be mounted in /dev/ttyACM0
                          Have you already execute
                          sudo usermod -a -G dialout openhab
                          Be sure that you have the las binding
                          https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                          and your openhab2 is updated.
                          • pentti12P
                            pentti12P
                            pentti12
                            I am running the Ethernet GatewayW5100 software on Arduino UNO. I don't have rpi, I have installed OH2 on Pine64. It is running debian Jessie and it is uptodate. Also the latest mysensors binding is in use. So what to next?
                              JicJ
                              JicJ
                              Jic
                              wrote on last edited by Jic
                              #55
                              @pentti12 I am confused.
                              Don't you need to connect your Ethernet GatewayW5100 by USB into your pine64?
                              • pentti12P
                                pentti12P
                                pentti12
                                OK, now Gateway is connected via USB into Pine64 and it is shown as /dev/ttyUSB0.
                                  JicJ
                                  JicJ
                                  Jic
                                  @pentti12 said:
                                  /dev/ttyUSB0
                                  Now, you need to configure your binding in your OH2?
                                  https://github.com/tobof/openhab2-addons/wiki/Configuration
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    I added into demo.things following line:
                                    Bridge mysensors:bridge-ser:gateway [ serialPort="dev/ttyUSB0", sendDelay=200 ] {
                                    In OH2 MySensor Serial Gateway stays OFFLINE state now. And also the Philips HUE things went OFFLINE state even if they have their own Bridge.
                                    Looks bad!
                                      Looks bad!
                                      JicJ
                                      JicJ
                                      Jic
                                      @pentti12 This configuration is for a Serial Gateway connected to GPIO, I think.
                                      You should use this one
                                      Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
                                      But at this point I am really confused, I don't know how Ethernet Gateway works. I am not sure when I can help you.
                                      Do you need configure you ESSID and password of your WIFI in your sketch? or the ethernet Gateway geneate their own network?
                                      • pentti12P
                                        pentti12P
                                        pentti12
                                        Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
                                        I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
                                          JicJ
                                          JicJ
                                          Jic
                                          @pentti12
                                          Ok, sorry, I think I was wrong.
                                          Here has a similar example
                                          http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/
                                          Could you try connecting it again separately, and configure in your OH2 and ethernet binding with the ip from your gatweay?
