  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    Wait a minute! I think that from the original GatewayW5100 sketch there were missing the IP Gateway and subnet addresses!
    So I will recompile sketch and test again.
    jogantJ
    jogantJ
    jogant
    wrote on last edited by jogant
    #49
    @pentti12
    slowly my image gets complete. Online/Offline status is resolved by OH2 binding via polling during initialization. Value updates are sent spontaneous by the gateway via callback, afair. So the gateway needs to know the address and mask of the controller to send values.
    • pentti12P
      pentti12P
      pentti12
      No help after new sketch loaded into GatewayW5100. OH2 log informs the same result:
      14:49:09.484 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
      I will take a break - to be continued on next day...
      jogantJ 1 Reply Last reply
        jogantJ
        jogantJ
        jogant
        @pentti12
        "connection skipped" message occurs frequently, usually every 10 seconds. That is normal and ok. But you should see messages from the gateway everytime the sensor nodes send updates, except the value is the same as before.
        • pentti12P
          pentti12P
          pentti12
          I connected my laptop into Ethernet Gateway. Here is a sample of monitoring listing:
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.4
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.9
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.5
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.0
          0;255;3;0;9;TSP:SANCHK:OK
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.8
          0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.8
          So I think that this is OK, when I have only one sensor node alive.
          But still, how I shall modify my Arduino Gateway sketch in order to get OH2 server show temperature and humidity values?
          JicJ 1 Reply Last reply
            JicJ
            JicJ
            Jic
            @pentti12
            Could be permission problem?
            Can you connect your gateway on rpi and execute
            ls -l /dev/tty*
            I think you are using a ethernet gateway skecth, normaly it's should be mounted in /dev/ttyACM0
            Have you already execute
            sudo usermod -a -G dialout openhab
            Be sure that you have the las binding
            https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
            and your openhab2 is updated.
            • pentti12P
              pentti12P
              pentti12
              I am running the Ethernet GatewayW5100 software on Arduino UNO. I don't have rpi, I have installed OH2 on Pine64. It is running debian Jessie and it is uptodate. Also the latest mysensors binding is in use. So what to next?
                JicJ
                JicJ
                Jic
                wrote on last edited by Jic
                #55
                @pentti12 I am confused.
                Don't you need to connect your Ethernet GatewayW5100 by USB into your pine64?
                • pentti12P
                  pentti12P
                  pentti12
                  OK, now Gateway is connected via USB into Pine64 and it is shown as /dev/ttyUSB0.
                    JicJ
                    JicJ
                    Jic
                    @pentti12 said:
                    /dev/ttyUSB0
                    Now, you need to configure your binding in your OH2?
                    https://github.com/tobof/openhab2-addons/wiki/Configuration
                    • pentti12P
                      pentti12P
                      pentti12
                      I added into demo.things following line:
                      Bridge mysensors:bridge-ser:gateway [ serialPort="dev/ttyUSB0", sendDelay=200 ] {
                      In OH2 MySensor Serial Gateway stays OFFLINE state now. And also the Philips HUE things went OFFLINE state even if they have their own Bridge.
                      Looks bad!
                        Looks bad!
                        JicJ
                        JicJ
                        Jic
                        @pentti12 This configuration is for a Serial Gateway connected to GPIO, I think.
                        You should use this one
                        Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
                        But at this point I am really confused, I don't know how Ethernet Gateway works. I am not sure when I can help you.
                        Do you need configure you ESSID and password of your WIFI in your sketch? or the ethernet Gateway geneate their own network?
                        • pentti12P
                          pentti12P
                          pentti12
                          Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
                          I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
                            JicJ
                            JicJ
                            Jic
                            @pentti12
                            Ok, sorry, I think I was wrong.
                            Here has a similar example
                            http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/
                            Could you try connecting it again separately, and configure in your OH2 and ethernet binding with the ip from your gatweay?
                            • pentti12P
                              pentti12P
                              pentti12
                              Can someone explain, why I cannot get real values from MySensors node, which has only temperature and humidity sensors?
                              I can get the MySensors Ethernet Gateway into ONLINE STATE. I can get humidity and Temperature Sensors ONLINE STATE, but I cannot get real values from the node.
                              What I see from OpenHAB2 log side is:
                              09:31:45.356 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                              09:31:45.375 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                              09:31:48.356 [WARN ] [otocol.MySensorsNetworkSanityChecker] - I_VERSION message response is not arrived. Remained attempts before disconnection 1
                              09:31:55.377 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                              09:32:05.380 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                              I think that there must be some error in MySensors Binding at the moment, because for example the Philips HUE bridge is working corretly via Openhab2 in the same Pine64 controller.
                              JicJ T 2 Replies Last reply
                                JicJ
                                JicJ
                                Jic
                                @pentti12
                                This message is, following the information
                                https://www.mysensors.org/download/serial_api_20
                                node-id ; child-sensor-id ; message-type ; ack ; sub-type ; payload \n
                                0; ;0 ;3 ;0 ;2 ;
                                A message-type=3 means an internal message of the protocol
                                Sub-type=2 means that it is ascking for the gateway version.
                                You can find here how to disable it using skipStartupCheck=true
                                Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200, skipStartupCheck=true ] {
                                I hope this help you.
                                  TimO
                                  Hey @pentti12!
                                  Which gateway are you using? Serial or Ethernet? You can't use the ethernet gateway via serial connection.
                                  Which sketch are you using?
                                  If you are using ethernet gateway sketch but used the serial connection this would explain why the binding could not get any response.
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    I am using Ethernet Gateway in my LAN. Gateway has static IP and it is accessible (ping works). Also port number 5003 is detected correctly.
                                    I am using standard GatewayW5100.ino sketch.
                                    How can I force OH2 to use only Ethernet-connection?
                                    • T
                                      TimO
                                      Have you configured the gateway in the *.things file? How does it look?
                                      • triceTT
                                        triceTT
                                        triceT
                                        Hello to all.
                                        I have similar problems as pentti12.
                                        Can not get values updated in OH2, there are always -NAN
                                        While with serial connection I get some reads in the log file, with eth connection I can't see any reads from gw.
                                        I've installed everything as per wiki several times without success.
                                        Radio connection between gw and nodes is running without problems.
                                        Previous testing gw with w5100MQTTClient sketch, was running perfectly
                                        My configuration:
                                        MySensors Binding: 2.0.0.201611221149
                                        OH2: 2.0.0-SNAPSHOT Build #629 running on debian
                                        gw: Arduino Uno with W5100 sketch
                                        Node: arduino nano with temp and humidity sensor.
                                        Could somebody help me in this.
                                        Regards!
                                        *** Debug for serial connection without skipping I-Version check
                                        2016-12-05 22:06:22.608 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                                        2016-12-05 22:06:22.634 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                                        2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                                        2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                                        2016-12-05 22:06:25.665 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                                        2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                                        2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                                        2016-12-05 22:06:25.668 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                                        2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                                        2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                                        2016-12-05 22:06:25.865 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:06:26.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                                        2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                                        2016-12-05 22:06:27.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:06:28.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:06:29.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                                        2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:27)
                                        2016-12-05 22:06:30.666 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                                        2016-12-05 22:06:30.666 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                                        2016-12-05 22:06:30.666 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialWriter
                                        2016-12-05 22:06:30.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                                        2016-12-05 22:06:30.670 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                                        *** Debug for serial connection skipping I-Version check
                                        2016-12-05 22:16:52.785 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                        2016-12-05 22:16:52.786 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: true
                                        2016-12-05 22:16:52.787 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                                        2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                        2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                                        2016-12-05 22:16:52.789 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                        2016-12-05 22:16:52.793 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                                        2016-12-05 22:16:52.821 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                                        2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                                        2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                                        2016-12-05 22:16:55.852 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                                        2016-12-05 22:16:55.855 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                                        2016-12-05 22:16:55.856 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                                        2016-12-05 22:16:55.855 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                                        2016-12-05 22:16:55.860 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:power:9ba30e1b
                                        2016-12-05 22:16:55.862 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                                        2016-12-05 22:16:55.863 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                                        2016-12-05 22:16:55.863 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                                        2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                                        2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-6 not registered yet, registering...
                                        2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                                        2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                                        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                                        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                                        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                                        2016-12-05 22:16:57.553 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                                        2016-12-05 22:16:57.558 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                                        2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:BC
                                        2016-12-05 22:17:00.812 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=4)
                                        2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                        2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:GWL OK
                                        2016-12-05 22:17:01.091 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        2016-12-05 22:17:02.854 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                        2016-12-05 22:17:02.857 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=1)
                                        2016-12-05 22:17:02.868 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        2016-12-05 22:17:02.881 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2016-12-05 22:17:02.924 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                        2016-12-05 22:17:02.935 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                        2016-12-05 22:17:04.940 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                                        2016-12-05 22:17:05.863 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                        2016-12-05 22:17:06.765 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                        2016-12-05 22:17:08.599 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=0,t=1,pt=0,l=0,sg=0:
                                        2016-12-05 22:17:10.422 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=0,t=7,pt=0,l=0,sg=0:
                                        2016-12-05 22:17:12.248 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                        2016-12-05 22:17:12.258 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        2016-12-05 22:17:12.261 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                        2016-12-05 22:17:12.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
                                        2016-12-05 22:17:12.309 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                        2016-12-05 22:17:12.320 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        2016-12-05 22:17:12.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.3
                                        2016-12-05 22:17:14.157 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.8
                                        2016-12-05 22:17:15.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                        2016-12-05 22:17:15.980 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.788
                                        2016-12-05 22:17:25.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                        2016-12-05 22:17:34.431 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:1
                                        2016-12-05 22:17:35.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                        2016-12-05 22:17:36.265 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.4
                                        2016-12-05 22:17:38.088 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.6
                                        2016-12-05 22:17:39.911 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.768
                                        2016-12-05 22:17:41.744 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:0
                                        *** Debug for Ethernet connection without skipping I-Version check
                                        2016-12-05 22:23:12.927 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                        2016-12-05 22:23:12.930 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
                                        2016-12-05 22:23:12.931 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                                        2016-12-05 22:23:12.934 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                        2016-12-05 22:23:12.935 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                                        2016-12-05 22:23:12.937 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                        2016-12-05 22:23:12.938 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                                        2016-12-05 22:23:13.148 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:23:13.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:23:14.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:23:15.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:23:16.964 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        2016-12-05 22:23:17.964 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                                        2016-12-05 22:23:17.967 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                                        2016-12-05 22:23:17.968 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                        2016-12-05 22:23:17.968 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                                        2016-12-05 22:23:17.971 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                                        2016-12-05 22:23:17.975 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 10, revertState: false
                                        2016-12-05 22:23:17.976 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                                        2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 11, revertState: false
                                        2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                                        2016-12-05 22:23:17.990 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                                        2016-12-05 22:23:17.991 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                                        *** Debug for Ethernet connection skipping I-Version check
                                        2016-12-05 22:27:59.514 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                                        2016-12-05 22:27:59.515 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                                        2016-12-05 22:27:59.515 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                        2016-12-05 22:27:59.525 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                                        2016-12-05 22:27:59.527 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                                        2016-12-05 22:27:59.527 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                        2016-12-05 22:27:59.528 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
                                        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                                        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                                        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                                        2016-12-05 22:28:09.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                        2016-12-05 22:28:19.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                        • triceTT triceT
                                          Hello to all.
                                          My configuration:
                                          Regards!
                                          TimO
                                          wrote on last edited by TimO
                                          #68
                                          @triceT you're trying to connect per serial to your ethernet gateway. Try connecting with the ethernet gateway configuration using the IP 192.168.1.66 and port 5003, like in the last output of your post. You only get the debug output of the serial gateway in OH2, the messages from the nodes are not forwarded to serial.
                                          The connection seems to be get established, but there is no answer to the I_VERSION message. Are you using RFM69? Did you try a "telnet 192.168.1.66 5003"? Do you see messages incoming?
                                          triceTT 1 Reply Last reply
